Opinions about cheap Ribbons >3k5 XO with a 3" mid
Hello,
The mid unit is a 3" ScanSpeak 10F 8ohms I'd like to XO no more than 12 db electrical at 4 K hz max.
My feeling is some ribbons could do the trick though I have a small budget, nearer to the Fountek's than Hivi's for illustration.
Now I know a better center to center spacing could be near 1.2 to 1.4 of the XO wave length for a dome or clode to the edge of a ribbon I also have the choice with cheapo very good dome, as some 22 mm and also horned ones by design or with a 3D party of shelves WG (Monacor, Visaton) or 3D ones as Augerpro's.
So the list is relativly big, but my feeling is a ribbon could be more forgiving with the XO I plan instead a dome.
Problem being is the design is monowired, passive. (the units are all 8 ohms)
Anythought on cheap ribbon models please ? Fountek neo 3.5 H for instance ?
It's true there are excellent dome also on my wisch list, knowing the spl should be around 86 db imho at XO with the mid :
Peerelesss NV19 non horned
Monacor DT-25N
SB26 CAC non horned
SB26STAC
Morel CAT378 (perhaps too short in the highs, but without Ferro ?)
DX25TG horned
XT25TG horned
Wavecore TW22WA10
There is no AMT, reading the good enough are outside of the budget.
If anyone have experience with the 10F and ribbons or tweeters of that list, advices much apreciated 🙂. Would like to stay 12 dB XO !😀
Scanspeak and Wavecor drivers for sale.
BNIB Scanspeak Discovery 18W/4434G-00 $100 for the pair.
BNIB ScanSpeak Discovery R2604/8320 $80 for the pair.
Wavecor FR090WA02 Fullrange, these are brand new and have never seen power but I did mount them in an enclosure which turned out to be too big for project. I can't find the boxes so $80 for the pair.
All prices are plus shipping.
New Prices.
Sony ST-SA5ES Front End problem
Hello to all fellow members and friends. Sony ST-SA5ES tuner came to my hands with poor sensitivity issue and after a re-alignment seems to corrected but still signal strength reports low levels. Looking around front-end circuit, I realized that IF level is too low and not clean 10.7 MHz wave. Unfortunately, SONY doesn't provide schematics of this Front End can. Is anybody from you faced same problem or has this schematic in order to investigate deeper? The P/N is 1-693-289-11. Also it is not available any more in known market places. Maybe someone of you has this available for purchasing.
Thanks in advance for your kind attention and help.
John
Marantz PM4000 Amplifier Muting after short period
After a period of between a few seconds, and a few minutes (sometimes longer) the MUTE light would come on after a click (speaker circuit disengaging), and the sound would go dead.
Please see attached pictures.
I presume this is some sort of protection circuit trying to prevent damage to the amplifier. What I found was that each speaker post had its own connection to the pcb, but each group of 4 connections had a central connection that connected to earth (I presume to use as a reference for the protection circuit). I noticed that on one bank of four this central earth connection wasn't seated correctly, and after reshaping it, pushing it in and screwing it up, it seems to now be working okay. It's been running for over 3 hours now without a hiccup.
The two screws that hold the 8 speaker connectors in place on the back panel, are what screw into the earth connection and earth it to the back panel.
Hopefully this info could help others.
I have no idea how it got like that, and think it must have been like that when I bought it (second hand).
Rob
ReVox B226, B226-S CD repair tip - (weak laser symptoms)
ReVox B226, ReVox B226-S CD player repair tip:
A fault that APPEARS LIKE A FAILING LASER is due to partial failure of IC5 on the servo board (IC5 = L272M op-amp), causes the player to be slow in track searching, have a noisy focus motor, and not read the TOC of certain discs, or lose focus towards the end of discs.
It's a $2 chip, worth replacing before buying a new laser assembly.
Complete novice alert! *don't read if easily annoyed by stupid questions*
Hello all. I just recently decided during lockdown to learn some basic electronics. I then found I just had to build myself an amplifier of some kind. I then found this Instructable: https://www.instructables.com/id/Make-your-first-Serious-Amplifier/ I have copied it as far as I can but am now stuck. I have followed the original version but used a blank pcb used some other ideas from someone else who has made this (at the bottom of the website). Basically I am stuck as to where the connection goes to V+. Also what happens at the potentiometer and the front switch. Can anyone help? This is a pic of where I'm at, but I don't know if it will help:
The two connectors in the centre of the pic are where the lines from pin 10 (V+in) and pin 1 (V+) come to. I don't know where these connect to tbh. Any help very gratefully received!
Building a Class Amplifier from Scratch
Hi everyone here..
I'm new here.. see my introduction then you know..
Building a Class A Amplifier from scratch.
Answering following Questions before you start. Here I talk about YOUR IDEA, not a design someone else posted on the net, or you find a finished circuit in some Magazine or likewise.
Questions should be as follows
1. Why Class A
2. How much can you spent on it
3. Are you conform with what it takes to build an Amplifier, never mind the class?
4. What the specs of the amp should be?
5. do you have the necessary tools to build it.
6. Do you have the necessary Computer Design and Simulation programs?
7. How about your technical knowledge?
8. Do you know how Class A operates versa Class B & Class AB - not Talking about the rest of Amps.
To build a decent amp, you need to be able to simulate and go beyond the regular designs. Today many Class A are sold which are in fact just AB amps BIASED with A Bias.
For me there are two Kind of Class A.
1. Single End Class A = this is an Amplifier where one Transistor per Stage making all the Work. Meaning amplifying the whole 360 degrees of the signal.
2. Push Pull where one Transistor amplifies the Signal and the Second one is the Current Source which enables the "Signal Transistor" to Work freely
The difference between Class A and Class B, respectively Class AB is, that a Class A Amp does not break the signal in two pieces.. Upper and Lower Signal
Class A is the only Amp where Distortion is the at minimum, where heat doesn't matter like in other configuration regarding Signal amplification, this only when the amp is designed well and the Working point of the Transistor is exact in the Middle of the Working field of that Transistor.
That the Sound of it is more close to the Natural Sound what you hear everyday. that the Amp reproduces the sound without coloring it.
The disadvantage is that you loose about 80% of the power. So if you have a Class A Single End Amplifier and you have a power supply with 0 + 50 Volts then the max Power you can expect to hear out of the Speaker are about 17 - 20 Percent. this means that you will get an RMS Voltage at the output of 10 Volts in the best case and only 8.5Volts in the NORMAL CLASS A Amplification scenario. So if you use Single End, then you are lucky if you get this 10 volts out, this would mean that you have about 12.5 Watts RMS @8Ohm, not yet looking at the Distortion which might occur because of so many reason like Components, layout of the PCB, Supply Voltage, etc etc.
