ImPasse Preamplifier
I searched for the original Maida paper with no luck. When you refer to the set resisters are these R5 and R6? I seem to have 385V going into U2 and 270V out of it. How would I determine if it is starved? I am loading the output with 12k 5W resisters. I will check for oscillation when I get home.
guys
The Maida paper is LB-47 "High Voltage Adjustable Power Supplies" -- where LB stands for Linear Brief. The reference voltage for the temperature compensated regulator is the sum of the internal reference plus the temp compensating diode.
guys
R108 and R109 set the regulator voltage. R109 should have 1.25 v across it (careful when measuring, the voltage above ground is quite high!). R105 could also be made slightly smaller if your pass transistor is a bit low in the beta department. If all else checks out, try 10-15k in that position.
Ok, its is always the simple things R5 turned out to be an impostor. Got that straitened out no Oscillation output is steady 348V DC. Now just waiting for chassis to show up.
Thanks for your help guys.
Bill
Having problems always gives a better understanding, basically the pass transistor puts the voltage within a range the regulator can handle. R109 fine tunes the regulator to the desired voltage by trying to maintain a 1.25V differential and the current demand is what requires fine tuning these resistances?
Bill
Bill
Sorta. The regulator tries to maintain 1.25V across R109. To a reasonable approximation, the current into the ADJ pin is zero, so the current through R108 is equal to the current through R109. Using Ohm's Law, I = V/R = 1.25/R109. So the voltage across R108 = IR = (1.25/R109)(R108). The output voltage is the R108 voltage plus the (negligible in this context) 1.25V across R109.
The base of the pass transistor is held at 12V over the output voltage by use of the Zener diode. So the emitter voltage is 12 - 0.7V (the Vbe drop) = 11.3V above the regultaor's output. The regulator chip is then happy, because it's got anough voltage headroom to operate, but is protected from seeing an excessively high input to output voltage.
Bill
Most of the voltage dropping is done by the 1K and 470 ohm resistors in the pi-network. You can work with the value of the resistor supplying the base drive (R5 in the illustration) to increase the amount of current drawn, and the current flowing across Q1. Too low a value of R5 and the regulator just won't supply enough gas. The LM317 needs a bit of current to cook properly.
I have the LM317 and TIP50 heatsinked on a piece of aluminum flashing -- of course with Bergquist insulators, silicone grease etc.
Jack, perhaps you could look real quick at the attached SPICE circuit. The reference designators align to those in LB-47. I'm using a single pass MOSFET. R3 had to be dropped significantly, but will be a 1/8W resistor, so it should still protect against over current. The RSET resistors should run much cooler.
Replace the 1N4733 with a 1N4739... (BV=9.1) should work then.
Jack,
Nice drawing, played around and checked my voltages they are where they should be.The R5 I had in there was significantly higher I noticed the pass transistor running much hotter than it is now, I will add some heat sinking any way. Case showed up today 12" X 12" X 3-3/4", a little tighter than I had imagined but doable. Any recommendations on signal grounding not sure what to do with transformer coupled inputs, I will use the ground loop breaker from amp ground to case/earth ground.
Bill
I mounted the power supply and amp their new home and powered it up, the neons glowed for a second and died down but no leds. Then I noticed no filaments in the 6SN7. Power it down and checked and cold solder joint re-soldered and and powered it up and everything lit up. Would have put some inputs and outputs on it and tested but no molex plugs to be found. Decided to ditch the molex plugs and solder silver wire for internal wiring (it deserves it) so had to ordered some wire. In the mean time a pair of Martin Login Electrostats followed me home today listening to some Buddy Guy - the grin on my face is starting to hurt.
Bill
