HOLMImpulse: Measuring Frequency & Impulse Response
Hello again,
I double check, and still have same problems. I got about 1m shift in about 30s, making it useless to compare relative phase between driver.
I shall receive soon a better soundcard, I will test again with it and let you know if I got better result.
So,
I receive my new sound card (m-audio fasttrack) and the problem disappear....
on windows 7 I had to use ASIO driver to use it efficiently (I don't understand anything on the way windows 7 work with sound card....). On XP, no need of specific driver
Look like most a build in sound card and cheap USB soundcard have a phase problem between input / output
Thanks for your inputs
So,
I have the same problem when using ministreamer with minidigi and minidsp. With my Maudio soundcard, there is no such problem. Do you think it is the USB (ministreamer) soundcard issue?
anyone have an idea how to fix it?
V1.4.2.0
The FILE/SAVE MEASUREMENT don't save correctly the Distorsion data's @ low frequencies.
Example , the red is a loop-back real-time measurement and the blue is the same measurement but first saved and then loaded.
Here is a loopback measurement of my M-Audio card.
Procedure just as you specified. THD as noise
Yes, there is a tiny bit of difference in some spots, like 0.3dB, but nothing major.
When I set the ASIO driver to 24 bit depth and HOLM to save in 24 bit, the results are even closer.
Maybe it's something in your settings? Maybe the .net framework?
