Kef Concerto Crossover Rebuild
In my easy listening room, I have a pair of Kef Concerto's driven by a Kenwood Supreme 500. I love the way they sound, but they have the original crossovers and I'm feeling that they may have deteriorated somewhat since they were manufactured somewhere between 1969 and 1977. Winter is on it's way, and I have decided it is a good time to rebuild the crossovers. I'll put in my ESS AMT 1 mini towers or my Wharfedale Dovedale 3's while the recap is being done.
Now, the question is, do I rebuild the crossovers to the original Kef design, or do I try to emulate the improvements that some say were done by Falcon Accoustics, Wilmslow Audio, or some other design? To be frank, I am looking for your help on this decision.
I will document the full recap with pictures every step of the way.
I really love these speakers, so I want to put in the best components possible to within reason for these beautiful sounding classics.
I've been reading a lot on rebuilding the crossovers on the Concerto's over the last few days. Some say the caps were seriously under rated for the power handling of the drivers. If that is the case, I want to put in higher power components so that I can benefit from the additional output. But I don't want to risk blowing the drivers.
What are your thoughts?
I also don't want to lose the balance between the drivers. As it stands right now, these speakers project beautifully at all volume levels I use in this room. This is where I tend to spend most of my listening to music time and entertaining. I have no plans to modify the cabinets unless they will be hidden changes.
I'm thinking quality caps and aircore inductors, and I also intend to build a whole new circuit board so that I can compare the original with the upgraded crossovers. What recommendations do you have?
Should I follow the schematic specs or the in-unit specs?
FS, UK. Linear PSU. Torroid based, +/- 66V output 600va+
As stated in the title. Trying to gauge interest in this torroid based power supply pulled from a Denon amplifier. Massive torroisal converter and plenty of capacitance to deliver 600+ VA's actions and positive and negative rail. (Three main wire)
If interested let me know and I can send pics if required before you make an offer.
No price yet, waiting to see what interest there is.
Any Q's ask. Postage will be £8.80 UK only.
Newbie - Orientation question
Thanks for your interest.
I am building a 300b amp, and am building it in two parts - PS and Amp.
The PS chassis has two power transformers (one for HT, one for Regulators), and one choke. The amp chassis has two OPTs and two chokes.
What orientation conditions do I need to consider?
On the PS chassis, do I align the two power transformers and put the choke at 90 degrees to them?
And on the amp chassis do I put the two OPTs 90 degrees to the chokes?
And should I align the chokes across both chasses as they will be close to each other, or is that not so important?
Many thanks for your help
Sometimes fake works better !
I designed a USB scope that runs about 10 mega samples/second.
The prototype ran ok but with a little noise in the signal at lowest voltage setting. It was passable so I let it go.
I had to buy in some more a2d's which were about £10 at RS.
So looked around elsewhere for some cheaper.
I eventually found some on Ali Express for about £1.50 each.
I guessed they were worth a try.
After a couple of weeks they arrived and I tried one and it is a better output than the full price ones !
People usually warn you off fakes but these ones seem to be better than the real thing.
Recapping Focusrite 315 mastering EQ
Hello!
Left (upper) channel on my 315 recently died but for some reason works when I short hot & cold on the output - which in its turn offsets balanced gear down the line. The following item loses 5-7 db on the left channel. I guess my short circuit makes it semi balanced, or something like that?
I will figure it out!
Anyway, since it's a 25 year old beast filled with ~60 Nover 16V 100 uf caps per channel I thought I might as well recap it. Actually it doesnt use any other cap than those Nover 16/100. In & out level stages, eq stages = all Nover 16/100. The power supply use two Nover 50V 4700 uf and one 16V 4700 uf.
Any tips on what to use instead? What cap would be suitable for audio and an upgrade. I'm looking at Elna (on Mouser) RFS-16V101MH3#5
Elna are 10 mm diameter instead of the Nover 6 mm but should fit. Spacing between legs are 5 mm on both the Elna and Nover.
Or would you recommend anything else?
(the 315 also uses a lot of Philips NE5534N opamps 🙂 )
Need help with two Jaycar CW-2198 subs
Hi, I need some help, please.
I have two of these drivers. I can seem to calculate an ideal enclosure to make a sub with them.
