Phillips CDM4 v1 CD mechanism for sale or trade
Hello
I have a Phillips CDM4 v1 CD mechanism, was named CD1 , it was working few years ago, but I can not ensure that it still work since I do not have the cd player anymore
It s come from a Rotel RCD 855 , but I did keep the CD mechanism only
Make an offer, money or do trade for something you have
You pay the shipping
For Canada only
Bye
Gaetan
need advice on upsizing driver heatsink
I have an ESP Project 36 that I've transplanted into a Hafler P225 chassis.
The original build article from years ago specified to use a 1"x2" piece of aluminum as a heat sink for the driver transistors.
I've found that this heat sink reaches 70C when the lid, up from 50-55C with the lid off. This seems a little high and I'd like to reduce the temp with a larger heatsink but I'm not sure how much larger or if I should use thicker material as well.
For example I replaced that 2" wide piece with 1" angle aluminum, essentially doubling the surface area and quadrupling the volume (1/16" v 1/8" thick), could I expect a significant temperature decrease or does it look like air flow is going to hold it back? There are vent holes above it but no vent holes in the bottom of the chassis.
I realize that there are many heatsink calculators out there but most require more parameter input than I can provided. Just looking for a nudge in the right direction.
How much power are you guys feeding your front 2 speakers?
Hey guys, I've been thinking about my next setup. Up until now I have always ran a Decent Denon or Marantz Receiver to power all my speakers. But I'm wondering if I will get BETTER performance with a better amp??
How much power does a decent Home theater Receiver really put out to the front channels??
Is it worth upgrading to a good DSP and Amp with some real power???
part of me really wants to build some MASSIVE output front channel speakers for the movie room. Whata you guys think?? 🙂
6V6 PP Design Help
So I'm planning a 6V6 build for my parents for Christmas, but am having the most difficult time deciding on driverphase splitter. The amp will be used with a pair of small bookshelf speakers (NHT). The power transformer is from an old Motorola Console that ran PP EL84 (280-0-280) and a preamp section. The output transformers are Tamiko 5k 4/8/16 30w with UL taps. Amp must be autobias and have enough gain to be used as a integrated amp. They will more than likely use a cell phone (spotify) as the source. I was originally looking at the Dynaco/Acrosound schematic with 6SL7 as driver phase splitter, but not sure about the gain/drive capability. I would like to regulate the screens with VR tubes, but don't think I have enough voltage. Any suggestions?
Moth 'Flutterbuster' TT psu
Hello folks,
I'm new here. I have a moth flutterbuster tt psu. It is not working at the moment. Everytime I power the unit up , it blows the internal fuse (600mA). There is a 47R wirewound resistor in the circuit , just infront of the Fuse, i believe that this is now open circuit and there fore it has probably burnt out. I would like to try and get the unit back up and running, even if that means putting it into a repair shop.
Do any of you guys have any experience of this unit and also does anybody have any literature, eg Circuit schematic or just a user manual that they could get to me.
Even if this does not help me it will assist the fixer in the reapir shop.
The unit has a 240v 50Hz input and a 200 - 230v output at either 50 or 67.5 Hz , depending on the toggle switch position. It designed to power a TT with a 'Basik' type PSU and a AC syncronous motor , eg Systemdek iiX , Thorens, Linn LP12 etc.
I have taken some pictures of the unit and you can see them here. it looks like quite a simple unit with a fairly low parts count. It is a few years old now though so i don't know how many of the components are still available, or even what some of them are. If any body could assist and would like to play 'spot the component' i would appreciate it, I have filled in the blanks that I think i know .
1) 47R wirewound ceramic resistor (open circuit !)
2) Fuse 600mA ( in series with #1 from live supply)
3) ??? has 4 legs and W08G9102 written on it
4) Diodes (IN4002)
5) Transistor (TIP49 )
6) Polystyrene/foil Capaicitor ????
7) Transistor ( TIP 50 )
8) OP AMP ?? LN324N
9) Trimming Capacitor ??
10) Transistors ?? ( BC 546 )
11) Capacitor
12) Capacitor
13) Diode ??? ( PH 12 ?? )
14) IC ?? ( M706B1 )
15) Crystal Oscilators
16) Green LED
17) Toggle switch
As you may have gathered , I am a keen Hi-Fi enthusiast with a basic knowledge of Electrics, electronic circuits are not one of my strong points but i am working on improving that knowledge. Im probably won't try to fix this myself , however it would be good to know a little bit about the circuit, for when i take it to the repair shop. Any help greatly appreciated.
Here's the Pic:
Circuit board picture
S&C
Tube stash, some really nice ones, for trade
Hi all. Came across this lot from a gentleman who passed away. I've tested almost half of them and they all test far above minimum so I'm guessing this was just his replacement stash. The 101f I cannot test, but I'm assuming it's fine just like the rest because it measures 4.2 ohms and looks brand new. Anyhow, you can see from pics, and I'd be happy to test every last one if someone wants. I've got a few DHT of my own to play with, and I'm looking to build a few SE amps amongst other things. Stuff that would interest me in trade is basically SE OPTs, interstage transformers, and possibly transmitting triodes, but really I'm looking for any iron.
Edit: I should also mention I am absolutely willing to make up the difference in $ on my end.
Here's the list of tubes pictured:
Western electric 101f globe
Uy227x2
27x5
56
24ax4
811a
43
75
6n6gx2
2a5
6y6g
26x4
Cx326
6sl7x2
80X4
6l6g
6sn7x8
76x7
6j5gx3
6l6ga
And Iron, if I had my choice though I'm open to any SE iron, would be outputs for 300b or GM70 (2.5-3.5k and 9-10k), and interstages for driver for the GM70.
Thanks all, have a great day!
Loren
Pet Peeve - Gym Music
Pet peeve: public gyms that play music way too loud. It's normally high energy thump thump music but I'd be annoyed no matter what they played if it interferes with what I'm playing in my headphones.
I cancelled a gym membership for this reason one time. I listen to meditation music when I'm running because it distracts me from feeling fatigue. But they played pop music so loud in the background that it overpowered my noise isolating earbuds.
Curmudgeon me, "Get off my lawn you kids!"
Am Selling My Used OPPO UDP-205 4k Blu-Ray player
Am selling My Used OPPO UDP-205 4k Blu-Ray player
Oppo Udp-205 4k player I am the original owner.
I bought it directly from Oppo late summer 2018 the last batch from OPPO
very light use to play 4k disc I upgraded the usb dac to do MQA.
I have everything it came with from oppo.
Unit will be double boxed.
What's in the Box:
Owner's manual
Blu-ray player
63" AC power cord
Remote control
2 "AA" batteries
69" HDMI cable
Text me or call on + 1 (917) 633-7290
Email: paullarry86@yahoo.com
How to combine Sonos Connect & ‘alien’ wireless speakers?
Dear audio-DIY friends,
For my current project, my challenge is to connect Sonos & Arylic wireless audio.