Knowing all this I'm still going for Class A. Because if you really seriously do your job and giving your Best, consult the big guys if you get stucked, then success will be on your side. Then the next part of the story is what you do about the HEAT of a CLASS A. As the Amp burns Power away more than its able to deliver to the speaker..
In the days to come I will place some Schematics, PCB layouts and Building "instructions" which are necessary if you want to build a Class A.
Building Class A Amps you need to be able to Jump over you Shadow in sometime building something where all the world would say: na this never works.. but if you believe in what you do then I'm Sure that success is on your side. This is a small example. If anyone likes to see how the Amp looks like inclusive Specs and everything, then just ask. Developed by me. There is one resistor R2 10Ohm, its 200Watt.. the rest is all regular. this config has an output of about 12.5 Watt @8Ohm linear 10 -100Khz with very low distortion below .01 Linearity is +- 0.2 db over full bandwidth..
BTW I'm open for everything and with everything I mean I also can take Critics and all what comes with it.. Just let me know
Thanks for reading
Regards Chris
http://www.hecco.ch/pictures/class_a_amps/Class A - Double Stage Single End OP37 Amplifier.pdf
What am I?
Hi, lock down has provided me with the opportunity to work on a project I had been keen to explore for some time.
The task was to create an easy to drive "loudspeaker" of sensible efficiency that was flat in power response and FR across a wide horizontal angle that could be used from around 800Hz upwards. The components had to be currently available and with real world prices. Passive circuits were integrated into the design to produce the final result.
I would like to take this opportunity to thank the forum member who converted my circuit designs to gerber files and JLpcb for producing the boards.
The challenge is..."what type of speaker am I"!! For those interested I will post details later. No prizes except smug satisfaction for those who "guess" correctly!
I am posting the plot clues below. Just some supplementary info. The ARTA levels are not calibrated, I use Omnimic for that. Both programmes used the appropriate calibrated mic. The SPL level of 100dB was taken at the surface of the "driver". The distortion plots include the whole system as they are derived from the Omnimic V2 test CD. You will note the 2nd harmonic is around 1.5% at 100dB, (inaudible?) and the 3rd harmonic around .08%. The system includes RME DAC, KT EQPT "pultec" valve EQ, TL audio 5013 parametric, Rane 23s X over and relatively low cost cass AB power amps...EQ was flat for the plots and active crossover set around 1kH/24dB/LR.
The plot with the FR response and minimum phase is ARTA gated. THE BD and CS plot are derived from ARTA impulse response. The plot of just FR is "in room" at around 1m. The On/Off axis are 0,15,30 and 45H degree plots at 1m. The impedance and phase plot is created by DATs.
So..what type of loudspeaker am I??
HowTo: Etching a brass frontplate
Last year I struggled to mark a frontplate made from solid brass. The process involved countless tries and errors and turned into major project itself. Since I documented my findings in my private wiki, I thought it might be worth sharing them here as well.
The situation
I bought a diy-ed preamplifier on eBay that came in a custom made housing made only from solid brass. It was "untested" and completely unknown to me. The brass however sparked my interest right away so that I could not resist and bought the thing for little money.
The brass definitely needed some cleaning and polishing. As far as I could tell the scales and lables on the frontplate had been made with rub-off letters. It looked quite impressive, but unfortunately the letters would come off immediately when polishing the metal. In fact the brass would even need some serious sanding before I could even get to polishing.
I therefore needed a way to apply new markings and labels. Preferably something that would withstand future polishing and would not ruin the distinct look of the brass.
I looked into a whole variety of techniques including engraving, toner transfer, mod podge, laser engraving and what not. But nothing seemed to fit my toolset or expectations.
TL;DR
The solution I came up with involves a combination of laser etching and acid etching (just like we used to etch PCBs in days gone by). I own one of those cheaper Chinese Laser engravers. These are by far not strong enough to etch brass directly, but they are very well suited to remove a layer of etch-resistant in whatever form or shape required. The laser engraved plate is then etched in Ferric Chloride. Lastly the etched engravings can be filled in with lacquer or color of choice.
The template
I started out by designing the complete frontplate in InkScape. Since the markings had to fit the already existing holes, cut-outs and knobs, this step required a lot of measuring.
Next I printed the layout on transparent slides (as used for overhead projectors) to verify the alignments.
The transparent foil also helped a lot to mark squares around the individual elements to assist in positioning the laser.
Since my Laser (an Ortur 20Watts) has a limited working area, I could not engrave the whole plate in one go. Instead I had to move and align the laser after every element.
Positioning the laser is always a bit tricky, since the only way to "preview" where the laser will be firing is by outlining the shape with ver low power output.
The Etch Resist
Now it was time to apply an etch resist to the plate. An etch resist is simply some sort of protective layer that keeps the acid away from parts that we do not want to etch. The easiest way to apply etch resist is to simply spray paint the part with acrylic paint. I decided for black paint, as black is the easiest color to laser - it simply absorbs light the most. Nevertheless I had to test several brands of spray paint, as some of them don't adhere to brass very well or are not as "resistant" to acid as expected (some can be easily peeled off or crackle after drying, which would allow the acid to flow in from underneath). I found the spray paints from edding to work really well and also some no-name can from my local store turned out really good.
Great care must be taken to cover really every tiny spot in paint. Don't forget the edges and insides of holes and cut-outs. Every bare spot of metal will be etched away if not properly protected. Little spots can easily be corrected or improved with an edding pen (the ones containing actual lacquer and have that metal ball you need to shake before using it).
For the backside of the plate I simply applied generous amounts of overlapping packaging tape, which also makes for great etch resistant.
Activate Lasssszzzer
Now it was time to engrave my layout into the etch resistant. The laser basically burns away the spray paint and reveals the bare metal where we want to etch. Finding the right settings for the laser was another lengthy process. After some tries I found that the following worked well for me. The settings will very likely be different for another laser and other spray paint:
  • Speed 500mm/min
  • 90% power
  • 2 passes
  • 1bit b/w dithering pass-through
Even if you don't happen to have a laser at home, you can still remove the resist by any other means. You could even scratch it off by hand in your own writing or create a stencil. The possibilities are countless from hereon.
The Etching
Time to actually etch the brass plate. After a few experiments I found that about 10 minutes in Ferric Chloride create the desired effect. Any shorter period will result in lower engravings that cannot be filled with color very well. Longer than 10 mins and you risk to loose details - fragile letters like 'A's and 'e's will become unreadable.
The acid was less problematic to handle than I first anticipated. Just make sure to wear rubber gloves and eye protection. All materials involved should be acid resistant of course. Just don't poke around with metal or organic parts and you'll be safe.