I purchased these about 10 years ago, knowing what I know now, I wouldn't buy them again. From the response graph, they don't look like they go down low at all.
Woofer Speaker Driver - 10 Inch | Jaycar Electronics
Seems like a shame to chuck 'em in the bin, but am I just wasting my time with them?
Data in the attached .zip file
I'd appreciate any help or suggestions
WTB: Scan Speak (15m/4531) Sonus Faber Cremona midrange
FINISHED. WTB: Scan Speak (15m/4531) Sonus Faber Cremona midrange
No longer needed.
Speakers will be locally sold.
Hello.
I have a damaged Sonus Faber cremona Midrande (WOF30001)
Does anybody here has one or two original replacement units?
Although I know they are not standard versions, a pair of scan speak 15m/4531 could be interestig to try.
The problem in the midrange is that the coil wires are broken at soldering point with tinsel leads.
I have checked continuity at the voice coil and it is ok, but the soldering point is in bad condition.
Calle me crazy, but I managed to solder a pair of wires from the voice coil to the speaker terminals (I had nothing to loose) and the driver works good, but this is not a dewffinitive fix.
Another chance: Any of you here can make a good repair or knows where to do it at a reasonable price??
Thank you
Tascam Portastudio individual output mods
Hi everyone,
I’m looking to do individual output mods to my beloved Tascam portastudios (488, 488 mkII, 414 MKII).. I’m curious if anyone might be able to offer any guidance... I’m just getting a start with soldering... reading schematics... identifying/sourcing/ replacing components... and generally wrapping my head around audio electronics in general.
I’m looking for any info, but ideally, specifics would be most helpful. Service manuals for all three models mentioned are available..
Thanks!
How about this...?
I moded my 6th order bp idea to fix that air-compression thing and here it's (just a sketch, not scaled).
Could someone please sim this for me, cos I don't know how to...?
I'm now ready to build this and looking for dimensions.
If space is your concern, I have enough space in the room to place any large of a box.
For t/s reference, here's the driver I'm gonna use.
12TBX100 LF Drivers - B&C Speakers
Thanks in advance... 🙂
Simple 6BX7 preamp
I originally made this preamp for a 6AS7. The gain was as expected only 1.7. I ended up needing more gain, so simply swapped the 6AS7 for a 6BX7. Got plenty of gain, almost 20dB (18.8x), and that with a much too low value for the plate resistor.
This sounded fine and I was happy, but I knew it was not optimal with the 2200ohm plate resistor (which is ok for the 6AS7) and I finally replaced the resistor with a 3900ohm value. I also replaced the 10uF! metallized film coupling cap with a proper 470nF value foil cap. (I paralleled 4 x 3.9nF COGs just for good measure).
Much better!
The plate load should actually be higher for the 6BX7, and if the 6BL7 is to be used it really really should be higher, more close to 10kohm. But it's a compromise with the available voltage, the current I want high, and so forth. As it is it sounds plenty good.
But if done again, and not just using parts at hand, I would get a proper tube rectified supply giving at least 250V. Alternative is of course choke load the plates, which I think will be my fix, enabling me to keep the lowish 175V supply rail.
Nothing special at all, just another pre. This can take 6SN7, 6BL7, 6BX7, and even the 6AS7.
Edit: the load lines shown are with a plate voltage of 175V, so that will be either with a higher b+ rail, or with choke load.
Advice for first time two way build? Preferably MLTL, TL
Hi there,
I have built couple of TABAQ variations, and quite like them. Especially the softness of MLTL. Have built none of multi-way units.
Requirements:
1. Two way with the main "star" being the woofer unit. Thinking ~6 inch woofer with tweeter or quality full-range. It can be 1.5 or 2.5 way, if it works.
2. Passive crossover.
3. Size is no limit! Any size, any size of the baffle, any shape of cabinet. Full size floor standers. No need to go high WAF but that does not mean that it has to look weird.
4. 40Hz F3 is ok, no need to go much lower, but will need to sound at least OK without woofer.
5. MLTL, TL, Horn or other. Everything works except open baffle or bass reflex. Also no line arrays for now. Pls no flame about this, this is personal preference, like color of cabinets. 🙂
6. The budget for drivers and crossovers is up to ~300-400EUR per pair, that is the same in USD, as the drivers tend to be cheaper on other side of the pond.