In this audio home system, I have two active HiFi speakers with amp/power/Up2Stream Mini built in. Also there are 3 Sonos speakers and a Sonos Connect.
I would like to stream the same music (multi-room) to all speakers, both Sonos & the wireless HiFi speakers (with Arylic Up2Stream Mini inside).
My idea is to connect the Arylic S10 to the Audio-OUT of the Sonos Connect. This way the HiFi speakers should get a signal/music stream coming from the Sonos Connect, via the S10.
Question
Will this setup enable that I can stream via Sonos to play via all speakers; Sonos and my own wireless speakers?
All comments, experience, suggestions are welcome!
Best regards,
KolfMAKER
The Phrugal Phono Stage - a Tasty M65 Preamp for under $200
Greetings, Friend. Are you a Frugal Fi guy?
This is a Phono Stage built around a kit from ZeroZone. It's a clone of the Shure M65 circuit, using a pair of 12AX7s in a Class A configuration. PSU is on the board. A kit with all parts can be found on eBay or Ali for under $30, transformers cost about the same, and the PCB can be found for around $12.
I've read the threads on the EAR834p builds, and I see what can be done with $600, but let's consider a listener with a smaller budget. I don't know about the rest of you, but given the current economy, and the number of record-listening folks stuck home, out of work and bored, I think a project like this is due. I've only been messing with tubes since the beginning of the pandemic, getting time on the bench when my 2-year-old naps and researching when time allows, so this may be a tired subject already. Please feel free to steer me to any other M65-based projects, or share any advice you have.
The lack of the v3 tube and the lower power requirements (30VA, 100v@20mA , 14v@800mA ) bring the cost of all components well below $200, depending on options. The small size of the PCB (4x5.25", 100x135mm) allows the use of very small enclosures such as Hammond 1455Q2201BK (8.6x5x2")when the transformer is placed atop the chassis, under a steel cap, with a small amount of fabrication necessary so the tops of the tubes can stick out. If you don't want the tubes to show, the larger Hammond 1458VE3 (8x10x3") can accomodate transformer and PCB with very little fab work. Both of these options are under $50, as I'm sure are many other chassis from many manufacturers. I've been impressed with Hammond's quality and range of options so far.
For this build I swapped the film caps included with the kit with Orange Drops. C1 and C2 are 0.47uF, and the others are 0.047uF. This is the low value spec'd on the PCB itself, 0.47uF-0.047uF) and the caps included with the kit are 0.33uF. The preamp has a wonderful clear sound, especially in the range of the acoustic guitar, but the bass is lacking, and I wonder if the smaller 0.047 caps are responsible. Any thoughts on appropriate values for those caps?
Since each channel gets its own tube, both tubes should be high-quality V1 tubes, HG+ or similar, but TBH it sounds great with a cheap pair of matched JJs.
I've learned that the original M65 did not have a true RIAA de-emphasis, and that different parts in the feedback loop can address this, swapping the 470pF for a 680 Silver Mica and swapping the 100K for a 110K resistor, and swapping the 1800pF for a 2200pF polystyrene while leaving the 4M7 + 3M resistors in place.
In terms of off-roading, the PCB traces lead to pins 4&5 to heat the tubes at 12v, so a similar 30VA transformer with a 7v@1,6A (?) output could power a pair of 6N2P-EV tubes, for substantial savings. Perhaps different components would be called for in the PSU section? This part I'm just spitballin'
I have a PDF of the circuit here:
SHURE-PHONO-RIAA-SCH.pdf - Google Drive
And Here's the original BOM:
M65舒尔唱放 - Google Sheets
I've been working on a BOM of upgraded components from Mouser, and I'd appreciate any feedback on my selections.
M65 WORKSHEET - Google Sheets
Marantz PM66 SE keeps blowing fuse
Hello All,
Hope your all doing well in these troubled times. I have just joined this forum to try and get some help with my amp (Marantz PM66 SE). Sorry in advance for the long winded post.
After having stored my hifi in the attic (I know BIG MISTAKE, I won't even say "hindsight an amazing thing" as a little logical thought should have stopped me from storing it in such a varied temp environment) anyway... connected it up and it actually worked for a minute or two. Had music coming out of both speakers, however one side was very low regardless of volume level. I messed around with the speaker plugs and still no improvement. Eventually, it just muted....no sound at all 😳 . When switching the amp on I could hear a click but nowhere as pronounced(loud) as it should be. This is a hifi system that has more value to me then it's actual financial worth and as I'm stuck in lockdown I thought I'd have a go at fixing it myself. I've been reading up 🧐 on capacitors, transistors, resistors...etc I don't have a huge amount of money to throw at it but I will give it my best shot to bring it back to life. I am your below average self taught fixer-upper, I have a multimeter, soldering iron, and a hammer lol 🔨
So one day I decided to open the amp... there were no obvious signs of capacitor explosions, however one of the large capacitors was very slightly swollen from the top and both of these large capacitors had a resin of some sort around the base. The pcb (think this is the sound board), from underneath, showed signs of burn in certain spots but not under the large capacitors. I immediately thought the capacitors had leaked out from the base so proceeded to remove them from the board. Having removed one of the capacitors I realised that the resin was not the electrolyte from the capacitor, it was some sort of glue to hold the capacitor in place :facepalm:. Kind of panicked and soldered it back in place lol.
After inspecting the board I noticed that the solder connections holding the three pin small transistor (D1508) had come loose. Re-soldered these on both sides, reassembled the amp, switched the amp on and a few seconds later something started to smoke 🔥 quickly switched off 🥵 . Plucked up the courage to switch it back on and the fuse (T1.6A 250V) blew. Upon further inspection of the pcb board I noticed one of the metal oxide resistors was reading 255ohms when it should be 330ohms. I'm assuming this is what heated up and started to smoke (total guess).
This is where I am at, obviously I could do with some help and advice. I'm trying to learn as much as I can before switching the soldering iron on. Also I'm 100% certain the capacitors (ELNA 10000uF 56V) need replacing but have no idea where to buy them. Some UK ELNA stockiest don't have the 10000uF 56V, I have found an ELNA 10000uF 63V on aliexpress but I really want to try to buy from UK so any ideas where I might be able to get these capacitors from?
I read up and watched countless videos on testing transistors (mosfet) and capacitors, thinking of removing the three transistors and the large capacitors from both sides of the board for testing. I am struggling with the markings on transistors :
One is marked as follows : A1256N with a R under the A and 6C under the N
Another marked as : D1508 with 6C above the D
the third is marked as follows : C3182N with R under the C and 5L under the N
Taking the first one as an example ...Is this a A1256N transistor? All the literature I have read state there should be two letters before the digital code. Also what does the R and the 6C mean?
Once I have understood/identified the components I will remove them and test them. Can anyone give me some advice on how to test capacitors and the above transistors. Info on google is so contradictory..one person says do this yet another says do that 😵
Am I going about this correctly? is there anything else I should check before taking the board apart?
If you have got this far with my post then thank you for reading, if you can give me some advice (other then buy a new amp or pay someone to fix it) that would be much appreciated.
