100W Ultimate Fidelity Amplifier
Hi Willy,
Can you send me the corrected copy including the PCB. I have 2 pairs of MJ15024 & MJ15025.
Thanks.
Rey
Hi Rey,
Here it is.....
  • APEX AX11-MK2 PCB.pdf
AX11 or Studio Reference series?
Hi Mile,
I was wondering about the difference between your AX11 in this thread and the studio reference series amplifiers. Other than power differences, is there an acoustic advantage of one over the other (in your opinion)?
Could you please also explain what you meant in your post http://www.diyaudio.com/forums/solid-state/173462-studio-reference-amplifier.html#post2313884
Rail voltage for SR200 is +/-75V, I prefer sound of bass from this amplifier topology.
How would you say the bass was better?
Thanks in advance.
Hi Mile,
Thanks in advance.
Bass is stronger if this is better 🙂
AX amplifiers can work in class H, just add this circuit 🙂
This looks interesting small class H amp Mr. Mile.
Will this stay in the same thread?
FYI work in progress...😉 but will continue tommorow as it's getting late now and have to wake up early tommorow for work.
Have a great weekend to all...
I suggest to use single pair of outputs 2SC5200/2SA1943 no need for two pairs, and step transistors can be TO220 like IRF4905/IRF3205 or IRF540/IRF9540.
You have some about simple classH amp H100 in thread:
http://www.diyaudio.com/forums/solid-state/162081-dc-servo-mosfet-amplifier-6.html
