apex audio amps 3 diyers here like them
that´s really good picture! 🙂 good team with same goals!
need help
Greetings all. please help what is wrong with this amp. when dc in connection directly fuse burning?
Thank you so much
Thank you so much
Thank you so much
Check you prower transistor and driver transistor, theres must be short somewhere...
Did you use 10R/10W resistor instead of fuse on both rail or light bulb tester on the first fire up??
Thank you so much
1N4007 wrong polarity.
no am 4 Kediri jatimDRAuns, are you from Solo? I see uns there...
Arif B
I made this amplifier for test my home DIY speakers (two way TL).
T Line for 8 inch driver, size 36x22x80cm
Hi Apex,
AX14 with custom PCB (VBE transistor not mounted yet).
Nice work,
is very fantastic
Greetings to all, thank you very much for the apex audio
Thank you for a very quick response, I already fixed the position of races. and the sound of this amp is very fantastic. . clear, deep bass,1N4007 wrong polarity.
HiThank you for a very quick response, I already fixed the position of races. and the sound of this amp is very fantastic. . clear, deep bass,
Greetings to all, thank you very much.
very good work my friend
i dont have PCB file for this amp
please share the PCB and layout file
Hi
Greetings. mine use this layout
sorry my bad english
- 100W Ultimate Fidelity Amplifier