It helps a lot if you warm up the ferric chloride before using it. If you have the possibility, you could also heat the acid bath during the process - for me it worked just fine without.
I kept the solution in motion by gently stirring with a (plastic!) brush over the plate from time to time. Make sure that no bubbles accumulate underneath the plate or in hidden spots.
After the etching time is over you need to neutralize the acid to stop the etching process. I simply purred normal baking soda over the whole plate, which works just great. Keep your neutralizer always at hand if something goes wrong during the process.
Remove Etch Resist
After the etching is done a nasty crust of neutralized ferrit chloride and etch resist has to be removed. Start by carefully washing and brushing the now crusty baking soda of.
To remove the spray paint you will need something stronger though. Universal paint thinner should do the trick to disolve the spray paint. It is quiet a mess though and should be done in a well ventilated area. Also make sure that you have plenty of paper towels at hand, since you will need it in great quantities. Initially I expected the acid etching to be the messy part, but removing the paint was by far the greater hazzle.
See below a close-up of the etched scale:
Now is the time to give the brass a good polish. The best polish for brass that I found so far is "Autosol", which I happily recommend.
Filling the Engravings
You can either leave the engravings as they are or take another step and flood fill them with color of your choice. The engraved areas will darken (faster) then the rest over time, which can also look appealing. I decided to fill out all writings and leave the scales as they were.
The filling is quite simple in theory: you pourr plenty of lacquer into the engravings and sand or polish everything plane after the lacquer has dried - leaving only the etched areas filled with paint. The practical application was again not that easy though and required once more several tries. Some of the paint I tested did not dry "hard" enough to be sanded. Other sorts of paints or lacquer attracted dust from the sanded brass parts, which again looked ugly.
The best results were obtained by using the same lacquer edding pen I used before as an etch resist. I painted several times thick layers with the pen and then used plain office paper wrapped around a block of hardwood to "sand" the excess paint off again. Professionals apparently have special filler paint or waxes for this task, but I was happy with the results I was able to generate with household items.
Finishing Touches
Lastly, I wanted to preserve the shine of the polished brass. It took again many tries (involving Zapon lacquer and the like) until I was recommended "Renaissance Wax". That wax seems to be used a lot by watch makers and was originally developed by the British Museum to preserve all kinds of materials without damage. It is a bit costly, but the smallest can will last you live time and is definately worth it. Just apply a very thin coat of the wax and you will not have to polish the brass for a long time. Even the frequently touched parts, like poti knobs, still look great.
I hope this write-up will be of use or inspiration to someone. 🙂
ultra low noise psu from China
hi,
I hope you are all well,
I bought this low noise PSU from China and made schematics for it,
could you please have a look at it or check if the design makes sense?, quite often China boards are criticized.
any suggestion to improve it?
best
KR.
....there is a mistake in this schematics!,...sorry my mistake,...please look at post *12 with an updated and corrected version.
Philips NE5534 opamps
WTB: Philips NE5534 opamps
Some of these were recently offered and bought here, so I thought I'd try.
For some projects I am looking to buy a couple of pairs (whatever anyone has and wants to part with, really) of genuine, vintage Philips NE5534 opamps. Doesn't have to be NOS - no problem if pulled from something equally vintage. Signetics would work too, but preferably Philips.
Soundproof door advice
I'm looking for advice in building a "soundproof" door between my basement listening room and the utility room which has the washer & dryer along with the furnace. The opening is aprox. 6' x 4.5" and currently doesn't have a door.
Because of space available I won't be able to use a hinged door it will have to be a sliding door.
I thought about screwing multiple sheets of plywood together but I'm not sure if warping will be a problem.
The top of the door will be almost flush with a HVAC duct so I can't use sliding barn door hardware to hang the door. My thought was some type furniture glider on the bottom of the door.
Any ideas??
Thanks in advance!
Scott
3D printing knobs and potentiometer extenders
Using FreeCAD ( FreeCAD: Your own 3D parametric modeler ), I designed a potentiometer knob and a potentiometer shaft extender for the preamplifier I am building. The models are parameteric so that you can change the shaft diameter, flat size, etc. for your particular project. I have included STL files for a short extender that works with standard 6 mm diameter potentiometer shafts and knobs.
  • potentiometer-CAD.zip
Crossover board Accuphase F-20
Hi, I have a Electronic Frequenzy Divider from Accuphase ( F-20 ).
Who comes with different crossover cards, 70-12000Hz.
I have 100Hz, but with old filter I crossed at 200Hz.
So I can by the 180Hz or 250Hz card, think the 290Hz is to high.
The crossover is between Seas Excel W26 (10inch) and Seas Excel W18EX (6.5inch).
OR!! is it just to swap the resistors/caps in the 100Hz card to get even 200Hz?
And using only the 24db alternative only few comonents has to change.
Enyone have a ide how to find the value of the components for 180/200 or 250Hz?
Frank
Colour code ?
I’ve just taken my new power transformer from Monolith Magnetics out it’s box .. and there are a bunch of wires protruding from the base , as expected..
However there isn’t any identification on the wires ..
3 x green 1 marked with black
2 x red
2 x black
1 x Blue
3 x pairs of marked white ..
Is there a standard colour code for power transformer wires ?
High power class AB amplifier rectifier circuit
Hi! I come across a highend Japanese amplifier, the power transformer is center tapped, normally we only need to use 4 diode to get the dual supply like the circuit below:
951515d1620974448-power-class-ab-amplifier-rectifier-circuit-12v-dual-power-supply-circuit-diagram-png
This amplier's dual supply rectifier circuit use 8 diode:
951516d1620974448-power-class-ab-amplifier-rectifier-circuit-capacitor-pcb-png
This circuit connected to a 3KW transformer.
May I know what is the benefit of this circuit?
Thanks.
  • Poll Poll
VOTE: Who is seeing the strangest/best/weirdest amps around these parts?
Who has the best/weirdest/strangest/rarest amps in their repair stack?
  • Dr Zeus
    Votes: 2 28.6%
  • Perry Badin
    Votes: 2 28.6%
  • Miniman82
    Votes: 0 0.0%
  • Achim1409
    Votes: 0 0.0%
  • mnhiphop101
    Votes: 0 0.0%
  • jeff5may
    Votes: 0 0.0%
  • silversweden
    Votes: 0 0.0%
  • OTHER (Post below who you think?)
    Votes: 3 42.9%
Just a check here. I've been combing through the threads and my own amps and decided to post something a little 'fun' for us amp fixers. SO, who would you vote for on this forum; who has the strangest/best/weirdest/obscure amps being repaired/collected?
Have fun!