Thank you & stay safe
bass out
Diy Powersupply
Hello Everyone, i am starting a new project, i am going to make a PowerSupply for my X-Can V8 and my heed , i will use it as a learning experience, so i will try to make it as good as possible, fuigure i will try a lot of things to get it as good as i can. 🙂
The easyest thing will be the PSU for my X-Can V8 sens it seams to only be a toroidal transformer around 30va and not much more, one that makes a third party PSU have added a EPCOS surge protection and a EVOX class X2 for filtering.
is it a good idea to att surge protevtion and filtering ? if so what whold
be a good rout to go ? something like a IEC with EMI filter or is it better to make a board for that ?
The wall wart that come with 3 pins gives it 24VCT (12 0 -12) and 500mA
dose anyone have a picture on how the X-Psu V8 looks like inside ?
The next one is the powersupply for my Heed Audio Questar
The Heed Q-Psu 3 that is the "real" one i shold get seams to use a
50VA transformer
8x diodes for bridge rectifier
2x10 000uf 63v 85c caps (on older modelse they have used Jamicon)
4x voltige regulators ( conectors have 4 pins 2x24v )
and a few smal caps and diodes.
from what i can see they use one film cap before the rectifier from + to -
what is the "best" way to do this, from what i have seen some use a cap and a resistor from + to - , then some use film caps like a 10nf in parallel with diodes in the rectifier. i am open for ideas 🙂 and also what is the best diodes to use in the rectifiers ? Schottky diodes ? [FONT=Arial, Helvetica]or a "chip" ? something els?
is there any voltage regulators that you know of that will be realy good for this ?
i know that there is a lot of questions (and there will be more) but i am just starting out in making my own circuits so bear with me 🙂
i dont realy have a budget for all of this but sens this is for learning as well i might have a higher budget then i normaly whold, as long as it costs less then the originals🙂 hahaha the Q-psu is 572USD?? and the X-Psu when it was around was 350USD so it shold be easy to get below that i am guessing 🙂
have a nice day all 🙂[/FONT]
My long overdue 3-way tower build
Long time member, infrequent poster here 🙂 After years of planning on "getting around to" building a proper set of towers I finally have the space, tools, and time to start on this project, as well as a livingroom in what is hopefully our "forever home" to put them in.
Some background my my speaker building experience and this project:
  • Like many, my interest in audio started with my car. Initially focused around off-the-shelf 2-way passively crossed system and evolving into actively driven systems including a setup involving Peerless "Exclusive" HDS 8" midwoofers with Image Dynamics Horns
  • My first venture into home speaker building was a set of the Dayton Audio 8" MTMs Here is an example
  • A set of bookshelfs based around the CSS WR125 driver with a cheap Dayton tweeter (cross-over design copied from a published project)
  • After removing the Peerless Exclusive 8s from my car and mothballing them(10-12 years ago) I grabbed a matching set of Peerless Exclusive 5 1/4's before they were discontinued, with big plans on using them in a TMW tower build
  • Also leftover from another automotive install are a pair of Dayton DC28F-8 1-1/8" silk dome tweeters which I'd like to utilize in this build, provided that they pair well with the Peerless mid & woofer drivers
Goals for the project
  1. Finally get some experience designing crossovers. I realize jumping into a 3-way setup may be a steep learning curve, but if I don't try to tackle this now I'll probably never get to it
  2. Make good use of the Peerless drivers which were pretty well regarded when I purchased them. Utilizing the Dayton tweeters is a nice-to-have, but I wouldn't loose sleep over tossing them if needed
  3. As these are going to be prominently displayed in our living room, I will be considering them a piece of furniture when it comes to cosmetics. Bodies will be primarily MDF, but I do plan to incorporate some hardwood accents and matching veneer
Baseline Driver list:
Peerless HDS Exclusive 8 (830884) - Firm
Peerless HDS Exclusive 5 1/4" (831882) - Firm
Dayton DC28F-8 1-1/8" Tweeter
Oddly enough I searched through my post history and found This Thread that I started in January 2007 when I was starting to think about building a proper set of towers, so this project kick-off has been a long time in the making 🙂 I also just realized that my "Black 300zx" has long since been sold and now a white 300zx resides in the garage 😛
How to open Dynaudio Sapphire to test crossover circuit
I have Dynaudio Sapphire's and both the woofers on one speaker have stopped working.. I have tried basic troubleshooting with switching cables between left and right and the same speaker does not work.
I am trying to open it to test the crossover circuit and was hoping that the area on the back where the cables are connected can be opened. I have opened the screws but the "thing" does not budge.. (see attached pic)... I don't to damage it.. was hoping I can get some guidance on minimal opening to test out the crossover..
Thanks in advance,
Idaho.
Kicker KX1200.1 - missing elements
Good day!!
there is such an amplifier to revive. . some elements are missing on the board. please tell me what should be.
1. q06,07,08,09. q12,13,14,15 - power supply. ( I have a circuit this amplifier. but the diagram shows other numbers) -
diag. this Q71,72,73,74. Q81,82,83,84 - IRF3205.
2. q118,119,120. q140,141,142 -
diag. Q230,231,232. Q330,331,332 - IRF640
3. ic-U14 soldered - LM361M
diag U508 - B52
thank you.
Wavecor driver question
Due to this pandemic state, the sales are declining significantly, as I just informed one of diy audio store in my area is cleaning out their inventory and will cease to operate. Several interesting parts they carry are including faital pro and wavecor. As these 2 brands not as popular as seas/vifa/scanspeak/sba here in indonesia
I was inclined to some discounted wavecor drivers on their racks.
It was tw022wa05 (tweeter) and wf152bd05 (5.5 inch midbass)
The tweeter now at usd $40 pair and the midbass at $60 pair
I have a plan to build a 2.1 system with these 2 drivers as satellite, but still looking for options on the subwoofer
Has anyone use these drivers before? How do they sound? Do they comparable /in the same tier with the likes of scanspeak discovery range / peerless hds / sb acoustics nrx? Worse / better?
Purifi 1ET400A Input buffer with Korg Nutube valve
Purifi 1ET400A / Hypex NC500 Input buffer with Korg Nutube valve [Updated]
This buffer is based on the double Nutube triode from the Japanese manufacturer Korg. The circuit is valid for Class D power modules, model 1ET400 from manufacturer Purifi Audio and model NC500 from manufacturer Hypex (with some limitation). They both use the same expansion connector and are fully compatible.
First of all, we must bear in mind that, with this buffer, we want to achieve the maximum power, dynamics, damping factor and efficiency, typical of class D modules, and mix it with the warmth that valves provide. This is not a buffer with very low distortion, for this we already have other buffers in our store with very good results. This is a buffer that gives us a sound very similar to vacuum valves.
This buffer works fully in differential mode, so the input has to be balanced with an XLR connector (or TRS). With the balanced audio input, we provide an appropriate output signal to attack the balanced input of the power module. In the case of using an unbalanced audio signal (with RCA connection), we will have a loss of gain of 6dB, which is equivalent to four times less output power.
