Quite interestingly, the simulations I have performed do not show a firm trend in this regard. The important thing just seems related with how to control the expansion process to minimize reflections.Hello,
Inversely to the common knowledge waveguide don't have less HOMs than horns. What an OSwaveguide do better than horns is that it uses the HOMs in order to reflect them in various directions in order to obtain a more evenly distributed directivity.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Hello Rob,
Here are the relevant messages :
Earl's measurement on his OS waveguide
Waveguide_00 (it appeared that Fs = 32kHz and there was some noise)
http://www.diyaudio.com/forums/multi-way/123426-horn-vs-waveguide-10.html#post1516725
Earl's measurement on a JBL waveguide (which reference?)
http://www.diyaudio.com/forums/multi-way/123426-horn-vs-waveguide-10.html#post1516728
Earl's new measurement on the same OS waveguide
http://www.diyaudio.com/forums/multi-way/123426-horn-vs-waveguide-13.html#post1517241
validation by Earl Geddes of that new measurement:
http://www.diyaudio.com/forums/multi-way/123426-horn-vs-waveguide-17.html#post1518269
"the waveguide low noise is definately what I expect."
My measurements on one of my Le Cléac'h horns:
Le Cléac'h horn with curent driven TD2001
http://www.diyaudio.com/forums/multi-way/123426-horn-vs-waveguide-52.html#post1527765
Le Cléac'h horn with voltage driven TD2001
http://www.diyaudio.com/forums/multi-way/123426-horn-vs-waveguide-53.html#post1528568
I didn't know there was a second measurement and I stand corrected.
Hello Panomaniac,
You can find in the attached file 2 graphs obtained using my Matlab quasi-wavelets routine on the impulse response of the Pioneer horn you gave. One is with the normalized response, the other one for the not-normalized response.
Which Pioneer horn is this (TH4001?)
I'd like to see a wavelet or good CSD of the Pioneer horn, but I"m having a devil of a time. Can anyone help? Impulse is attached below.
And here is the FR graph. Remarkable for a horn. 2nd harmonic rises sharply below 750Hz (not shown here).
If someone can run a graph on this and tell me what your setting were, that would be great. Thnx
Context will remind you -- Earl was comparing EconoWave to his product. The "JBL horn" was the $9.90 90° x 50° thread-on progressive transition waveguide 338800-001 driven with a $40 Selenium D220Ti compression driver.What JBL waveguide is that??
As to the issue of noise, Earl provided a relatively noise-free impulse he had taken on his waveguide elsewhere. It should be easy enough to compare wavelets from the two OS impulse samples he attached in that thread.
You can see me request that the noise be removed from the JBL impulse for comparison, but that did not happen.
CLIO wavelet upgrade is here, but not yet installed. It'll take me some time to crawl up the learning curve, probably; see Chapter 18 of the CLIO 8.5 User Manual for the capabilities:
http://www.audiomatica.com/clio10/download10.htm
Hello Soongsc,
Don't misinterpret what I wrote, I did'nt say that the most part of the control of the directivity of a waveguide is due to HOMs.
But surely they play their part in filling the holes in the radiation pattern....
Here's the post for JBL and OS comparisons:
post #323
http://www.diyaudio.com/forums/multi-way/161627-horn-honk-wanted-7.html#post2124412
Yes there is a large amount of reflections/diffractions before 1ms in OS seen here also in this plot 4kHz-20kHz:
Mouth reflections are different phenomena than the above but they do exist in OS
- Elias
post #323
- Elias
Hello,
You'll see in attached file a comparison I have done using my Matlab routine (quasiwavelets) between a Le Cléac'h horn (Fc = 320Hz) a JBL waveguide and an OSwaveguide. I modified somewhat my routine in order that the shown graphs are normalized in amplitude.
Elias yet gave some multiresolution wavelets graphs for those horns and waveguides in the message:
http://www.diyaudio.com/forums/multi-way/161627-horn-honk-wanted-33.html
The vertical stripes having an yellow-orange color you can see on the graphs for the JBL and the OS_waveguide appear within the interval of time between 0 and 1ms. This means that there are due to reflexions having a short delay( by that I mean that the correspodning delay is smaller than the delay due to the reflection between mouth and throat.)
IMHO a large part of those short delay reflections are HOMs.
To confirm or not those yellow-orange stripes are du to HOMs we should analyse with the same method the impulse response at different off-axis angles.
