The Very Best Amplifier I Have Ever Heard!!!!
Goldmund Mimesis 3 also has 2 buttons on the front panel. You have to press them both at the same time for the amplifier to turn on....
After one presses both buttons, it takes almost 3 minutes before the amplifier actually turns on....
The turn on circuit has more parts than the entire schematic for the amplifier itself!
Did they outsource the design of the on-off switch to Microsoft?
Some interesting snippets taken from the Goldmund technical notes
TRANSISTOR SELECTION
Transistors have been selected for their minimum sonic thumbprint. The double inverted symmetrical topology makes the negative and positive part of the signal travel in the same type of transistors to symmetrize the non-linearity of these transitors.
The low coloration allows multiplication of this same kind of stage without the typical sound alteration.
The total symmetry and use of inverted transistors in each signal path provides high insensitivity to transistor matching. Replacement of a transistor doesn't effect the balance of the design nor the sound quality.
A single adjustment for each stage compensates for DC offset differences between modules so that a quick DC tuning is the only adjustment needed after a transistor or input module replacement.
The question has been asked multiple times in this thread about transistor matching, and it seem the design has engineered this factor out.
EXTEME SPEED
The very high speed of the amplification stage allows the design to be made with negligible frequency tuning. Without phase correction the stage displays perfect (0 degrees) phase response in the audio bandwidth. Thus the linearity can be made perfect and the stability of the whole design is maintained with ease and without the strong frequency limitations usually adopted (very detrimental for sound quality)
POWER SUPPLY REJECTION
The schematics used provide rejection of power supply imperfection of nearly 100dB. The typical induced power supply noise is thus not perceptible. Since the schematic is also very symmetrical, even an unstabilized power supply can be used, and the typical high frequency noise of regulators can be avoided.
No wonder your previous breadboard clones were not blowing up Nagys 😉
THERMAL STABILITY
To insure a very low DC offset, and keep this offset very constant, the input circuitry of the amplification stage is potted. This technique allows the temperature difference between input transistors to be kept very small. More, due to the very symmetrical topology, the temperature changes have very limited effect on this offset.
This explains why the best MIMESIS products are fully DC coupled without the usual impractical limitations inherent in this kind of design, and without the sonically imperfect DC servo-loop usually encountered in transistor design. This is one important contribution to the famous "liquid" sound and very clean bass reponse of the MIMESIS line.
SHORT PROPAGATION DELAY
The propagation delay of the stage, typically less than 80ns, allows negative feedback to be tailored without significant TIM induced distortion. Depending on the position of the stage in the amplification line, this capability allows the designer to use a needed amount of negative feedback without detrimental sonic effects. The stability and low inherent distortion contributes to free the choice of extremely low or moderate values without significant sonic differences, and allow a perfect purity of the signal.
The transformer should have dual secondary windings of 60VAC in parallel, or 120VAC in series.
You can certainly use just a single transformer for each channel. If you take the voltages after the bridge, you'll have +/- 85VDC (formula: 60X1.414=84.84) to feed the outputs, which is perfect. Then just feed the input stages with 60VAC that you can take before the bridge.
Thanks Mosfets
Specs state the following
Max power is 400W rms into 3Ohm load.
Max Voltage swing 60V peak
Max Current swing 40A peak
Maximum power consumption 1000W
60V x 40A = 2400W peak or 1200W average.
This suggests they use a transformer rated at somewhere between 1000VA and 2000VA.
Most likely 1000VA based on the last spec. However I wouldn't be surprised if they used a 1500Va (1.5kVA) transformer per channel (or two 750VA transformers per channel).
Thanks for the link. An interesting observation is that the Japanese guy who made the original chip amp also used low value reservoir caps and the sound was claimed to be stunning. I never heard one but so the reports say.
But if one look at it closely small capacitors discharge quickly and the amp gain compresses at high volume levels (peaks) in that it sounds louder because the average power increases which could be perceived by a listener as being more dynamic. Could this be partly responsible for their characteristic sound apart from all the mechanical stuff. It is more or less in contrast what most DIYers do, bigger reservoir caps are better, punchier fuller bass etc.
I have been a member here for a few years and notice that we strive to be technically correct maybe musically we miss the boat or maybe it is a case of different strokes for different folks.
