DAC-ASH (dac-end 2 up date)
My friend make DAC-ASH, please see it! Thanks
R-Core and Center Tap
The R-Core from diyclub is:
R26-29 primary 115 X 2 : 0-9 X 3(0.7A); 9-0-9(0.7A)
It has 3 9V, 0.7A output and a 9V with center tap. I can get two of these for the DAC-End. What's the "center tap" for? How should I connect them? I saw nothing on the Dac-End board for "center tap".
Quanghao,
Thanks a lot! The link to heatsink is for trimmer. 😀
Some comment in Mouser Electronics - Electronic Component Distributor
1. Inductors 120uH
RLB0812-102KL Bourns Power Inductors
http://www.bourns.com/data/global/pdfs/rlb.pdf
2. Trimmer Resistors 1K
M64W102KB40 Vishay/Spectrol Trimmer Resistors - Multi Turn
3. Heatsinks for IRF9540 + 540
4. Tranromer for DAC + IV stage
DIYCLUB
R26-93 primary 115 X 2 : 0-9 (1A) X 2; 0-9 (2A)
DIYCLUB
R26-28 primary 115 X 2 : 0-12(0.85A) X 2; 0-9(0.85A) X 2
Quanghao,
1. Inductors 120uH
581002B02500G Aavid Thermalloy Heatsinks
4. Transformer for DAC + IV stage
DIYCLUB
DIYCLUB
Hi All,
The five pieces of the Salas multi 9v transformer are out of corrosion control and can be shipped. Please PM me with current address to ship to and I will finalize ship amounts , provide you with a total an a Pay Pal edress to use. The two international units will ship USPS flat rate.
Bud
Hi All,
Bud
Hi Bud,
don´t know if you just make one for me, I´m still waiting for the answer about the trafo for IV stage and also the trafo for the Phono-pre of Quang Hao.
Klaus