Hello,
I agree with Jean-Michel, there is no noise issues with those IR files that would prevent wavelet analysis. Inherently built in feature of wavelet analysis is its noise rejection ability due to its band pass filtering nature.
See post #323 in this thread to see the noise level of JBL and OS files. See before the beginning of the wavelet above 1kHz, and you'll see the noise is below -35...-40dB in the normalised plots (right hand side). And then compare the plots showing the temporal reflections/diffractions and you'll see they are much higher in amplitude thus having nothing to do with noise.
Even if the noise would be at higher level, one could still see the temporal sequence of reflections because they do not correlate with random noise.
- Elias
- Elias
There was a noise issue when Earl made those measurements. That could easily be a reason for all the clutter in the first milisecond.
There is no noise issue there.
Hello,
This is a very interesting statement Jean-Michel!
If some of the pre 1ms reflections are due to HOM, how the reflection pattern should behave versus direction angle?
Any volunteers to do a set of IR measurements versus angle of some horns?
I can measure 18sound small horn later for this purpose, thats all that I have at the moment. I do have IR files at different angles already but didn't analyse them this wise.
- Elias
- Elias
Here we go
"wash prove" CD horn - EV ST350 - outdoor measurement 1m mic distance (not any perfect but might do for a starter):
You remember mighty Sentry III ?
Not mine though, nor what's been measured here !!!
on axis 0deg :
http://www.kinotechnik.edis.at/pages/diyaudio/GD_HighPass/EV_ST350/ST350_deg+0.wav
10deg :
http://www.kinotechnik.edis.at/pages/diyaudio/GD_HighPass/EV_ST350/ST350_deg+10.wav
20deg :
http://www.kinotechnik.edis.at/pages/diyaudio/GD_HighPass/EV_ST350/ST350_deg+20.wav
30deg :
http://www.kinotechnik.edis.at/pages/diyaudio/GD_HighPass/EV_ST350/ST350_deg+30.wav
40deg :
http://www.kinotechnik.edis.at/pages/diyaudio/GD_HighPass/EV_ST350/ST350_deg+40.wav
50deg :
http://www.kinotechnik.edis.at/pages/diyaudio/GD_HighPass/EV_ST350/ST350_deg+50.wav
60deg :
http://www.kinotechnik.edis.at/pages/diyaudio/GD_HighPass/EV_ST350/ST350_deg+60.wav
another little honker - I'd say...
on axis 0deg :
10deg :
20deg :
30deg :
40deg :
50deg :
60deg :
I can supply 5deg step for JMLC and Minphase and 10deg step for OSWG. Here is 0deg and 90deg in blue plus noise floor in red.
Yes please !
Michael
Download area
Keep us updated please - I'm curious how it compares...
Michael
Same driver?
Same driver?I can supply 5deg step for JMLC and Minphase and 10deg step for OSWG. Here is 0deg and 90deg in blue plus noise floor in red.
Different drivers: 2" STX-D1300-Ti for JMLC-60 (350Hz) and Minphase (500Hz), 1" STX D800-Ti for OSWG 12".
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Somehow I got pretty funny results, Elias and Jean-Michel could you please verify ?
I don't think thats any representative !?
Jzagaja's measurement of oblate spheroid contour (on axis):
Jzagaja's measurement of LeCleach contour (on axis):
Jzagaja's measurement of Gaussian MinPhase contour (on axis):
Michael
Michael
Thanks Jean Michel! I was having a hard time with that.
It looks better in FR and distortion than it does in the wavelet.
The only markings are on the drivers. PM-40-1
Horn is bent 90 degs about 70mm from the driver. Small throat, only 16mm
Horn mouth is 31.5mm wide x 14.5 tall.
Driver has the female thread, not the horn.
Michael,
It seems that you haven't gated ghost impulse response. Ghosts could happen with MLS stimuli.
...might be – but leave those "time machine ghost pattern" aside and have a look at my worst piece of honker (0 deg horn with no round over = quarter wave tube of 20cm length) there:
http://www.diyaudio.com/forums/multi-way/161627-horn-honk-wanted-8.html#post2128416
There should be no horn performing any worse as above !?
The OS wavelets here
http://www.diyaudio.com/forums/multi-way/161627-horn-honk-wanted-7.html#post2125170
and here
http://www.diyaudio.com/forums/multi-way/161627-horn-honk-wanted-7.html#post2125178
do not show such extended reflections, especially in the upper frequency range - as seen in your measurements - either....
Michael
- Horn Honk $$ WANTED $$