7. There has to be balance between the quantity and quality of sound, preference on... hmm.... maybe quality 60%, quantity 40%.
8. It will be driven by class D amp, but must sound well with others.
9. Drivers have to be available in EU.
Right now leaning to building 10F/8424 & RS225-8 FAST / WAW Ref Monitor MLTL version but still not decided. There is not much other on my mind...
Any advice is ok, be generous 🙂
SME 3009 ground wire
I replaced the 4 pin output socket of my unimproved 3009 with RCA jacks. Instead of connecting the ground wire to the ground socket I soldered it to the ground terminal of the left channel jack in order to avoid a separate ground wire from my preamp to the tonearm.
Is this correct, I want to avoid hums.
DIY Preamp recommendations
Just finished refurbishing my dad's pre/power amps and am hooked 🙂
For my next project I would like to build a pre/power amp combo, starting with a preamp. There are so many options that I am getting a bit lost. Can anyone recommend a preamp build with the following criteria:
1. transistor-based (not valve) and class A, obviously
2. no phono stage, tape monitors etc
3. bass and treble controls
4. preferably sonically compatible with a good class A/B power amp
5. good/high quality
Many thanks!
Mark Audio CHR 90 - Ideal Frequency Response?
I was taking a look at the MA graphs for various drivers (as you do) and I was struck by how useful the CHR90 frequency response could be.
First you have the built in baffle step response which all MA fans will be familiar with. Then we have a dip that is centered around 4kHz which seems to match up to the Fletcher Munson curves. Then there is a bit of a boost at around 10kHz which may be useful depending on your age.
Anyone else think this dip at 4kHz may be a good thing?
Dedicated power circuit and line noise
Hello all,
I have moved into a new place and am concerned about line noise. I do NOT have a dedicated line for my audio /video system (all low level source electronics, amps, TV, cable box (TV, internet). But this line only supplies the above and a few lighting receptacles. In addition I am adding a noise filter receptacle (audioquest) on the 1st in this chain.
In a previous question (which I cannot locate) about how to hook up the audioquest receptacle someone had recommended another line treatment that could be installed (Cdm???). ANY recommendations is greatly appreciated.
Joyo AC-40 Hiss
Hi, since this forum offered such great advice on my last project I am turning to you again in hope for some help.
I had this amp for a year now and I am rather satisfied with it.
Joyo AC-40 - Google Photos
There is only one problem: A permanent background hiss as soon as I turn it on at around 30db (background at 20db). I usually play this amp at volume 2, so its no biggy. But I would like to understand and fix if possible.
IF I turn up the volume of the MIC channel, the hiss increases a bit (about 7db at max volume). That seems to be expected.
But hear comes the funny thing and that I REALLY would like to get rid of.
IF I turn up the guitar volume at 5 a zing (or beep) is added that changes frequency as I go further. It peeks (frequency and volume wise) at 7 at 42db and is gone back to the "normal" background noise at 9. It sounds a bit like tuning an old radio.
I tried to record it with my phone. CAREFUL LOUD!
Any help on diagnosing/fixing this is greatly appreciated!
I am sufficient with a soldering iron and a multimeter, if that is of any help.
  • WhatsApp_Audio_2021-04-11_at_18.45.25.mp4
    972.8 KB
Preprocessing data while driving a DAC.
Suppose a DAC is driven in such a way as the following:
Since a DAC essentially converts a binary string into a voltage or current, and this is done every time a binary string is presented at its input, it makes sense to hold all digital inputs at a logic 1 if the succeeding bit is also 1. This should avoid having the corresponding bit going down and up at the arrival of the next binary string. So, it goes something like this:
If the present bit is 1 and succeeding bit is 1, hold the input bit at 1. If the next bit is 0, drop the input to 0 normally. The same holds for successive 0 bits. This, according to my logic, should minimise some noise issues at the output.
Electrocompaniet AW180
I am selling a clone of the Norwegian amplifier Electrocompaniet AW180. A differential amplifier powered by stabilized voltage. It will play several thousand amplifiers. Bias 450mA. 40.000uF for channel.Toroid 450W for channel.Price for amp 1300€
cable - mono device to android
Hi All,
i need to capture audio from an external amp into android.