The circuit is prepared for use with the original Hypex power supply, model SMPS1200/A700, in the case of use with the NC500 module, or with the model SMPS1200/A400, in the case of use with the Purifi Audio module. In both cases, an important point must be taken into account: Jumpers J6 and J7 (Vaux marked in red) must be placed in position 2-3 (unregulated Vaux) as indicated in the green box. This way we will obtain the correct voltage to supply the circuit in J4 connector.
The circuit is made with the best medical grade and audiophile grade electronic components. The resistors are made of metallic film with a 0.1% tolerance. Electrolytic capacitors are Nichicon special for audio. Sparkoslabs very low noise voltage regulators have been used. The two variable resistors at the top of the pcb adjust the maximum distortion value and the two variable resistors located at the bottom adjust the output signal in differential mode. These resistors are factory adjusted to the optimum value so that the power module works in the best conditions. It is not advisable to touch these resistors to avoid a malfunction of the circuit. Only if laboratory instruments are available could they be minimally varied until the desired function is achieved.
The circuit is adjusted so that with, an input sensitivity of 500mV (balanced), an output power of 160W RMS at 4 ohms and 2,67% THD+N (with Purifi Audio).
Higher output powers can be achieved by increasing the input signal, but the distortion will rise exponentially.
The PCB measures 125 x 63mm and has several connectors.
  • J1 Balanced audio input connector.
  • J3 IDC connector 2x5 flat cable.
  • J4 Angled connector 2x18.
  • J5 Speaker Fastom connector (+)
  • J6 Speaker Fastom connector (-)
  • J7 Power connector.
Connections are made as follows:
  • J1 Buffer Nutube to balanced input connector (XLR o TRS).
  • J3 Buffer Nutube to J4 SMPS1200/Ax00 with flat cable and IDC connectors.
  • J4 Buffer Nutube to power module.
  • J5 Buffer Nutube to Speaker (+)
  • J6 Buffer Nutube to Speaker (-)
  • J7 Buffer Nutube to J1 SMPS1200/Ax00.
The SMPS1200/Ax00 J4 connector has the following wiring:
  • J4.1 + 21Vdc
  • J4.2 - 21Vdc
  • J4.3 GND
  • J4.4 No Con.
  • J4.5 No Con.
  • J4.6 Amp. enable
  • J4.7 No Con.
  • J4.8 No Con.
  • J4.9 GND
  • J4.10 DC Error
The SMPS1200/Ax00 J1 connector has the following wiring:
  • J1.1 VDR+
  • J1.2 HV+
  • J1.3 GND
  • J1.4 VDR-
  • J1.5 HV-
  • J1.6 GND
The kit consists of the following material:
  • Buffer Nutube PCB (2 units)
  • Molex Connector J1 with pins (2 units) w/o cables
  • Speakers female Fastom Connector (4 units) w/o cables
The rest of the connectors and cables are usually included in the power modules. They can be obtained individually on the Hypex or Purifi website
Details in Buffer Korg Nutube for Hypex NC500 and Purifi Audio 1ET400 | atm-audio.com
Buffer with op. amp. https://atm-audio.com/product/buffer-hypex-nc500/
[UPDATED Summer 2020]
We have recently made a new version of the Nutube buffer (V2). We have replaced JFET transistors and used very low noise instrumentation op amps as impedance adapters. In this way, we have managed to reduce the total harmonic distortion (THD) throughout the power range, especially in the 100-500W range, which is where the V1 buffer rises a lot, keeping it below 1%.
This curve was measured with the Nutube V2 buffer connected to the Hypex NC500 module.
We have achieved, for a +/-1 VRMS differential input signal, an output voltage of 141 VPP before clipping. The total harmonic distortion + noise (THD+N) is 2.34%. The distortion of the second harmonic (2H) is 0.27%. With this numbers, we have the equivalent of a 625 WRMS tube amplifier @ 4 Ω, with a total gain of almost 36,19 dB.
In the next graphs you can see some measurements of the THD+N at 1 kHz and its harmonics depending of the output voltage:
https://atm-audio.com/500-w-hybrid-power-amplifier-with-nutube-valve-for-hypex-nc500/
[UPDATED November 2020]
These are the buffer measurements with the Purifi Audio module.
For a differential input signal of +/- 500mV RMS, we have an output voltage of 98 VPP before clipping. The total harmonic distortion + noise (THD + N) at this point is 1.53%. The distortion of the second harmonic (2H) is 0.037%. With these numbers, we have the equivalent of a 300 WRMS tube amplifier at 4 Ω, with a total gain of 34 dB.
As can be seen from the graph, for 100 WRMS amplification the distortion is only 0.35%. Up to 50W the distortion is less than 0.2%
Power vs THD+noise
(5W @ 4 Ohms)
(100W @ 4 Ohms)
https://atm-audio.com/300-w-hybrid-power-amplifier-with-nutube-valve-v2/
SB17NRXC35-8 and SB29RDC-C0004 playground
I made some measurements and derived the .frd and .zma files for this particular drivers. I've been playing for a while with different types of xovers. Files are attached so anyone who wishes can play with it in PCD by Jeff Bagby, WinPCD or Boxsim and see if the drivers suits him.
If anyone shows interest for it, i can upload the files from Holm-Impulse if you want to change the gate and derive your own files.
The mic is on tweeter axis, about 1.2m distance.
cheers
the new 500 mm baseplate option
I am having difficulty in understanding exactly what exact chassis the new 500mm deep baseplate goes with.
In one answer, I got dissipante 4u as an answer but then when I try to order it, the web site confused me. The baseplate option did not give that choice.
Also, is this the depth of the chassis or the width of the chassis ?
What is the largest (5U perhaps) chassis that the new 500mm baseplate can be used with and does anyone have an assembled picture of it ?
Quad-405 Power amp clone boards
Two Quad-405 power-amp boards, LJM made, removed from amp in working order, mint.
Original 405 schematics, needs some NPN output transistors and TIP42 driver transistors, these ( originally some MJ-TO3 and drivers) were connected to heatsink with wires.
Price for two boards 20€ plus shipping.
Regards.
DAC ES9038pro Bluetooth Upgrade
Hi everyone,
I'm trying to put a Bluetooth Receiver (CSR64215) into my China DAC, but I have no idea how to connect it or if it's even possible. I've added some pictures for you to see what I mean. I've also looked on the Internet to find some general information but haven't found anything yet. There is some free space to add a USB to IS2 Interface with 6 open pins to connect it - would that maybe be an option?
I'd really appreciate any help or information!
David
Meniscus Continuum 2 Build
Just finished my first multi-way speaker build (it has a crossover). I'm an experienced woodworker & toy around with lutherie so I have tools, machines, etc.
I wanted to make a set of sealed box monitors for the shop so they could be placed against the wall & I decided on the Meniscus Continuum 2 monitors (Bagley BBC LS3/5A inspired).
