Which one you preferred?
Nice work, I suggest 22k pot instead 12k resistor for simetry adjust not 470k pot.
Ok... you mean like this?
This is ok, but I don't want use trim pots.
Ok so you want me to remove the 22K pot or let's keep it as an optional for some diy freinds?
Let's keep it as an optional for some diy freinds
Cool! Will post the files shortly.....
Here's the file for APEX AX-6 Rev. 1.4.
thanks Willy, bourns trimpots are tops and allows for output symmetry and bias adjustments, i would use no other types...
Willy 10uF polarity reverted.
Good catch Mr. Mile Thank you... will correct that shortly.
Ok here's the corrected one....
^what i have in mind is more bias than that...
It's a minimum value to remove crossover distortions, use more if you have large heatsinks
What is the recommended trafo that i would need to use, with 2N3055? (srednja skola i nije mi neki budzet )
2x36vac 75VA for mono 150VA for stereo.
Willy please correct 10uF polarity on this pcb also 25mm diametar caps will be nice
Ok here's the corrected 10uF polarity ver.1.6 using 25mm caps.
Hi All,
Here is my pcb version on AX6 amplifier circuit with TO246 package power transistors.
https://www.dropbox.com/s/kz2m72offvtio1g/Board_TO246.GIF
PCB for print
https://www.dropbox.com/s/plh3ma156q8g0ug/AX6%20rev_1_6_TO246_PCB_PRINT.pdf
Schematic and Simulation
https://www.dropbox.com/s/f4c109ep479b6aw/sch1.png
https://www.dropbox.com/s/suvoupxhxv0yqtf/sch2.png
https://www.dropbox.com/s/szavhehgng9uhxh/sch3.png
The trimmers on bias and offset are these - https://www.dropbox.com/s/fk05m8ruosaaq9w/SH655MCL _trimers.pdf or Bourns
BR,
Lyubo
PCB for print
BR,
Lyubo
- Retro Amp 50W Single Supply
