DIY progress report
Well, it's not like I don't have one...
No, the copper we see makes Circlotron sense. There is some skinny traces going off to the left that would only be an LED thingy. And, no big holes for pwr supply connections or speaker outputs... But, the "Ref1", "Ref2" and "Bias" is an important area I have not suceeded in developing enough stability in output offset. I think that is the biggest area to conquer. But, Biasing the 2 halfs into a semetrical complamentary/balanced behaviour is also important.
I wonder though? Is it posible to apply susy to these things???
Recently, a member of an another forum (froggy) ebayed some mosfets (IRf 240 and 9240) in order to build an UGS UP (Cheff de Gaar).
According to the seller they were matched Vth and Ids at this point (around 1 - 2mA for the most), with a so called Fet analyzer ...
Anyway, surprisingly it appeared that the fets offer not a bad match also at 100mA bias (measured in situ) .
Is it just chance? or is there a correlation between those Vth numbers and matching at any bias current ...
Manu