First 2 way speaker
Hello,
This is my first time designing a two way speaker with bass reflex, I have made a couple of full-rangers in the past, but this is my first time trying to put together a crossover.
The drivers I am gonna use is a dayton audio TCP-115 4ohm and a dayton audio Dayton Audio ND25FA-4, in a 4 liter box with a slot port tuned at 57hz (i wanted to make it a bit smaller but i couldn't really.
The crossover is a 3-part one or the tweeter and a 2part one for the woofer. I am trying to keep cost down since i wouldn't want for the crossover to cost more than the drivers.
How does it look to you, should I change something? Would i need a baffle step correction filter ( baffle width is 20cm)?
Help trouble shooting Sanyo Plus 55
I have a left channel distortion caused by my hand slip. The signal looks good going into the amp circuit, 1khz sine wave. At Q701 (2SA798) it starts to distort. I replaced the 2SA798 with one I got from eBay and it may be bad. I pulled all of the other transistors in the circuit and they check ok using the diode and hFE functions on my meter. I was a licensed tech 40 years ago but it is really just a hobby now.
Here are photos of the scope readout and that part of the schematic.
This is PIN 1, 200mv
attachment.php
PIN 2, 2.8v
attachment.php
PIN 3, 130mv
attachment.php
PIN 4, 2.7v
attachment.php
PIN 5, 130mv
attachment.php
SCHEMATIC with numbers, "A" is the left input from the preamp.
attachment.php
ak4497-ph-2.1 schematics, improvement
Hello,
I see there are several AK4497 topics, but not with this board and I would have specific question on this board.
I am just eperimenting with an ak4497-ph-2.1 board and found I probably want to improve the output.
Not bad as it is. I compare it to my AD1865 based, resistor I/V than transformer, than tube output dac.
This chinese AK4497 board has the details, the solid, precise base, clear highs, wide and deep sound stage, The difference is, the AD1865 is more easy to listen to. I can not describe exactly why, but especially on classicals, violin, I prefer the AD1865 based dac.
I think the AK4497 has the potential, guessing the output should be improved.
Do you guys has a circuit diagram for this?
First of all, I do not need the differential output, second, I do not need this big amplification. I will probably short the relays also.
But, it would be much easier if I have schematics.
Do you guys has any advice for this?
Thanks!
JG
Converting an old radio into a standalone stereo speaker
Hello
Few days ago I got my hands on an old Marconiphone 282 radio. Sad thing is, all of the original insides are gone so there is no chance of restoring it without spending way too much. So the idea is to convert it into a BT stereo speaker to go into our summer house bedroom corner.
I'm planning on using Dayton Audio KAB-250v3 amplifier, because it seemed to be good for a beginner with its modular design. Also, the reviews weren't all that bad.
For speakers I'm thinking about Visaton Fr10-4s.
Do you think these components work with the case? How would you suggest I mount the speakers into the case so they would work as well as they could? I was thinking about using the shelf in the middle to build a mount for the speakers. The width of the opening in the front is 18cm, and it is around 30cm wide total. Also, the case is open-back.
Snell JII replacement tweeter recommendations
So the coating on these fabric dome tweeters are pretty much "see through." So I'll need to find some replacements.
(No I don't want to try a DIY coating.)
I understand these are 1" 4ohm and manufactured by (long gone?) Tonegan.
The faceplate is 94mm, and having trouble finding that.
Thanks in advance.
Dan
AMP must output sine wave when open loop
For the sound quality the audio power amplifiers must output sine wave when open loop and 4Vp-p input , I have testing the +_70V and +_85V AMP drivers , Open loop X27/X3=9 is better sound and more detail like tube AMP, It' is 3W only.
+_70 Driver open loop Vcc2 is not enough :
+_85V driver Open loop X27/X3=9 is better
1KHZ:
20Khz:
100KHZ:
Now the transistors AMP and the tube AMP are the same sound quality, and the transistors amplifiers can out put 1HZ to 20Hz audio signal.
And the Vcc1 are regulated when Vcc1*Ic(2SC5200/2SA1943)>=(Max output voltage)*(Max output voltage)/8 Ohm(Speaker impedance) , This is new rule that I tested.
TU-8500 part question - 7 Pin PCB mount
Hello Everyone.
Looking for a bit advice and maybe someone has done this already? I want to add a second CN2 7-Pin socket into the PCB.
Currently i am doing the expat thing and living in Germany. One day we may make the final move back to the land of the Big PX and I want to future proof this pre. Does anyone know the part number that matches to CN2 7-pin? Something i can order from one of the big electronic parts stores? I went down teh rabbit hole at mouser and found too many plugs to make a safe guess.
Warm regards,
Erick
Small power (<10W) audiophile class A ?
Hello,
I'm looking for a high-quality, low distorsion, low noise, proven, hassle-free, solid state (FET ?) class A amplifier for quiet listening.
I never listen loud and my setup is near-field so I need only little power, I think even 1W would be enough. It should be used with Audiolab M-DAC as DAC and digital preamp. It can be both stereo or mono blocks.
Thanks in advance
Dayton Audio iMM-6 False Response Rise from 200-20K
I'm very new to this world, but I recently installed a DSP for my car audio system.
I was noticing my LPFs were not showing reactions in REW when measured, but I could hear the difference.
I'm using a Dell laptop with a single headset jack, and set it to headset when plugged in.
I'm using the line out port on the imm-6 to send the audio to my HU.
Problem is, regardless of any audio signal or not, the microphone will report back a linear response from 200 to 20K.
If I unplug the line-out and use the laptop speaker (or when muted as well) the false response goes away.
Makes it really hard to tune here...
Any thoughts/help?
CS4398 output filter
I'm looking at the output filter recommended in the datasheet and I notice it's the same two pole type of filter recommended in the AK4396 datasheet. There's a few differences, apart from part values, the CS4398 circuit has two caps to ground instead of one between the outputs and there's an extra 100uF cap in series to ground with one of the resistors. What does the 100uF cap do in this case? I simulated both and they perform very similar with 2.4k replaced with 2.7k (from the AK4396 datasheet). The AK4396 values are more BOM friendly. Any reason to go for the one in the CS4398 datasheet instead of the one from AK4396 datasheet?
For some reason in the simulation when I add the 2.5V offset to the one on the right it doesn't work right.
Also another curiosity is the high DC blocking cap value, at 22uF. For 100k it would work pretty ok with 2.2uF, maybe 3.3uF. At 2.2uF you'd loose 0.13dB at 20Hz. I think that's absolutely fine considering that would allow for other types of caps not just electrolytic.
