Hi Willy,
Can you send me the corrected copy including the PCB. I have 2 pairs of MJ15024 & MJ15025.
Thanks.
Rey
Hi Rey,
Here it is.....
AX11 or Studio Reference series?
Hi Mile,
I was wondering about the difference between your AX11 in this thread and the studio reference series amplifiers. Other than power differences, is there an acoustic advantage of one over the other (in your opinion)?
Could you please also explain what you meant in your post http://www.diyaudio.com/forums/solid-state/173462-studio-reference-amplifier.html#post2313884
Thanks in advance.
Hi Mile,
How would you say the bass was better?Rail voltage for SR200 is +/-75V, I prefer sound of bass from this amplifier topology.
Thanks in advance.
Hi Mile,
Thanks in advance.
Bass is stronger if this is better 🙂
where you connected basis?????AX amplifiers can work in class H, just add this circuit 🙂
Those are the output transistors of the existing circuit. So, basis connections come from the previous section. Maybe he should have drawn those existing parts using dashed lines.
Thanks for your reply. Do you attribute the stronger bass in the SR200 to the output stage simply having more pairs, or is this due to other differences in the topology?
This SR200 topology and AX11 topology have stronger bass.
Hi, Mile!
Do you a have a quasi version of AX-11, with NPN BJT outputs?
Many thanks.
There is no quasi AX11
Hi Rey,
Here it is.....
looks fantastic buddy 😀 that is you right there bro "my opinion, I love it !" 😀
Thank you bro! And Nice to hear from you....
This looks interesting small class H amp Mr. Mile.
Will this stay in the same thread?
FYI work in progress...😉 but will continue tommorow as it's getting late now and have to wake up early tommorow for work.
Have a great weekend to all...
I suggest to use single pair of outputs 2SC5200/2SA1943 no need for two pairs, and step transistors can be TO220 like IRF4905/IRF3205 or IRF540/IRF9540.
You have some about simple classH amp H100 in thread:
http://www.diyaudio.com/forums/solid-state/162081-dc-servo-mosfet-amplifier-6.html
Noted Mr. Mile...
I have drawn F100 but still not posted on the thread and can revise it into class H soon.
apex AX-20 WIth three pair output layout
how it is
how it is
sprint file in ZIP:
- 100W Ultimate Fidelity Amplifier