This is only an observation from what I read in the pamphlet.
I cannot confirm how powerful Goldmund's transformers are because I don't own the Mimesis 9.2, nor do I have access to one. And even if I did, the transformers are completely potted so I wouldn't be able to look.
Any suggestion that Goldmund Mimesis 9.2 uses, or that this amp needs transformers in the 1000+VA range, is completely ridiculous.
For Mimesis 6, Goldmund used approximately 300VA (5"X2") transformers per channel. That amp has a max power rating of 200 watts at 3 ohms. Perfectly falls in line with this simple basic formula: 200 X 1.414 = 283 watts.
Here's a picture that shows the tops of the transformers:
For Mimesis 3, Goldmund used two transformers per channel. They are very small (3.5"X1.5"), therefore I'm guessing they are 150VA each. Mimesis 3 also has a max power rating of 200 watts at 3 ohms. Which again corresponds with this basic simple formula: (150 + 150) X 1.414 = 283 watts.
I conclude with certainty, that Goldmund Mimesis 9.2 uses two 300VA transformers per channel, totaling 600VA. Mimesis 9.2 has a max power rating of 400 watts at 3 ohms. 400 X 1.414 = 566 watts.
I agree that using good transformers is very important. So may I suggest the Hammond and the Plitron.
Nico Ras - The capacitor size does not make a Goldmund amplifier sound incredible. Simply because Mimesis 9.2 uses 4700uF, Mimesis 6 uses 6800uF, and Mimesis 3 uses 15000uF. They all sound fantastic, but they all have different capacity power supply capacitors. I think the excellent quality of sound is due to the circuit and the construction.
Nagys,
It still baffles me.......where does 1.414 come from, which text book is this from? I must have missed something in engineering school is it related to two divided by the square root of two?
Usually when desingning you calculate for worst case load and add a margin for losses and account temperature rise and regulation.
Judging from what you are telling us, the Goldmund power supply is extremely "spongy" and I assume would produce a fair amount of lower harmonic distortion under high drive conditions maybe this is the magic Goldmund sound.😕
My tests found the amp lacking into low impedance loads granted I have a preference for electostats and ribbons so it is nowhere near a Pass Labs or Krell in that regard. I have to say Goldmund is very vague in stating their specs. I would like to know for instance power into eight ohms and the power into four ohms or two ohms (if possible) to gauge the current dilivery of the amp.
Jam
I think there is no contrast or disagreement there. Bigger reservoir caps do bring punchier fuller bass etc. But to consider "better", you have to wait. We know that bigger caps have limitation. At least the high impedance issue.
One reason why I don't like bigger amp is because then I have to use bigger cap while power supply along with the caps is very critical. It is very expensive to have a high quality caps in thousands of uF. If you use "cheap" cap, then you will have the problem.
It is not uncommon that people parallel caps with smaller one, and use the highest quality for the smaller ones (look at those yellow caps in Mimesis85?). And many others parallel small caps to achieve bigger capacitance. I think 20000uF generic caps just don't work well with high frequency? You (and of course salas) know better what might be the issue.
Sounds realistic.
Lateral MOSFETs sound better with lower value source resistors, and best without them.
But using no source resistors carries the risk of blowing the outputs, one way to mitigate that problem is a powersupply that runs out of oompf for suspended periods in a low impedance load.
Long enough for the protection circuit, cq thermal switch on the heatsink, to cut in.
Basic rule for that overhere in the '80s-'90s was sizing the transformer smaller or at max equal to total Pd of the output devices.
Also in-line with the mains fuse value, 5A slow at 220Vac is 1100VA, fat chance the total transformer VA was way more than half that value.
had a little spare time, and played a little more with what I suggested
but a small area that probably makes no difference at all
IMHO, this project would require a MAX 500VA XFMR per channel(and that is too much) but who cares anyway. Strap a couple 2000VA's down and get yer freak on. To each is own.
300VA to 400VA per channel would deliver the goods.
Now if somebody would proto these Goldmund board(s) and run it through some paces...then you may end up with another "Krell KSA50 Clone" type thread...but who ever did finish THOSE K50 builds anyway?
He he...wink wink ...
Carry on as ye were...