FS: Custom built Objective2 amp with agdr 'boosterboard'
This is a commercially built Objective2 amp with the agdr 'booster board' which enhances the performance of the amp, significantly increasing output current capability and reducing dc offset amongst other improvements.Booster board additional info:O2 Booster Board
There is a discussion thread about it on this site.
agdr tuned the gain to my requirements by creating the voltage divider at the inputs, resulting in 0.67x on Lo gain (good for my sensitive IEMs) and 3.4x on Hi gain (works fine with a 2V RMS DAC and my 250Ω Beyers). Gain can be tweaked to your needs (as agdr did for me) by changing 4 resistors and two caps. agdr installed sockets for the gain switch R's so they can be changed without soldering (the booster board does make them hard to get at, however.)
Included but not shown are the 12VAC wall wart; ~$40 worth of Mouser parts consisting of replacement and upgrade parts; soldering and building supplies (battery iron, flux remover, solder sucker, tools etc). I think my building days are over. There isn't much in the way of turnkey kits á la Dynaco/Heathkit and I don't have the motivation, tools, or skills to take on something like the Whammy which lacks switchable gain (something I find very useful) and also requires the builder to 'engineer' and (to an extent) fabricate the enclosure.
Shown but not included are the batteries agdr was using for his bench testing.
Asking $100 + actual shipping cost (The booster board alone was $129). Get the amp everyone loves to hate- only better. Paypal and Venmo accepted.
Single TX dual power supply
I am building a stereo power amplifier and plan to use a single transformer with dual secondaries.
Each power amp board will have it's onw rectifier bridges and smoothing capacitors.
As the transformer has dual independent secondaries, I am using two bridges (one for V++ and another for V--)
As it is a stereo power amp, I will have four bridges total.
My question relates to the way I am planning to connect the single power amp to feed both amp boards in parallel.
Can I simply parallel the two positive bridges and the two negative bridges in the secondaries of the TX without fear of GND loops ?
I am posting the schematic of the PSU hoping for comments on possible issues and solutions.
Troubleshooting Pascal SPRO2 module - no sound.
Pascal SPRO2 module - no sound, update: In protect mode
Hi guys,
I have got a RCF Subwoofer 905-ASII with no output. The subwoofer has got the pascal Spro2 module. I understand that there aren't any available service manual/schematics for the module. I couldn't find any obvious faults like shorted FETs etc.
I have ruled out the input/dsp board which is made from RCF by plugging that into a working subwoofer.
Any ideas on what to look for? I have a feeling the it might be that the mute signal is on. I couldn't find a testpoint to test it, and I couldn't find the pinout for the 26 connector either.
Your help would be greatly appreciated 🙂
Malfunctioning VRDN…
So here is a VRDN out of a Wayne‘s BA2018 linestage, that seems to be… not working?
Symptoms were a dead channel and loud hum, when replaced with an identical build into the same setting, the line-stage is brilliant again…
My problem is that the PSU looks perfectly intact, and the measurements are spot-on and stable like a rock…
To isolate the problem, do I look after what and where?
Thank you
Rockford Punch 40DSM
Im a little stumped on this amp. Powers up but will not play audio at speaker terminals. Bias is not working at all for either channel. Right channel stays at 0vDC across emitters and no amperage change no matter where I set the pot. Similar on the left channel as there is no controllability, but sometimes it will have some voltage across emitters. Left channel seems to have some floating vDC on it, sometimes.
First I changed out all the 10uf caps on the main board as they had some leakage. Then I wicked and re-soldered all driver/ridsing boards.
Voltages look to be -ok- on the legs of the outputs. I see good rail and regulated voltages, but the left channel seems to have vDC of drift on the speaker terminals. Maybe 1vDC.
Mostly the amp will draw 0.25A, other times it will draw more like 0.75A at idle. When it draws higher amperage, the left channel voltage across emitters goes up to 0.005vDC or a little more, even with the bias pot set to full CCW.
I looked through he 200DSM page and tested all the components highlighted on both of the driver boards. The driver boards this amp is using are identical to the first two large images of the 200DSM page.
Any clue to what I may be missing? Im thinking this amp is muting, but the voltageDC and bias is I believe my first step.
Hitachi SR-804 bad right channel
I’ll do my best to describe this problem, in the hope that someone can advise what the problem might be.
I’ve owned a very clean (and brilliant) Hitachi SR-804 for around ten years now, and over the last couple of years it has developed a strange fault. The right channel on the amp will run fine for, say, ten minutes a time then right channel VU meter will start flicking up and down the scale like mad whilst a very loud, sub bass sound will be produced through my right hand speaker. If fact, the first time this occurred it blew the driver in my right speaker.
The amp is a US model, I use a step down transformer to use it with UK current. I’ve checked the channel fuses inside the amp, both seem fine. I’ve tried all manner of cable changes, changed the step down transformer, switched the speaker wire etc and it always comes through in the right channel.
The amp will produce this fault whether or not there is any audio going into the amp (ie. the turntable or aux playing any music) and is unaffected by volume/tone controls, switches etc. The VU meter for the right channel will also flickering wildly whether or not the amp volume control is turned up or not.
I’m stumped, I’m sure solving the issue may be beyond me, but I’m trying to ascertain if anyone has experienced a similar fault and what the issue may be before I am concerned with getting it fixed or not. Of course, I’d like to, but if it’s an expensive fix, this may be beyond me at the current time.
Any help would be appreciated.
John
Aikido pre for ss
I wish to build an aikido linestage. Since I already have a tubedac with 3volt max output. I do not want to much gain. 12-15 db gain is what i am looking for.
It will be driving a solid state power amp. so no too high impedance.
I know that 12au7 tubes have a gain off 12 db. is there other factors that makes the total gain of a preamp?
And how is the reletian between input tube and output tube?
How do I calculate ore at least have an idea about what my impedance is.
I hope some one can help me ore give me some useful links.
Generic Chinese CLASS D full range ISSUE
Hello everyone.
I have this class D full range amplifier (in my country it is marketed under various brands, diaboliko, ipnosis etc).
Unfortunately the amplifier presents problems on only one of the two channels.
One works perfectly, the other shortens the entire amplifier.
The 8-pin integrated near the output mosfets is an irs2011 and is driven by the "FDM04-RC" driver board of which I have found nothing on the internet.
By doing some tests, I found the linear regulator to be short with the relative zener diode, which I promptly replaced.
I also replaced the open gate resistors and also the irs2011.
Unfortunately when I install the new IRS2011 (without output mosfet) the amplifier goes into protection.
If I remove IRS2011 and control at input pins 5 and 6, there is nothing (no waveform injecting signal into the amplifier) ​​while on the working channel, on pins 5 and 6 of IRS2011 there are two beautiful square waves.
