Complete Novice Needs Help
better !
So, how's it going?
Russellc
Cheers Russell,
much better .... I have found a laser company to do all my cutting of the enclosure for a very good price . All stainless steel .... Just stuff I have left over from old projects.
Ordered the extra parts I needed today ...
I'm preparing the heat sinks ready for the fets
Studying layouts and reading really basic stuff ... Things are still pretty vague - things like DC offset and linearity .
I guess I'm out of my comfort zone thats for sure 🙂
Started looking at my next project .... DAC from a Eval kit .
Rich
I'm very sorry to all, I did not know that the PCB boards I'm using are none sanctioned
copies . This is my first project so I'll continue with them and remove the "Pass'' as Mr Pass suggested in the F5 thread I was just reading . I will not use them again .
SORRY ALL !
Cheers doggy !
I'm hoping that my next project will be built on the kosher board. Now I'm a member here I may be privy to the whereabouts of said boards 🙂
I'm an artist by profession and the notion of copyright is something I take quite seriously ..
Thanks for the heads up on the silpads.
Rich
kosher PCBs for power?
Where is a good place to buy power supply PCBs for power amps, I'm assembling parts for a BA-2 and would like to implement the rectifier - CRC filter arrangement shown in the original amplifier description. I've gathered that red is for danger 🙂
Thanks Dennis
I bought a chip amp kit from there and the quality is excellent. The layout is a bit different though, basically
bridge - big cap - load
whereas the one sketched in the BA-2 goes
bridge - big cap - resistor - big cap - load.
I'd like to stick close to the original paper, do you anyone who sells those?
Steve
Buy a secondhand analogue oscilloscope. Dual trace or dual beam, >=20MHz
Any software scope attachment for a computer is effectively a sampling oscilloscope and a very slow one at that.
You will be wasting your time trying to get good results from equipment that is incapable of performing well.
Internal Layout ?
Hi folks,
I'm looking for suggestions on the internal layout of the amp .
I thought this might be ok . Bearing in mind the objective being as much distance as possible between power and audio signal ....
Please advise .
I'm off to laser cutters tomorrow so I would love to get panel dims confirmed asap .
thanks, not a novice anymore , just a funny colour green
Rich
It's hard to get a sense of the layout size, what are your heatsink dimensions? Just at a glance it looks to be fine.
I hope you have flattened and polished the heatsink areas where the fets are mounted, it is quite important. A fine mill file will reveal how unflat they really are.
Don't forget to include some venting in your top and bottom panels.
Lookin good!
