2N3055 inside - commercial famous amplifier models, quasi complementary power output
RCA 2N3055 - first date of really availability for the industry - which year?
I still search the exact first launched date of RCA's 2N3055.
Under post #33 and post #34 about
http://www.diyaudio.com/forums/parts/167680-vintage-transistors-4.html
you will find some cover pics of vintage RCA semiconductor databooks. Perhaps one of you can identify that book, where the 2N3055 was first mentioned.
In the moment I know only the claim from wiki - the early 1960.
Altec 351C equipped with AL40494 = selected 2N3055; schematic wanted
Altec 351C equipped with AL40494 (selected 2N3055) for the output power stage.
Who knows the year of the introduce of Altec's "351 C" ?
And who knows about it's sound resp. sonic character?
Also schematic wanted.
some URLs and attached photo gallerie also include inside photos (pictures save from ebay Item number 300424476508)
Vintage Altec 351C 50W Amplifier +Peerless Transformers
http://www.greatplainsaudio.com/vintage_altec/351C_amplifier_spec_sheet.pdf
Power stage transistors: AL40494 = selected 2N3055 like follow:
VCEV >90V 1V5 reverse bias, ICEO 1mA maximum at VCE = 50VDC
go to Note 5 page 2 about
http://alteclansingunofficial.nlenet.net/publications/techletters/TL_175A.pdf
Altec 1590E equipped with AL 40494 = selected 2N3055
This 1590 E mono power amp is equipped with a big fat output transformer. It would be very interesting to know how it sounds. Some guys claim, this amp is absolutely the best sounded amplifier from all with a small amount of idle current. This could be right because it's symmetric circuit topology (really true complementary stage instead so called "true complementary" NPN/PNP output power stage) and the according distortion behaviour.
All papers you will get here:
http://alteclansingunofficial.nlenet.net/proelectronics/proamplifiers/index.html
  • Altec 1590E-Schema.pdf
Altec 1593B equipped with AL/D40494 = selected 2N3055
Altec 1593B is a smaller mono amp than the 1590E, but works with same basic topology, i. e. also without so called "true complementary" NPN/PNP output power stage; output transformer seems to be larger than the mains transformer.
Altec 1593B equipped with AL/D40494 = selected 2N3055 - more pics
Altec 1593B equipped with AL/D40494 = selected 2N3055 - II
more pics (high resolution) from new ebay offer - go to Item number: 320550280086
AND AN OFFER FROM 1593A: go to pdf attachement
  • Altec 1593A.pdf
    Altec 1593A.pdf
Altec 1594A and 1594C - latest of 159xx series equipped with Successor of 2N3055
It seems to be, that Motorola's 2N5878 was by Motorola a successor of the 2N3055 (80V/10A/150W/4MHz vs. 60V/15A/115W/2,5MHz)
The circuit topology is basicly the same than bevor (see previous posts), i. e. not OTL.
  • Altec 1594C Schema 2N5878.pdf
Harman Kardon Power Amp Citation Twelve (Citation 12)
Harman Kardon power amp Citation Twelve (Citation 12) and Citation Twelve DeLuxe uses RCA's 40636 (= selected 2N3055 with higher value for Vceo) in their quasi complelentary output buffer stage. Harman's factory number therefore is follow: "HK 43024216"
There are a lot of informations like service manual, e. g.
http://manuals.harman.com/hk/Service Manual/CITATION TWELVE sm.pdf
if only low speed web access available try this URL:
Powered by Google Text & Tabellen
because the explicite written article from Mr. Nelson Pass about
http://www.passdiy.com/pdf/citation.pdf
this could be one of the most popular push pull solid state amplifier for diy
about
http://www.ibiblio.org/pub/academic/agriculture/agronomy/ham/RADIO+PHONO/20060518.pho
I read follow regarded replacements for transistors with Harman's factory number:
43024216 = 40636 RCA (2N3055, BDY20)
43024218 = 40594 RCA (2N5320, BSS42)
43023221 = 2N5232 (2N5210 BC184L)
Harman Kardon Quadro Receiver HK-150 (HK150, Model 150)
This quadro receiver model uses the same silicon power devices than the Citation Twelve (based on the 2N3055): the "HK 43024216"
The attached pics I have found by use "HK 43024216" as keyword by google.
http://manuals.harman.com/hk/Service Manual/150+ sm.pdf
if there is low speed web access available try this URL:
On the web (by Google) are only vew links about this receiver, therefore I think, it's a rare model.
I haven't read through the whole thread, so please baer with me if I missed something. Do original RCA 2n3055 have some sort of date code on them? I have one that reads:
"2N3055
RCA
RG 563"
Was it possibly made in May 1963?
Good Question. The only way to find out this is checking all databooks and application notes from RCA arround 1963 (between 1960 and 1970). I have heard also from RCA cross ref. lists 40xxx - 2Nxxxx.
By post #33 and #34 about
http://www.diyaudio.com/forums/parts/167680-vintage-transistors.html
there are some cover pics from several (unfortunately not all) data books.
Siemens Klangmeister RV-90
This RV-90 amp from Siemens was released 1967 and is after recapping a very good sounded integrated amp
Südfunk (Quelle Universum) "V 716" (V716) Schematic needed
I need a schematic of follow integrated amp with quasi complementary output stage (2x2N3055/ch) and high pass couple capacitor (4.700uF/25V WIMA) between buffer out and speaker terminal:
Model No "V716" (V 716)
the manufacturer was Südfunk-Apparatebau Dr. Ing. Robert Ott
the device from me is branded with "Südfunk" (silver front panel)
the devices from the attached images are branded with "Universum" (special made for the German biggest mail order house at those days, - "QUELLE") That design was in black for the front panel.
There are only German informations on the web:
http://www.spickelmir.de/joomla/ind...gallery&func=viewcategory&catid=655&Itemid=82
http://cgi.ebay.de/HIFI-Stereo-Anlage-historisch-Suedfunk-Universum-/190477709658
http://new-hifi-classic.de/forum/index.php?topic=2102.0
Who can post a schematic ??
Who can post the first commercial advertisement (announcement) from formerly's brand RCA (from any electronic magazine published in the early sixties) concerning the 2N3055 and the first RCA application notes?
At which time was exactly launched the production?
I note, that the German brand Siemens launched the same type under the type number "BD130" in the seventies - unfortunately I don't find original datasheet online:
BD130 datasheet pdf datenblatt - Comset Semiconductor - NPN SILICON TRANSISTOR POWER LINERAR AND SWITCHING APPLICATIONS ::: ALLDATASHEET :::
First commercial advertisement from RCA still wanted.
Who can help?
let's not forget the Acoustic Controls 370 bass amp..... the "house numbered" transistors are actually 3055s. only one problem with this amp... if the outputs blew the amp was done. no amount of rebuilding would fix it.
