MOSFET Amplifier IRFP240/IRFP9240
Hello Mile,
Could you explain working of circuit in post 383 so we can adapt it to other amplifiers? How is the overload/short circuit detected? What current?
Victor
Over current detect circuit give positive DC voltage on PRO out if current is over 1,5A thru outputs (short circuit) or 10A (full power), C13 give time delay for peak current.
hi apex sir,
i pointed 2.2k resistor place.
in hv23 image in that place one diode have, any mistakes?
if u can pls share ur hv25 pdf.
i think the latest pcb is hv350.2 am i correct sir?
if u can, pls share hv350v2 in pdf.
thank u for sharing ur hv23.
HI APEX SIR,
I FINISHED EDITING HV25.
CAN U CHECK THE PARTS ARE CORRECT?
I AM CONFUSE WITH THE TRANSISTORS ,(2N5401,2N5551,BC337,BC327) CAN U MARK THE NUMBERS OF THE TRANSITORS IN THE IMAGE,
WHICH DIODE IS IN THE PROTECTION LINE?