I made a cable which connects mono out to mic, got a normal 4 pole to 4pole cable, chopped halfway then joined speaker from Source to mic on recorder side (Android phone)
its working fine but i have couple of issues and needed help to find a better stable solution
1: audio has noise, any way to cut it? (to be honest i can live with it, its not extremely critical, point 2 is more)
2: i have noticed weird behaviour, if i plug android side first then it uses the cable to record audio but if source side is plugged in first then android cable then it doesnt detect and uses builtin mic only.
is there any way or official cable i can use, this is quite annoying as this setup is not mostly used by tech people so they can plug cable in wrong sequence and app not to work.
thanks in advance.
kaleem
Wierd LTSpice error.
Hi all,
I have modelled a little 6080 amp with 5687 drivers and all is well in LTSpice.
However when analysing my results it is obvious that the 5687 is a bit marginal to get full power out of the 6080's, so I decided to try substituting a 6DJ8 for the 5687.
At this point the model refuses to run failing with "Time step to small". How can two valve models behave so differently in exactly the same circuit ?
Shoog
So, you didn't win the vfet lottery? (CONUS only)
Well, you didn't win but here's a shot at building one of the "vfet-less" kits. I've got a pair of 2sk82 KD-33 vfets that I'd like to donate.
Rather than giving Papa or Jason any more work;
Procedure:
You: Respond to this thread, first come first served.
Me: If you're first in line, I will respond and give you my email.
You: Will donate $100 to one of the two charities, and email me your receipt and paypal me $1 (so I can print a shipping label with your address).
Donations to two great charities – diyAudio Store
Me: I ship them to you. CONUS only, because I'm also covering the cost of shipping here.
Flared port velocity calculator
Hello, we have put together a port velocity calculator for round flared ports.
You can input port radius, flare radius, port tuning frequency, enclosure volume and velocity speed at an unflared port that I personally calculate on WinISD
The spreadsheet will then calculate port length for one flared end port or two flared end port and ofcourse the new port velocity.
Enjoy!
T5B Sound team
port_velocity_calculator_3.xlsx | Failiem.lv.
DIY DACs?
Just wondering,
I have a British DAC, a little Beresford Caiman SEG towards which I grew an antipathy, I don't need the headphone amp, don't like the external brick called Dorado nor I like the power brick, nor the led lights which make it look like a xmas tree, insomma, I don't like it any longer if not for the versatility of inputs, two SPDIFs, one USB and one Coax.
Now, given I need no high-end nor whistles and bells, one box fitting it all with a decent number of inputs, unbalanced outputs, will feed signal through a MacMini for LossLess music via USB and a TV and AppleTV through SPDIF, very basic.
Is there anything which can be built at home with decent sound quality and meeting the above requirements?
Grazie
Giovanni
Germanium Preamp Questions
Hello all!
Since I've been shunned to far away lands without my usual gear I've been fooling around with some transistor-based circuits in an effort to learn and hopefully make something cool sounding.
After building some fuzzfaces and rangemasters I started 'hacking' together a schematic for a positive-ground germanium preamp. When I say 'hack', i really mean it. But, to my surprise, the dang thing works and already sounds pretty good, considering.
My current issues and questions are these:
1) The variable resistor between the two gain stages works just fine up until about 95% of maximum volume and then just squelches out until there's no volume. I tried different pot values (1k to 500k) and increasing voltage from 9v to 12v - no change.
2) The frequency chart below says that this circuit is inherently dropping off pretty quickly under 200hz or so - how can I lower this? I want 80hz. (Note, I am using 2N527 transistors).
3) Since this is a total hack job, what could I do to improve it? I'm getting some good, colorful gain out of it at this point, but what are some options to try out and what have i done here that might be redundant or counter-productive?
Thanks and hope everyone's been doing great
NAD c368 upgrade?
Had my 368 as my entry into hifi and its awesome....but after looking around for more power, options being a c268 to bridge 300w per ch OR go with the new tech (which I prefer) being purifi amps. So c298 or more economically something like the VTV eval 1........BUT
has anyone opened up a 368 and just replaced the amp module with purifi amps? would the stock power supply handle this or would you swap that out for the SMPS that they usually come with?
i like the idea of hot rodding an amp and making it a sleeper 😎
thanks in advance
dan
cancelling memory distortion ?