I may be enamored with them since I constructed them from a box of drivers & raw electrical components but they sound really nice! They don't blow your mind when you first hear them but as you chill out, relax a little, and listen they're very good. I have a set of Revel Ultima Gems which I'm sure will surpass them head to head but I'm not missing them yet.
So now I'm intrigued. The 2's use a Morel tweeter while the original design used a the Dayton RS28A-4's which are no longer available but apparently they're out there. I realize that the Dayton tweeters will require the crossover to be changed but has anyone listened to the 2 configurations side by side? I'm really enjoying the Continuum 2's.
Crossover Inductor Diameter Limitations
Hey all,
I'm delving into crossover design and I am not experienced in it at all. I have also forgotten a lot from my circuits classes at university but I will do my best to understand whatever comes here and brush up on those concepts.
I have a general design for my crossover and I'm considering wrapping my own air coils. My main question comes in when using different values for coil height, diameter, and wraps I can get the inductance value with different dimension of the coil.
Something I can not seem to find any information on is possible design constraints for the air core diameter. Other than space, are there reasons to keep the air gap smaller or larger? Does going too large have potential for picking up RF? Or is there a change in latency of the field forming that can affect the performance based on the size?
I guess another way to put it would be is there any reason that I cant wrap a coil with a 2 inch diameter as opposed to half an inch? They can calculate out to have the same inductance but I imagine it can't be that simple.
I don't know what is worth considering or what is even an issue. Hopefully someone might know more about inductor properties here and can explain something.
Thank you guys for any help.
PSU Studer A810
Hi, I need some advice about the revision of my Studer A810.
For the electrical adjustements I measure some difference in the dual output (+/-15V).
With load, at the test points I have -15.62/15.19V, without load measuring on stabilizer card -15.66 en +15.38V. Maximum deviation according manual is 100mV.
Is this something to worry about?
Thank you!
Best,
Martijn
Audio Physic SPARK - first version (not II/III) - Test reviews and Part List wanted
A friend from me want to purchase the first version of this loudspeaker:
Audio Physic Spark Brochure
Audio Physic Spark I - wer kennt die ? - Verstarker, Lautsprecher, Zubehor - Analogue Audio Association
Who can upload the owner's manual, part list of custom made SEAS drivers and schematic of passive crossover network ?
Use the dome tweeter ferrofluid or not (maybe NOFERRO version) ?
Are there successor versions of the used LF-Mid driver and the used dome tweeter ? - go to
PRESTIGE TWEETERS
PRESTIGE WOOFERS
Thank you very much.
How to build a balanced single-source 6-channel preamp/vol control?
I have a bit of a dilemma. I'm building a 6-channel amp with balanced XLR inputs which will be amplifying 6 outputs of a MiniDSP 4x10HD to power a pair of 3-way speakers. I only have 2 inputs into the MiniDSP -- USB (streaming Roon/Airplay via Ropieee) and an analog turntable which runs through a Schiit Mani > Sys for level control.
My main worry is that the MiniDSP only has digital volume control. The knob on the front is an encoder, so there's no zero position. Thus I never really know where the level is, so I'm always worried that the volume might mysteriously be at a dangerous level.
I'd like to run the 6 outs of the MiniDSP through a basic preamp / volume control -- nothing more than 6 balanced inputs with 6 balanced outputs and a reliable analog volume knob that I can turn to zero. Except all of my googling so far hasn't provided me with any path towards a solution.
The only thing I can think of is to use 3 of the 2-channel solutions that I can find (e.g. this Differential Volume Control from Neurochrome) and somehow calibrate them so that each knob is passing the same signal level at the same position, but even then I feel like it'd somehow always be "off" so that the treble, mid, and bass signals being sent to the speakers won't be authentic to the original mix.
How do I make this happen / what do I look for?
EDIT: Even if it was a 3-dial stepped attenuator with only 10 discreet positions, that would probably be good enough if I could match the signal level of each step exactly. I think that would allow me to dial it in perfectly every time? All I really need is some way to reassure me that the volume level is low when I start playing music and be able to turn it up gradually to a reasonable listening volume. From there I'm happy to do further adjustments with the MiniDSP's digital level encoder.
Thanks!
Finding Resistors with correct Wattage or does it matter
Hi
I have a schematic that I am following to build a pair of crossovers for some JBL pro drivers. I have an 8 Ohm bottom and HF and a 16 ohm mid. These are all correct based on the crossover and the speaker model.
I am having a hard time findig resistors to match the resistance and watt rating.
For instance, I need a 50 Ohm 11W but all I can seem to find is 47 Ohm 10W
Can anyone advise how critical small differences would be. Would my ears hear any difference ?
Transformers - Winding/Wiring Questions
Hi all, first poster here. I'm launching into my first non-kit build based on this design. I'm going to drop the DC heater circuit in favor of AC for simplicity. This leads me to two basic transformer questions which I've had a hard time sourcing a simple answer for. Please forgive any lack of proper terminology or misunderstood concepts, I'm just learning. 1) I plan to use a center-tapped, 6.3V, 6 amp transformer (Edcor) but am uncertain how wiring of the heater circuit differs from a non-center tapped transformer. I understand that each side of the wiring is 3.15VAC out of phase, and along with the grounded center-tap this helps reduce hum. What I don't get is "flow" for lack of a better term. How do two positive voltages, wired into a filament, cause it to heat up? The voltages add up to 6.3, do they create a pathway back through the transformer to ground? Do i just pick a pin for one of the 3.15V taps and stick with it as I daisy chain the filaments? Question 2) the reason I chose this project is that I have two 3.5K output transformers from an Elekit project that I didn't use. There is little info online about these as they are Japanese (Etine or something similar, don't have them with me). They have five wires on the primary side, 3 that i plan to use (B+, UL, and plate) but also a ground and negative feedback. Since this amp has no NFB, i'll just tape that one off. What about the ground? Want to make best use but if that is just taping it off, than so be it. Thanks for your input.
Quantum Audio QEQ6 pre-amp with no output
I am trying to repair a Quantum Audio pre-amp that has no output. There is no power to the opamps. There is a small transformer on the board that is getting voltage on it's primary windings and auxiliary windings but there is no voltage bon the secondary windings which feeds some diodes and capacitors which then power the opamps VCC circuit. The remote turn on circuit appears to be working properly as well as the 3 transistors prior to the transformer. What can the problem be? The buck stops at the transformer but I see no sign of a problem or damage...
ecc99 - 6C19n PP, (6S19P)
Hey, I bought a bunch of 6C19N, to get started
ECC99 seem to match as driver
Should I use SE or PP driver stage
Interstage trafo could be coupled for 1:2 gain with SE to PP configuration
With PP to PP configuration only 1:1 seems possible
I could consider a line trafo, but those are expencive
Would nice with some input on this
TQWP Acoustic Bass Guitar
Hi everyone,
I have long had an idea of an acoustic bass guitar that sounds real deep and that is comparable to the upright
double bass in loudness.
