100W Ultimate Fidelity Amplifier
Nx14v2 pcb
This pcb for NX14V2 is fixed on heatsink, and you soldering outputs on coper side of pcb. Montage outputs is much easy this way.
APEX AX-14 (modifications)!?
Hello Mickey!
I want to develop this amplifier Apex AX-14. I want to ask one question:
What changes should I do when I have the amplifier power of Us = + /-38V and the output thereof I want to turn the speakers with an impedance of 4 ohms??:confused::rolleyes:
Thank you in advance!
RE... NX-14 Completed
Hi Apex,
Still no luck with my NX14. Looks like I have to assemble the second channel.:(:(:( Anyway I see there is a difference between the two boards(NX14 V1 and NX14V2). I see two 100R resistors on the layout but not on the schematic. See attachment. The 22uF 63V cap on the schematic is replaced with a 2.2uF cap on board.....is this okey......
Macd:confused::confused::confused:
Hi Apex,
Two 100R resistor in series I use instead one 220R, 2,2uF is OK.
Do you measure voltages as I suggest?