Does anyone know FDM04-RC?
All ICs on this driver board are deleted.
If someone knows a scheme or at least the component codes, I could try to understand what happens.
Best Steps for Jitter Reduction for an Philips-SAA7310P based CD Transport/PCM63P DAC
A friend have read this:
A Transport of Delight: CD Transport Jitter | Stereophile.com
He use a MICROMEGA SOLO only as transport (from first editions) and two DACs - a diy DAC on Burr Brown's PCM63 Demo Board - go to
B-B PCM63 Demo Board as DAC...any Mods?
and a Pass "D1" clone" similar to this:
PASS Labs - D1 - Familie Witt
very special here is the I/U converter
D1 IV Mosfet
sound quality is approximately on the same level (not on the same character) than Ultra Analog' D20400.
Passlabs D1 (PCM63) vs. Threshold DAC-2 (Ultra Analog D20400a) - who have heard both?
Currently operates the transport in standard configuration; i. e. SAA7310/PCF3523 in the PCM decoder and S/P-DIF transmitter section - go to
https://datasheetspdf.com/pdf-file/274390/NXP/SAA7310/1
and post #11 under
Help me I need MAB8441 PCF3523 PCF2705 DataSheets
for block diagram.
The currently equipped master clock (genuine equipment) consist only of the integrated oscillator from SAA7310 so as the crystal-quarz (X-TAL) with 11.2896 MHz.
The outdoor D/A converter works with DAC PCM63P,-K (2x) DF1700 and S/P-DIF Receiver
CS8412, go to
http://phonoclone.com/pdf/cs8411.pdf
and a second device on Burr Brown's demo board with Yamaha's YM3623 - go to
https://pdf1.alldatasheet.com/datasheet-pdf/view/103367/ETC/YM3623B.html
Both SPDIF receiver IC haven't own master clock and works with the integrated clock recovery.
Follow options are comes in mind for jitter reducing steps:
1) Adding of master clock unit in the CD-transport as replacement for the presently quarz generator, e. g. LClock "XO" from LC Audio - go for images and schematic to post #8 under
Clock Generator for Cambridge Audio DISCMAGIC1/CDT - Adjustment Instruction for VR1 ?
This is the first version of
https://www.lcaudio.com/index.php?page=4
2) Adding of same master clock unit in the DAC (at DF1700 X-TAL input) as replacement for the presently used integrated clock recovery (i. e. master mode operation with additional coax connector on the CD-transport and additional coax lead therefore) This eliminates data-related clock jitter. Was realized on Linn's DAC "NUMERIK" - go to
https://docs.linn.co.uk/wiki/images/c/cd/Karik_numerik_user_manual.pdf
3) same as before (like No 2) but include reclocking BCK and WCK going to PCM63 with help of an appropriate circuit extension - go to
Reclocking balanced PCM63
If a master clock frequency of 16,9344 MHz in the DAC is necessary, also a conversion circuit (PLL) to 11,8296 MHz is necessary for the Philips based chip-set (SAA7310/PCF3523) in the transport, or 33,8688 MHz clock with a 1/2 and 1/3 clock divider circuits - go to
and
https://www.lcaudio.com/index.php?page=38
Maybe there are other resp. further options.
Thank you very much for advices
Nakamichi OMS-5
HI
I would like to ask for help .I have these Nakamichi OMS-5 cd player , unfortunatly does not read .It will need to replace the lasser pick-up.
If somebody has experience with these player please let me know WERE I can buy new laser pick up or were I can find help to fix it .
Unfortunatly I have the part number but is imposible to read the numbers on the laser ..
Thanks for any help.
Pros and Cons of two different Clock Generators in a CD Player
There are any few CD player models with only one master clock generator (responsible both for MCU for control unit/operating keyboard, PCM decoder and DAC).
Examples are Cambridge Audio's models from 1993-1996 (CD-4/Trac-1, CD-6, CD-T, DiscMagic), and TEAC's CD-P 1100 (all equipped with SONY's operating MCU CXP1011Q).
Most of cd player models uses an extra 6 MHz clock generator for the MCU for control unit keyboard and display driver who works independent.
What are the pros and cons of both approaches and what of them provide lowest jitter results ?
Thank you for clarifying and sending links to appropriate papers concerning this topic.
Fluctuating B+
My El Cheapo-ish amp has a low frequency, say 1-4Hz (>10mV) variation over the power tube grid leaks when no signal is applied. It's not a single frequency, but some chaotic low frequency up-and-down-thingy (it doesn't look like an oscillation to me). The ripple/hum is ~ 1mV. In order to limit the number of variables I have pulled the output tubes.
It seems that the B+ is also fluctuating.
The amp sounds ok to me, but I haven't got a good reference. OT output seems ok on the scope. Is some common mode rejection helping me out?
Non the less, I would like to solve it, or at least understand it.
What could be the problem?
918509d1612383335-european-el-cheapo-ish-build-elcheaposchematic-png
Part of my problem is that I still don't understand how an LTP with a CCS (with B- below 0V) works, despite searching online and reading Jones' book. Normally 'everything' is referenced to ground, but the LTP has no idea where ground is as far as I can see. As long as I don't understand that, I can't reason about it and don't think I will be able to tackle this problem.
GZPA 1.3000D low sound output
This amplifier got a very weak output power on the speaker terminals.
The output fets are driven 100% fine, the amp pulls a little 2.20a on 14.4v.
- Photo 1: 50Hz music sine wave on RCA connector. Scope set to 0.2v/div and probe on 1x
- Photo 2: 50Hz music sine wave on the INPUT pin of the main driver board. Scope set to 0.2/div and probe to 1x. (Seems like a very low amplitude right? Can somebody confirm this?)
- Photo 6: You can see a red dot on one of the vias of the main driver board. This is the vias measured at photo 2.
Did somebody have the same problem as well?
Going full Downey Jr. with the TDA8932/ A Cautionary Tale
TLDR: If you have extremely sensitive speakers the first watt is phenomenal-- there is magic in there. There is significant and noticeable distortion when these are pushed to what I consider normal listening levels (loud) on 88db-ish speakers. I moved on to a TI TPA3220 EVM after these mods and it blows it out of the water in every metric. But costs 10x as much.
Disclaimer: this is a hobby and I find it fun to futz and all of my testing is done by subjective listening, take it with a grain of salt.
I tried to get every ounce I could out of these little boards after being pretty turned on by their stock setup-- I find them preferable to the 311x series and still do, warts and all. After much trial and error this ended up being the best sounding set of tweaks to my ears:
-Dual Meanwell 28v/5a SMPS with Full Wave rectifiers for each board (This is sort of my default power bank for testing boards)
-3x3300uf caps for primary DC input (yeah yeah inductance)
-0.68uf WIMA input coupling caps sounded best to me (the pics are different caps, try your own!) it's important to make sure the negative terminal coupling cap is attached to the PCB between PIN3 and the ground plane soldering location that the SMD cap was removed from. Will not work if connected directly to your negative cable, though positive (signal) will just fine.
