I am not going to build this project, so I am selling my 2 Baby Huey EL34 pcb’s from Group Buy 2. These have the PS on board. I have most of the recommended BOM parts from Mouser for stereo as suggested by Marc (bandol83).
The parts I am missing for the stereo build are as follows:
2 x R13 - Vishay CPF 247K, 39Kohm - 2W resistors
2 x noval (B9A) sockets, sku17658
2 x R33 & 2 x R38 Vishay MBB02070C3900F 390 ohm – 0.5W resistors
2 x C6, Nichicon LGL2G221MELA25, 220uF, 400V caps
2 x C7, Nichicon UPZ2G101MHD, 100uF, 400V caps
X1, 5.08mm headers or contacts, FCI20020316-H05
X2,X3,X4,X5,X6, 5.08mm headers or contacts, FCI20020316-H02
No V2 – output tubes.
All the above for $130.00 USD.
V1’s – ECC83, 12AX7, please see my NOS stock below. “ I am not a tube aficionado so here goes:”
I have a set of PSVANE 12AX7-T. Test new, Sections match. Measure 38/37 & 39/38. They pass GM, H-K leakage, Gas and overall grade is Premium grade A, tested on Amplitrex AT-1000. ($60 USD / pair)
Set of Russian re-issue TUNG-SOL 12AX7 Test new, Sections match. Measure 114/113 & 115-114 there is 2 other numbers on the box that look like B- 56 & M 55 and B- 55 & M 54. ($30 USD/pair)
Set of 12AX7 Groove Tubes, Test new sections match ($30 USD / pair)
Set of Russian re-issue Mullard 12AX7, Test new, sections match. ($30 USD / pair)
See pics below: PSV in box, PSV data, TS, GT, Mullard
I would like to sell the BH pcbs, parts, and as many tubes as possible in 1 kit.
If a person wanted everything listed, I would let it go at $260 USD. Shipping & likely tracking is on the buyer.
PM me if interested with a postal code, and I will figure shipping costs.
Thanks,
Myles
Thanks,
Myles
Big discounts, last advertisement
The 2 Baby Huey EL34 pcb’s from Bandol 83 Group Buy 2. These have the PS on board. I have approximately 85-90% of the parts needed for a stereo build. The parts needed are below:
All parts are from Mouser and follow the recommended BOM.
The price for the above is $100 USD.
I have the following tubes for sale also (Pictures in posts above)
I have a set of PSVANE 12AX7-T. Test new, Sections match. Measure 38/37 & 39/38. They pass GM, H-K leakage, Gas and overall grade is Premium grade A, tested on Amplitrex AT-1000. ($40 USD / pair)
Set of Russian re-issue TUNG-SOL 12AX7 Test new, Sections match. Measure 114/113 & 115-114 there is 2 other numbers on the box that look like B- 56 & M 55 and B- 55 & M 54. ($20 USD/pair)
Set of 12AX7 Groove Tubes, Test new sections match ($20 USD / pair)
Set of Russian re-issue Mullard 12AX7, Test new, sections match. ($20 USD / pair)
PM or show interest in thread,
MM
MM