I understand that it can only be achieved with a reasonably high body, because it is the big volume and mass of
air inside the instrument that gives the required loudness at the lower frequencies.
A couple of days ago I came across the concept of the Tapered Quarter Wave Tube resonator.
So the idea is to have a TQWP and fold it up as a guitar body shape as can be seen on the first attached image.
The driver would be mechanically driven by the resonating bridge, shown on the second image.
The instrument's lowest note would be the same as the double bass's lowest string : E1 (41.2 Hz) and its range
would only be two octaves up to E3 (164.81 Hz)
The tube would be tuned to somewhere around G#1-A1 (51.91Hz-55Hz).
Now my questions are:
1) First of all, is it a good idea at all? I mean, could this folded pipe instrument sound any louder, than a
conventional instrument with a simple hollow body and the top board as the resonator? Assuming the two instruments
had the exact same body volume and the plucking, mechanical energy input is the same in both cases.
2) If yes, how would the bending of the tube affect the sound quality?
3)How precise does the tapering have to be? Does its cross-section area have follow a strict increase along the quarter wave path?
4) Is it possible to completely cut off, or severly supress a frequency band above, say 170-180 Hz by the geometrical modification of such sound box?
Since I am not an expert at all in acoustics, any input/opinion/remark would be greatly appreciated.
Off-board Coupling Caps Question
I've got some huge Russian K40Y-9 .22uF 1000v caps that I want to try out in my SSE. They are too large and heavy to try mounting in the allotted space.
George, on your TSE page you write the following:
C9 and C11 are the coupling caps. In this design the coupling caps work into an almost purely resistive load. This makes the coupling capacitors far less critical than they are in a conventional amplifier design. It is still an important capacitor and a low quality capacitor will still have a detrimental effect on the sound. I have allocated a large space for this capacitor since some of the boutique capacitors are quite large. If your capacitors are larger than the allocated space, they may be mounted under the board, of off board. See the upgrades page for details.
Note the "upgrades" link is broken on your site.
My question is, for off-board installation of coupling caps, is the off-board cap location and routing of the connections from the caps to the board critical? Should they be located far away from any particular section of the board? Like "as far from the power as possible" , or "as far from the input section as possible?" I'm going to need to mount them to the side of my chassis and I want to get the location right the first time. Of course in my case I am talking about C11 and C21.
By far, the shortest run is from the board to the front of my chassis, on the side of the board where the input terminals are.
Trying to: 2-way Linear Phase Crossover
Greetings,
I guess I'll start by explaining what I'm doing.
I had been using a wideband driver and it's phase was mostly centered around zero degrees from the treble down to a few hundred Hertz. The stereo image and 3-D depth was fantastic.
The thing was, the wideband needed baffle step compensation and a tweeter. Adding even a first order crossover introduced phase shift. Along with increases phase shift I noticed diminished imaging and depth.
Woofer:
BSC
2nd order low pass
2 notch filters
Tweeter:
1st order high pass
1st order allpass to to align the phase 5kHz-20kHz
voltage devider
There is also impedance correction to reduce impedance phase. None of these had any practical effect on the acoustic phase, other than the allpass aligning the phase where it was needed.
The point I'm getting to is that I noticed one design in XSim3D called the "Cosyne3 with AllPass practical" as shown in the next image below. It has a mostly linear phase down to 500Hz. How exactly is this linear-phase response achieved?
Kenwood KA-3700
I'll start this thread with a very short prologue... (feel free to jump to the second paragraph)
I'm totally new to electronics and only have a vague understanding of the various components inside a circuit (I know what each does on it's own, but get quickly confused by circuits such as this one - can't follow the "logic of the current" yet), but I would really like to learn. So I thought that the best way to learn is to just dive in, make some black magic smoke :Popworm:, ask stupid questions and experiment. I'll just call it 'applied electronics' so I can feel better.
So, I searched the ads for a defective amp and this little Kenwood looked like a good place to start (not that complex, good looking, fairly good reviews when working).
The previous owner said it had one totally dead channel and the other with low volume and heavy distortions. I didn't plug it in and started looking for bad parts. So far I found one burnt resistor and one burnt fuse. I checked all transistors in-circuit and removed those that read 'funny'. Out of them 4 proved to be dead (various shorts plus one open base-collector junction).
I marked all identified components in red on the schematic.
Next step is to make a parts list on mouser (including a full recap for the electrolytics) but I have a real hard time picking equivalents for the transistors and I'm also not sure whether I should only replace the faulty transistors, replace them in pairs (as per schematic - both in a darlington pair even if only one is bad), replace them in pairs across the two channels (ie. also replace the inverted darlington pair in the left channel even if both read ok). I tried to find replacements filtering by specifications but I would feel a lot safer to get suggestions from people who actually know what they're talking about 🙂
All suggestions will help a lot 🙂
Thank you!
Garrard Type A Mk II Makeover
This started out as my uncle's Garrard Type A Mk II record changer. It got passed on to me last winter. The motor worked, but the other functions needed help. Once I looked under the hood, I realized it needed more expertise than I could provide to restore it's original functions. I made the decision to strip the automation, upgrade it with a Marantz tonearm, and build a custom cherry/curly maple plinth. I also brushed up the platter, painted the tray, added an acrylic mat, and mounted a decent LP Gear Vivid Line stylus to an AT-3600L cart. I removed the spring suspension in favor of vibration isolating rubber feet, but kept the original motor, controls tray, and rim drive system. Once dialed it in, it sounds pretty darn good to me. I've been having a blast playing oldies from his era on it, but it does just fine with modern recordings too. Very enjoyable and satisfying first TT project.
Sockets for TO-92 Transistors?
I have a Hafler power amplifier under repair on the bench. It has the unobtanium jFET K163/J44 matched quad in the input stage.
Not wanting to damage the jFETs and the old dual sided PCB tracks during repeated soldering/desoldering, I thought of installing sockets for each of these TO-92 devices.
A few of these need to be mounted with the three legs in-line, while others are in a triangle.
Can anyone recommend suitable sockets for such an application?
Thanks in advance.
Stay safe
Mayank
Crown I-T6000 Rare Failure
I am in the repair process of one Crown I-T600 power amplifier but it have a very rare and strange problem. This amplifier sound for 1 second(literally!) and after that it mute itself after the turn it on. I have added a short video showing this issue and I will be very grateful if someone can help me in order to find what the problem is.
WeTransfer
I will wait for any comment, advice or suggestion in order to try to repair it.
Thanks for anticipated help!
opacheco.
Yamaha DSP-AX1 Cap values
Just been giving this amp a go at seeing if I can repair it as I can not find 1 place worldwide that'll attempt it.........
So, problem is, powers up fine, no speakers connected, nothing else, shuts down a few minutes or seconds later. Thing is, when it shuts down, then a power on attempt causes a shut down straight away, leave it for 30 seconds odd and it comes back on.
