F6 Amplifier
Has anyone thought out the value of R1 to keep relative gain at 15db if using IRFP240's? I am prototyping this, but uncertain of a formula that can help.
My apologies if this has been mentioned already. I assume tweaking this and the degeneration resistors will get this working on point. I plan on using for source resistors 1R to start with the 10R Zen Pots.
I believe that R1 is the feedback resistor from output ? If so I'd leave it at 100R as this would still get us close to the orig 15 db gain。if you would like the actual exact formula it's somewhere earlier on this thread - I can look for it.
I set both R13 and R14 at .025 ohms and spent a couple of days listening. I think the soundstage is both wider and deeper than with r13, R14 set to zero.I also appear to have more detail. Don't know if its me thinking I need to hear something different 😉 I am going to set R13 to .0125 , keeping R14 at .025and give a listen. Then I will reverse the two. In my system this resistance range is where I get the most stimulation to my ears. Resistors are 5W wirewounds
Best
Bob
After seeing Tea-Bag's PCB layout, I was inspired to play around with another layout variation. This one is Jensen only and provides some additional options, such as lowered voltages to the drains of the input JFETs.
Face to face (flat to flat) allows them to be zip-tied together for thermal tracking.
sorry I mispoke, thats what I mean, face to face not back to back...doh! 🙄 for the thermal reasons you mention; but also Patrick's little heatsinks have them opposed, but side by side. neither of which can be used with the 2 layouts presented on this page
Patrick's heatsinks have them side by side so a pair of J74 could be used instead of a J109, on the same pad. For good thermal tracking face to face would be the most logical in this project.
