Post your Solid State pics here
Especially when an amp with that small an output stage could really only make use of one of those transformers. The entire amp and power supply could have easily fit in that one case with heatsinks. :confused:
That was the first amp I made and I realised my mistake immediatly so I used all the parts for 2 stereo power amps for biamping, they both still work perfectly as I said the NCC200 amps dont need a lot of heat sinking so the case with the small heat sinks is still fine.;)
Alan
My 5 channel amp.
Still neatening up some wiring. haven't connected to a speaker yet, but tested each channel with a dummy 8ohm load and some sine waves.
After these pictures added extra wire between the ground terminals on the two power supply caps.
Things are tight in the enclosure.
In short 2 x 500VA toroidals (each for a single voltage rail) delivering +-42V rails using a board that is very close to the ncc200 design.
50ohm slow start for 150ms on each Toroidal. DC protection on each output using upc1237 circuits
What fuse rating does that allow reliable start up every time?
Does that fuse ever blow when the music is turned up to silly "party levels"?
What size of fuse did you finally select?
Haven't decided on a final fuse size. Heck i haven't even soldered the rca wires on yet :p
So far just bench testing. And letting it idle for long times checking the bias.
Currently I have a 7.5 Amp slow blow in it.
The enclosure base and lid is 1.6mm mild steel black powder coated and the face is 4.5mm natural anodized Alu. The faceplate is punched to keep costs low. (around the $100 for the entire case with faceplate if I can convert it to $ directly)
I designed this enclosure (135mm high 420mm wide and 300mm deep) and a few other sizes ( 95mm en 60mm high) for the South African Audio video forums as a group buy.
T7.5A is no protection at all.
That should start a 500VA without a soft start (500VA / 230Vac * 3 ~= 7.5A)
Soft start allows the 3 factor to be reduced to ~1
I would expect a 500VA to soft start on a T2A fuse and you may find that you can start and operate your amplifier with a T1.2A or T1.6A. That's why my first and third questions look similar but are actually asking for different information.