Funny enough, no cold solder joints, PSU fine, transistors fine, but on discharging caps on the power board got 1 cap 38% down on Vloss, 5 others at 8% - 18% loss, so, is that more or less telling me, replace them? Is it a loss less, or on 3% ok?
The main Gold Tune caps, 27000uf 71v are down to19000uf and the other 17000 odd uf tiny bit of volt loss also...
Superpentode-like amp: any experience with it?
Hello everybody,
this thread is not strictly related to an hi-fi amp, but based on the curiosity born some moths ago after having read this document: http://www.next-tube.com/articles/Veen2/Veen2EN.pdf
Case 5 is super-pentode, where screens are connected to the opposite UL tap, and cathode feedback is applied as usual. This gives the highest wattage without having the best possible damping factor.
So, after having seen this cheap output transformer: D29A09F | Trasformatore audio OEP, primario 6.6kΩ, secondario 3.75 Ω, 7.5 Ω, 15 Ω, 10W, Montaggio a pannello | RS Components
I though it could be a good candidate for an AB1 PP of EL84 and 6V6GT with screens connected to the opposite 20% UL tap and some shunt (instead of cathode) feedback if needed.
The choice, apart from the price, is due to small amount of feedback, so the small amount of positive screen swing while plate is going towards zero. For sure there will be need of a bigger screen resistor to control secondary emission.
I would use it for two "twins" instrument amps using 6V6GT in one power amp and EL84 in the other. I know it should go on another section of the forum, but on that specific section of the forum I wouldn't find people with experience on this kind of things, and it would become a dead thread.
Thanks in advance to everyone would like to partecipate with cogitations, impressions, suggestions or expectations. I will post some simulations in the following hours/days.
LME49720HA/LME49600 Preamp/headphones amplifier board
Two more LME49720HA/LME49600 stereo preamp boards. One with 2xLME49720 (DC-servo), one with one LME49720HA. Only assembled and tested. IMHO these work great; as a headphone amp ( also with 2 X 9V batteries) or line preamplifier stage. Also one suitable power supply board; op-amp servo, adjustable..only need suitable centre-taped or double-output transformer.
Price for 20€ for bigger and 15€ for smaller preamp board, 20€ for power supply. Free shipping for regular letter, 6 € priority/ tracking.
Regards.
Can I build up these Darlington transistor if I use two BJT transistor ?
Hello
It is possible to build up successful (to get the same quality sound) the BDX53C /BDX54C medium power darlington transistors .
Data sheet with the internal circuit available here !
http://www.datasheetcatalog.org/datasheet/stmicroelectronics/4103.pdf
The reason I want to build up these darlington I want to get high power darlington close to the BDX type
For example
I chose for driver MJE15030 /15031 Minimum hFE=40
For power transistor MJW21195 /21196 Minimum hFE=20
The BDX53C/54C min hFE=750
If I do these calculation I get close hFE 40x20=800
I also have at hand MJL21193/94 similar like another power transistors but with more power .
Of course I ad the 10K & 150R resistors and also a diode .
Any comment , help , advise please 😕
Thank you very much
Cheers
High quality wire wrap
Anyone has a source for really high-end feeling finishing wrap options for interconnects/speaker/power wires?
Anything that seems to be used in DIY community is a common plastic braided PEI sleeving, which makes final product look barely attractive, stiff and otherwise ugly. We're here for the pleasure of perfect result, right :] ?
Some other options? Textile? More delicate braids? Some miraculous plastic/rubber? Anything I can't imagine yet?
Photo Resist Board
Hello All,
Back In the early 90s when I started my electronics, I used to use Maplin Photo Resist boards and back then the fibre glass laminate was clear so you could see faults by looking at the component side. Does anyone have any photoresist board that one etched looks like the photo with DIGITAL printed on (1st Photo) or any old Maplin Photo Resist board they will sell or any copper clad board (not presensitized) ? The following manufacturers would be Ideal : MAS, IGAV, and then 'i' (photo provided of symbols), There Is also a photo of a new green board which I'm not really keen on so thought I would ask here first. I'm stuck to my old ways rub down transfers and everything !
Many Thanks,
Digital.
Integrated PC Sound System. I Could Use Some Guidance.
2.1 Boombox. I Could Use Some Guidance.
Hello All, a small project of mine brought me here in the hopes that some of you could help me put the finishing touches on it.
I am in the planning phase of rehousing my Gaming PC into a 22inch Rigid Toolbox, in order to make it more portable than the tower it is in.
The carry handles and extra space for the keyboard and such is the main reason I decided to try it,
but then "The Question" popped into my head "Why Stop There?"
I am going to be running power into the box and have internal surge protection and a power strip,
and now all it needs is sound in order to be an all-in-one entertainment rig, which will only need a monitor and a single 110v outlet.
Ideally, the system would be filtered, with 1-2 Tweeters, 2 Midrange Speakers, and 1-2 Subwoofers powered by a bluetooth amp board.
They would need to be in the 1-3" size range, and still need to be plugged into the PC via USB or AUX.
I would like it to sound better and louder than a bluetooth speaker, and obviously better than the "Internal Speakers" found in TV's and such.
I don't have the necessary knowledge about Ohm's, Watts, Placement near electronics, and power to jump right into it, so I was hoping for some instruction.
I hope you all can help me, thank you for your time.
(THIS POST IS IRRELEVANT, DESIGN CHANGED FURTHER DOWN)
Dunlavy SC-V - Vifa D75MX-31-08 dome mid replacement drivers
Hi all,
I have a problem on my hands. In mid-October I bought a pair of Dunlavy SC-V off of US Audio Market. It took me far longer to get them into the house and ready to test them out than planned. I got the speakers into the living room and shoved into back corner a couple weeks ago, but didn't get around to testing them until Sunday evening and... no highs or midrange!
After checking out everything obvious I pulled a crossover thinking something got knocked loose during shipping; no luck. I pulled a mid and measured the voice coil; open. My heart sank. Same thing with the other mid. Same with the other speaker. All 4 mids and both tweeters voice coils measure open! Seller s they worked fine when he put them into storage in an unheated garage a year ago. He says he's willing to refund money to cover the cost of replacement drivers, so that's a good sign.
Anyway, I need to find replacement drivers and want to get them back to as close to when they left the factory as possible. With no tweeter or mid to measure as a reference I'm not sure how to proceed, especially since the D75MX-31-08 that are supposedly used as the mids are discontinued. I've also read comments saying the -41-08 version is nearly identical, but other comments saying they sound a little more forward.
Tweeters I'm not so worried about. Those seem readily available, inexpensive, and since I have pairs of both SC-III and SC-IV, I can rob the pair of tweeters out of the SC-III and shove replacements back in there.
What would you recommend I do? D I find 4 of the discontinued -31-08's, or buy new -41-08 from Madisound or whoever and have them match a set? I'm not averse to getting out the soldering iron and changing a cap, resistor or whatever if I had to to make the -41 sound like the -31, if needed. I 'd just need some help determining proper values.
Brent
Stetsom 5k
Hi everyone
I'm new to the forum and hope someone can help.