If a audio dual matched transistor pair is used at the i/p of a balanced amp and each half fed with the two differential phases of the i/p signal, will the alternate heating and cooling effects on each device cancel out due to their proximity.
can we assume that the two devices are close enough for this to occur ?
can anyone think of any drawbacks of such a scheme ?
would the cancelation cover all relevant frequencies ?
does anyone know about this kind of stuff ?
mike
Dual chamber reflex in a commercial brand speaker
Hello, I've just left every experiment in DIY and bought one beautiful brand pair of speakers with dual chamber reflex:
Given my modest experience, it seems to me that reflex frequency is quite high, being speakers a bit boomy if not far from rear wall, and I would appreciate a suggestion to try lowering it. For my knowledge, a dual chamber reflex is made by a little chamber where is driver with a high frequency tuned vent opening in a big chamber with a low frequency tuned vent, opening out. So the first vent lets pass a larger band of frequency, after reduced by the second one.
My new loudspeakers seems to me exactly opposite: a large chamber with driver opening in a small chamber, so my questions are:
- how are the low frequencies filtered by the first low-pass vent able to pass through the second high-pass vent?
- where have I to work around to decrease the lower tuning frequency of cabinet, on the first or on the second vent?
Thank you very much.
Bumper Industries, Zeuz/Bumper Speakers, new Website through trouble vs. Earthquake?
Hallo,
I want to know the new products from Bumper/Zeuz. The old website is to find about
splash
I find only this website with a example of transducer:
12'' DC FR Series Woofer 1250Wmax - www.cybermarket.co.uk
additional
EARTHQUAKE SOUND CORPORATION vs. BUMPER INDUSTRIES
EARTHQUAKE SOUND CORP. v. BUMPER INDUSTRIES - 352 F.3d 1210 :: PreCYdent Search Engine
The last Adress, what I know was follow
BUMPER INDUSTRIES INC. USA.
8113 NW 54th. ST. MIAMI, FL. 33166
TEL: 305-592-3999 FAX: 305-593-1499
E-MAIL: bumperind@aol.com
...........WEB SITE: bumperspeakers.com
My delivery source and Bumper's european distributor 10 years ago was "ALTAI" in U.K. In the attachement the correspondence regarded new distributor and similar models from Zeuz (not Zeus)
A special feature was the ultimate ratio of price/quality and 10 years warranty
Perhaps one of you can find out for me the currently website of Bumper/Zeuz transducer - Thank you very much
Connectors for ease of servicing ?
In the process of removing the PCB board from my 300B amp, I learned that the cheapo wire insulation melted at a MUCH lower temperature than needed to unsolder the damn things... On top of that, there was so little room to get the iron in.
I think its best to solder tails on the board using ptfe or silicone coated, and splice in the leads where there is a bit more room, with double heat shrink... Thing is, I may want to go in and out a few times... Got me thinking, does anyone know of any type of disconnect or barrel plug that can be used to facilitate easy connecting / disconnecting of wires in a tube amp ? The B+ is 450v and the amperage is relatively low. I see connectors for 1kv and much higher amperage for electric cars, but dont want to spend $80 per!
Greedy Kidz (Boyz & Girlz) Club
If you've spent enough time in the Pass Labs forum, you will undoubtedly see references to Greedy Boyz. Since it's 2021 we should revise this or at least be considerate and start calling this group Greedy Kidz but that's not the point of my post.
If you are a Greedy Boy or Girl, you already know you are but if you are unsure, how do you figure that out? 😕😕😕
Feel free to share why you consider yourself a member of this nefarious group and wear your badge of dishonour honourably (yes it's Canadian spelling). :grouphug:
Being a fan of Papa and Wayne also does not qualify you as a Greedy Kidz, in fact, it's a prerequisite but it's the ability to take this to the point of 'too far' that will gain you this privilege of joining the undeserving. :worship:
I am one of the Greedy Boyz (or Girlz or Kidz if you don't care to identify) because I think the best amp is the next one I haven't built yet and I"ve built at least 1 of Papa's creations, enjoyed it, basked in it's glorious sound and then started researching the next one.
