My class D amp
HAVE you tried any other core the core that detex audio uses
warm regards
andrew lebon
Hi andrew,
tested with ETD29 @23turns 1mm gap all,
Result EMI little high, LOW and MID best HF good. full volume(1v1 pp signal) MOSFET little HOT(55degree @30min. test)and coil hot @40degree. +/-75V supply full drive down to +/-73V
tested with 157-2 core @52turns
EMI Very low, LF,MID & HF best @full drive no heat coil and MOSFET 30min test.+/-75V supply full drive down to +/-73.6V
MANOJ
Hi andrew,
MANOJ
sir MANOJ, what is the size of the magnetic wire for ETD29. Thanks,
freestyle
Hi All,
Any suggestion for this.
anyone tested like this .it will work or not if i go with HCPL0723???:):)
MANOJ