-Set one board as MASTER and the other as SLAVE by putting a 39Kohm resistor between PIN32 and PIN10. Set the SLAVE by connecting PIN33 between both boards. This had the most dramatic ROI of any alteration.
-Replaced the output LC filter with various types, the best being 15uh/.68uf to my ears and mood. This is fairly simple to do and probably second best ROI if you're interested in playing with these boards.
I agree with danielwritesbac's assessment that there is some old school transistor vibe to these chips. That 70's Sansui/Marantz lushness is there, like a pantyhose filter on a camera lens. Very listenable. You stop caring about the set up and start enjoying the music.... then you turn it up and disappointment kicks you in the teeth. Especially because, for me, these sounded terrific with rock such as The White Stripes and Royal Blood. The 8932 just doesn't have the guts before very noticeable distortion cripples the fun. I haven't looked yet because, well, time and life, but hoping NXP has an offering with a bit more muscle in the same family. If they don't wish they did. (Just looked, seems they do, the 8954. Boards are $50. Got the 8932 for $3.50 ea., if you want to pay around 5x less a lot of people will be happy with the 8932. It's a the audio equivalent of a Civic with a few simple mods.)
All of my testing is done with the same PSU, TONE1 DAC and either a PEC or ALPS 20K pot. Moving on to 3221s/3225s!
Subwoofer clicking
I have an active subwoofer (Accusound, Australia) that is clicking about once per second. Doesn't amplify the sound/make any sound, just clicks, I don't think it actually stays on if for a second, or I haven't heard any bass from it. Sometimes if I leave it clicking for an hour it will click on and stay on, but mostly now it just keeps clicking.
Any ideas what it is? Is there a possibly fix? It has one of those automatic turn on circuits when it detects a signal. Can relays be changed? Or am I looking at a fault like transistors?
I'm hoping there's either a fix or a bypass to leave the amp on 24/7 (I'll just turn it on manually for movies).
Thanks.
If it's dead-dead, in Australia - Any recommendations for an active subwoofer either store bought, or one I can make? (I have a CNC router) Preferably under $300ish (yes I know that's low but I'm on a low income sadly, hoping for a good budget option like the accusound was).
Does anybody recognise this driver?
I have salvaged two 5" drivers from a Polycom Cambridge Soundworks Subwoofer - C1PLY24R.
Does anybody know where I could get any info on these drivers. I was tempted to get rid of them but original system cost a fortune. If they're any good I might use them in something.
World's Best Midranges - Shocking Results & Conclusions.
Ok.
Where to start? Let's start by the beginning, which was 1 year ago when i started that thread:
World's best midrange Blind Testing - Need your help.
Now, 100+ pages and 65,000 views later i've come to some conclusions that are... uhm... well: :spin:😱:no: (in any order)
So, last year the original goal was simply to organize a blind test of midrange/fullrange drivers and find the best ones. Pretty straightforward.
Then, preliminary tests showed that it WON'T be that simple. Nope.
It seemed that, once blinded, it's much harder than we thought just to identify said drivers.
So i did what i had to do: push the organization of the whole thing on a more serious/scientific level. Took time and planifications, and then more adjustements and trials, etc... Bottomline, you can read the 100+ pages to understand the whole process if you want, but basically the conclusions (so far*) are the following:
1. Auditory capacities of humans are massively overestimated by audiophiles (and probably by most humans as well)
2. Frequency Response is King.
3. Once EQ'd, a 10$ midrange can mimic a 1500$ midrange, if within mechanical/electrical limits.
4. DSP/EQ/in-room measure tools might be the best investment an audiophile can make in our era.
5. Others will have to continue spending hundreds and thousands for a natural uncorrected FR.
*so far, because for the sake of statistical validity, i'll continue with the blind test on more participants.
Here is the results of Matchup #1
World's best midrange Blind Testing - Need your help. - Page 115 - diyAudio
That is the easiest and most forgiving drivers matchup i could find. In fact, as you can see in the thread, i had to ''cheat'' with ½ octave difference... Expected success rate was very high.
(will be updated with most recent results)
As of 27th august 2016:
45 successful trials out of 61 (74% success rate)
3 successful participants out of 6 (50% success rate)
LM3886 with oscillation @ 30kHz
Hi guys,
I'm currently working on a project that involves the LM3886 as power stage.
A pre amplifier based on TL07x, a tone stack with same opamp and final the powerful LM3886. For reference the schematic is reported in attachment.
First of all: it works perfectly, the volume control is ok and tone too. 🙂
But I'm facing a major issue: at the output with an oscilloscope I can measure an oscillation (2Vpp) with a frequency of 30~31kHz.
The circuit is implemented into a 2 layer PCB, the ground is well routed using ground planes (power + signal) and a star connection with the power supply.
The power supply is linear with just a bridge rectifier and a couple of electrolytic capacitors.
Taking into account the schematic, is there something that can be causing this oscillation? Maybe some component that requires special care to the surrounding layout.
BH EL-34 GBuy#2, 12AX7 tubes
I am not going to build this project, so I am selling my 2 Baby Huey EL34 pcb’s from Group Buy 2. These have the PS on board. I have most of the recommended BOM parts from Mouser for stereo as suggested by Marc (bandol83).
The parts I am missing for the stereo build are as follows:
2 x R13 - Vishay CPF 247K, 39Kohm - 2W resistors
2 x noval (B9A) sockets, sku17658
2 x R33 & 2 x R38 Vishay MBB02070C3900F 390 ohm – 0.5W resistors
2 x C6, Nichicon LGL2G221MELA25, 220uF, 400V caps
2 x C7, Nichicon UPZ2G101MHD, 100uF, 400V caps
X1, 5.08mm headers or contacts, FCI20020316-H05
X2,X3,X4,X5,X6, 5.08mm headers or contacts, FCI20020316-H02
No V2 – output tubes.
All the above for $130.00 USD.
