C/E/X PA Flat to 30 (FT30) PA TH Awesomeness
done
do you use a sound processor? if so i can put the model in akabak to calculate hpf (and eq) what amp(s) are you going to use?
I'm going to use a dbx driverack for crossing over between everything and eq.
For amplification im going to use the Behringer EPQ2000, two of them will drive the 4 subs.
Now that I'm planning everything I want to get started building! Too bad I have to wait anouther 6 or so months
note:not a flat to 30 cab,but flat to 40.
With 4 of them possibly v coupled that will probably come down around 35hz, when i can use horn resp I can see more accurately
with the drive rack your fully flexible 🙂
i wil put it akabak to see where to x-over
if you look at the excursion graph,you see you can eq @ 35 hz without exceeding the limmits.but you maybe need a litle more power
That's why I'm getting it, also the automated functions will be good for people who don't know how to adjust a system
The amps I chose as a balance between price and how much power I actually need. The amp should be maxing out around near power compression for the subs based off of my quick-n-dirty guesstamating.
Btw the tops I plan to make are the bfm DR250's. 4 total.