Bought a stetsom 5k, one of the older gen ones, bought it as a faulty unit with the hope it would be an easy fix.
Everything on the board measures fine, no blown ps fets, no blown outputs, amp has never been touched.
Amp powers on, blue light, builds good squarewaves on the transformer primaries, as soon as it reaches full duty cycle the amp shuts down. I then get solid red led for about 5 seconds followed by 3 flashes of red led.
I see nothing wrong with any components, been through just about everything on the board.
I'm using a 30A regulated bench supply at around 13v so don't think it's a power or low voltage issue.
Current draw at startup is around 5-6A
Capacitors across rectifier diodes
Hello.I have an old radio that i want to change the 4 rectifier diodes and the 4 caps in parallel with each diode due to oxidization.
Original diodes were DS135D and caps 22nF ceramic.
I will replace the diodes with 1N4007 but for the caps i have 10nF/63V and 100nF/63V ceramic type.
The transformer secondary is 9V AC. Is the voltage rating of my 63V capacitors sufficient? can i use one of those two values instead of 22nF?
Subwoofer connection options?
Im running a system with a computer running jriver media center to a nad c510 pre-amp dac which does not have a sub output I have connected it to a sub in the past to subwoofers using the speaker wire connection option but the new svs sub i bought does not have them only rca inputs -Normally you would hook it up with a rca Y connector but I've got the nad dac hooked up to a power amp using xlr cables-do the rca's stll put out a signal when xlrs are being used or what are my options? any ideas🙂
preamp grounding question
Hi im putting together a preamp pcb as a lerning exercise and have a couple of questions.
One is how to make the earth connection if the preamp is a mono mono design in a single chassis (seperate psu for left and right). Its my understanding that whatever connections to the chassis you do, it should be made on a single point, but the layout looks more efficient if i pick 2 locations from the chassis, then to resistor/cap/back to back zener then to the psu grounds.
Also, does the signal input ground have to connect to the gnd of the pot before going to the psu ground? Because of my layout its more efficient to join the pot gnd and signal gnd seperately in a star ground arrangement
Thank you in advance for your help
/Haps A New Basic Opamp App: The Floating Interactive Current Multiplier.
attachment.php
This two resistor opamp circuit multiplies the input current by ( Rin/Rout+1).
The source sees the load impedance multiplied by the same factor and the load sees the source with the inverse factor. Bellow are two example as ×2 and ×1000 factors.
Hayk
A new perspective on current-sharing hybrid amplifiers
Happy New Year!
Coming back to the design of tube-like hybrid amplifiers, one goal was to create an amplifier that has some desirable characteristics of all-tube amplifiers but optimizes away some undesirable aspects, frequently low "specific output" wrt. operating voltage, heat, weight, cost...
The approach outlined in this old thread was to "boost" a tube using solid state technology such that the tube characteristic dominates, ultimately arriving at the idea of current sharing between a tube and a feedback loop:
http://www.diyaudio.com/forums/tubes-valves/118725-hybrid-21.html#post2933421
But what if we construct an alternate view, centered on the output transformer?
The circuit below contains the familiar chip-amp boosted tube stage, and goes another step to model it like a tube output transformer. I have separated the components to illustrate this.
The gyrator with extra B+ models the Primary Inductance (Lpri), allowing the tube to operate at a fixed DC point with high AC impedance.
The chip amp circuit models the step-down voltage ratio and current multiplication of the OPT, but multiplies the current by a very large factor. The tube only "sees" a high impedance resistive load.
The purpose of the Reflected Load is to set the current multiplication ratio of the modeled OPT to some desired value, putting some of the output load back on the tube. This can be set independently from the voltage ratio, allowing us to scale the tube down in current and voltage swing, while providing a scale model of the actual loudspeaker load for it to work into.
Some fraction of the AC current load at the output is reflected back to the plate circuit of the tube, to create a dynamic load impedance that looks more or less like what the tube would "see" through a transformer.
Some components are omitted to simplify the circuit...
Mosfet Reasonaleb b b ú⁶p1 Thermal Transfer Solutions.
A few question about replacing the silicone tacky type. It always tears when attempting to removebit from the old transistors or mosfets. Where can this be purchased or should i just stick to mica or kapton tape?
I only have 100 to-247 mica insulators.
And 1 and 2mil kapton is this thick enough or do i need the expensive 5mil kapton tape?
Can the other silicon type tape be purchaed? If so where?
Creek CAS4040
Initially not working;
DBT stayed on bright. Some electrolytics in the power supply v.bad (DMM & $25 component tester). Changed PS 'lytics, slightly higher voltages. DBT dimmed down "ok". Retested, bounce not noted! Changed ALL 'lytics.
Tested with cheap 3-way speakers, & the bass/woofers "bounce", no input, both speaker outputs switched & unswitched, headphones not affected (speakers disconnected) apart from background humm.
If the Bass Control is minimised/defeated, the bounce goes away. Bounce affected by either Bass &/or Volume controls.
Sound with a CD source, sounds ok, but with higher volume the woofer visually bounces.
Should I check the MKT type caps, re the bass & or speaker controls? Or is it something else?!
Help diagnose Sonic Gear 2.1 woofer no bass
Hi forum friends,
My first post here. I hope this is the right section to post.
First some info on myself. I am a beginner in electronics repair equipped with a basic digital multimeter, a 40 watt soldering iron and an esr meter. Willing to learn more if someone can guide patiently.
Last week when i switched on my pc to play some mp3 on this Sonic Gear speaker, i noticed the music is coming from two side satellite speakers but the bass(woofer) speaker no sound. Normally the bass will pump out some vibration. I fed dc3v to woofer speaker red and black wire at sp near cap c23, it had some speaker crackling sound. Fyi, the woofer speaker positive side is traced to 4th leg(output) of Tda2030 audio power amp at the bottom middle of img095833 while negative side is traced to yellow 104 cap at c27.
Using my dmm, i do voltage check at 8 pin op amp 4558 by positive red probe on pin 8 and negative black probe on center tap of transformer. Got 9.1vdc on both amp.
Another voltage check on tda2030, positive red to pin 5 and black negative to center tap transformer on all 3 pieces shown 15.7vdc.
I did 200ohm resistance test on those tda2030 by pin4 output to pin3 ground, the tda2030 near subwoofer speaker line showed 5.1 ohm.
Appreciate very much for anyone kind comment and suggestion on making the bass to come back again. Thank you in advance.
Great of value Q for equalizer
Hi all, I am new members here, and still learning about electronic circuit. I have plan to making a equalizer with 24 channels stereo (24 channels/mono). So I have problem dan confused to determine for value of "Q". Can u give me a suggests, what is the better value of "Q ' at +-10db for my equalizer? Or u have suggest a schematics for my project. Thanks a lot.🙂
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,756
Members
7,886,873
Messages
Filter
Forum Statistics
Threads
406,164
Messages
7,886,873
Members
507,756
Latest member
CalmRiver