V1’s – ECC83, 12AX7, please see my NOS stock below. “ I am not a tube aficionado so here goes:”
I have a set of PSVANE 12AX7-T. Test new, Sections match. Measure 38/37 & 39/38. They pass GM, H-K leakage, Gas and overall grade is Premium grade A, tested on Amplitrex AT-1000. ($60 USD / pair)
Set of Russian re-issue TUNG-SOL 12AX7 Test new, Sections match. Measure 114/113 & 115-114 there is 2 other numbers on the box that look like B- 56 & M 55 and B- 55 & M 54. ($30 USD/pair)
Set of 12AX7 Groove Tubes, Test new sections match ($30 USD / pair)
Set of Russian re-issue Mullard 12AX7, Test new, sections match. ($30 USD / pair)
See pics below: PSV in box, PSV data, TS, GT, Mullard
I would like to sell the BH pcbs, parts, and as many tubes as possible in 1 kit.
If a person wanted everything listed, I would let it go at $260 USD. Shipping & likely tracking is on the buyer.
PM me if interested with a postal code, and I will figure shipping costs.
Thanks,
Myles
Selling my Pass DIY Stack - Moving Sale
I am moving and have to downsize on equipment so I can put money towards my new house. All of these items have been built within the last year and a half and are currently setup and in use right now:
- BA3FE Preamp - Kubota PSU, Genuine Toshiba Jfets, Glassware A3 Stepped attenuator, Glassware Select, Clarity Caps, 3 inputs, 1 output 1 Tape output (used to HPA) - Asking $450 Plus Shipping
- Pearl 2 Phono - Toshiba JFets acquired from PassDIY. Set up for MC cartridges. Currently using with Dynavector 10x5 and Denon DL-103 - Asking $600 Plus Shipping
- Whammy Headphone Amp - Asking $350 Plus Shipping
- Noir Headphone Amp - Asking $125 Plus Shipping
- F6 Amplifier - 60,000uf per rail, AS-4218, Genuine Toshiba JFETS. Asking $850 Plus Shipping
- Two F4 Amplifiers (not pictured) - Genuine Toshiba JFETs, both units are completely matched, XLR inputs included - SOLD
Sticking with CONUS Only Please... Willing to give better deals if anyone buys more than one piece.
Any questions you have I can answer and provide more pics.
Oh Great Heil
Hi all,
TLDR is at the bottom if this is too much of a long story!
My Great Heils have sat in boxes for over a year. This must change.
I am looking for advice on a good way to go with them - preferably 2-way to keep costs down.
My room is 5m wide by 7m long, and 3m tall. (15' wide by 21' long by 9' tall).
Since I have a two year old around most of the time I'm not able to listen to the system at very loud levels these days.
Some of you may have seen my thread about making a horn with them - but any horn worth a damn for the Heils will just be too wide for the house I live in at this stage, so I need another plan.
I have the equipment to actively crossover this project - multiple amps, multi-channel usb DAC and Equalizer APO software installed. So I have the freedom to choose woofers that aren't an exact match for efficiency or impedance load.
In terms of design to go with, of course I have already done a bit of research and thinking already, but many here are far more experienced and knowledgeable than me thus I am putting this out to anyone kind enough to give me some ideas or critique.
Originally while surfing around I came upon Linkwitz's LXMinis.
I was taken with their compact design and semi-dipole nature - and their ability to not have to be too far from the walls but still get a little dipole magic.
You might say, just build the LXMinis - sure. But I want to use my Heils! Additionally the drivers cost to Australia is very high - I have much more cost effective options here and I am trying to keep costs down to the minimum that will work for the Heils.
I thought of keeping the base design rather similar but replacing the full-range up top with the Heil.
Here is a mock up:
Then I came to the realisation - this won't work!
1, the Heils are heavy! 2, the Heils don't go as low as the full range, so it isn't a great match.
This design would be stupid without some kind of mega bracing or complete re-think.
So I thought perhaps I could make rectangular boxes for it instead, like this:
This is better but probably not ideal.
After this I thought maybe I should do a complete rethink towards something a bit more conventional - likely a 6-8" woofer in a ported box with the Heil on top.
So I went hunting and came up with a short-list of the woofers that could work for this project and that have availability in Australia.
The are:
Dayton DA-175-8 x2 (cost per side $130). (cons - large enclosure required)
Dayton RS180-4/8 (cost per side: $100). (cons - SPL not too great if more bass is desired)
Dayton RS225-4/8 (cost per side: $140). (probably ideal but the crossover point might be a bit tight)
I also looked at a few SB Acoustics items but nothing was jumping at me like the Daytons. I'm open to suggestions though - SB Acoustics are also readily source-able in Australia.
Another question I had was - ported or sealed with additional subwoofer?
I have access to a single Dayton RSS265-4 which I could make a ported cabinet for that could go down to ~23Hz.
But then I came upon a thread talking about throwing out the subwoofer if you just listen to music, which honestly appealed to me.
If I can get these speakers to go down low enough that I don't need to build a subwoofer for them, that would make me very happy.
So, how low would I need to go?
I did a test on my main system with Equalizer APO where I could turn on/off a low-pass filter at ~45Hz and see if I missed anything with the genres of music I listen to.
Well, for the majority of music I listen to, I could hardly tell the difference.
Sure, for the electronic music, the deep bass beats were not as audible or impressive, but for the rest, it was fine.
In the end, if I am not satisfied with the bass from this build I can just build the subwoofer and be done with it - but I would like to aim to not need it if at all possible.
So I was surfing along the xKi thread and again was impressed with how much the xKi can squeeze out of a small driver.
Of course I am still waiting for my own xKis to be finished from my Dad (which will be my computer speakers) but perhaps there is a driver that works in a larger xKi down to ~40Hz that I can use as the midbass match for my Heil? The XKis appeal in that they have good cone control, great midbass performance and are compact for the bass they can output.
TLDR
Is there any (preferably Dayton) driver costing at or less than $150AUD each and cabinet combo anyone could suggest that would pair well as a two-way with the Heil (so crossover point somewhere between 800Hz and 2000Hz) down to around ~40Hz or lower?
Thanks to any and all who contribute!
B&W 803 Matrix problems
I always wanted A pair of B&W Matrix speakers, when I came across A pair of 803’s 1 st gen. For A good price I went for it.
My speakers where the Celestion ditton 33 where I put in new filter parts and cabeling. Nothing to exotic butt good quality.
The ditton’s sounded great, i thought the 803 should to better.
Although the 803’s sound verry balanced the lack in lifeness, detail and air.
I also replaced the capacitors, good quality MKP, didn’t do A lot.
I am disapointed, should I sell them or am I missing something?
New wiring? The wires are connected with quick connectors that I don’t like but will this make A difference?
Tryd another amplifier, Quad 606, el34 tube amp, sphinx project 12, sounds different but not yet at the level of my old Celestions.
Any tips?
Sorry for my writing, I it’s not my native language.
Greetings,
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,748
Members
7,886,495
Messages
Filter
Forum Statistics
Threads
406,156
Messages
7,886,495
Members
507,748
Latest member
ch5588