Please note, using the accolade 'fugly' alone doesn't qualify you as a Greedy Kidz but if you disagree, please feel free to explain.
As the creator of the term, I defer to the Mighty Zen Mod (MZM) to arbitrate 😀:joker:
Moderators, if any of this is inappropriate, please feel free to remove/lock
for Sale: Leader LAG-126S
Hi guys,
I have for sale audio oscillator Leader LAG 126S
- the item to have some signs of cosmetic wear, but is fully operational and functions as intended
- included original printed user manual
ship to: only EU
price: 370 EURO ( ex-work incl. shipping and paypal fees )
payment options: paypal
contact: milandks at pobox.sk / slovakia
regards
milandks
  • lag_126s.pdf
    lag_126s.pdf
One piece cone vs seam cone...
I'm about to buy a pair of vintage full range drivers from the late 50'
Both drivers are 8 ohm and were connected in parallel on a push-pull 6BQ5 mono amp. in a console with a turn table.
What I'm wondering is that the unit (Zenith console) is using 2 drivers which have differente cone construction even though they were both manufacturered the same year and by the same manufacturer.
One cone has a radial seam and the other cone is a one piece cone, no seam.
I have seem in many occasion this configuration in Zenith console, using 2 full range drivers located close to each other but with different cone construction…
Both drivers have the same basket, frame material, magnet type and size..
Why go to the trouble of using 2 slightly different drivers ? Any idea why would a manufacturer would do this ? I have some ideas but would like to hear yours first.
I'm probably making too much out of this but I keep wondering the reason for doing such a thing.
If there is sonic differences between the 2 cones, I would prefer to know now before moving ahead with this purchase.
Thanks,
Eric
Mundorf MResist Ultra = Isabellenhütte PBH ?
Just compare
Mundorf Mresist Ultra
https://hfc-fs.s3-eu-west-1.amazonaws.com/s3fs-public/mundorf_mreu_30_datasheet.pdf
Isabellenhütte PBH
https://www.isabellenhuette.de/fileadmin/Daten/Praezisionswiderstaende/Datenblaetter/PBH.PDF
Furthermore Mundorf is describing that the above mentioned resistor was developed together with a Resistor Company known for Laboratory Grade Production.
The used Alloy can be considered as Isabellenhütte Manganin
Everything fits.
p.s.: Price of course is not the same
FRD Response Blender Help
Hi, I have traced my full range speaker and I simulated the baffle step diffraction using Loudspeaker Design Software . I want to blend it using FRD Blender and Minimum Phase Extractor . The problem is that I only have Excel 2011 and everytime I load the spreadsheet, I always got an error message and can't find the upload frd button.
Can anyone help me blend this file? The file for the woofer will be named woofer.frd and the file that I got from simulating using Loudspeaker Design Software will be named Baffle step diffraction set as loss.frd and Baffle step diffraction set as gain.frd
Thanks!
Mono summing cable
Hello,
I want to make a mono summing RCA cable to connect my audio interface/DAC to a mono amplifier. The input impedance of the amp is 30kΩ, the input sensitivity (2Ω, 100W, 1KHz) is 0.83V. The source max output level is +16dBu and i do not know its output impedance.
What value resistors should I use? Do I need a resistor on the summed output that goes to ground? What is the purpose of this resistor (can be seen in the schematic below)?
The amp is a wondom model WONDOM | STORE
The audio interface a Motu M4.
Double Check me?
here is a schematic for a ocb that goes between my volume autoformer and the knobs. It uses Nixie tubes to display vol knob position. I have an option to use external 5 volt power you can set with a jumper. other than that its pretty straight forward. Just feel better if I get a few more eyes on it.
Thanks in advance!
Jeff
Forte model 3
I intended to do the right thing by replacing the old power supply caps in my model 3 amp. What I found were some caps that are much bigger in value and size, and voltage. The originals are 24,000 with a 60 volt surge rating. The new ones are 37,000 with a rating of 100V. After replacing the caps, the amp immediately blew the 8 amp main fuse. I then put a 6 amp current limiter in the incoming AC line after the fuse. It still blows the main fuse. I am thinking that I would be better off just getting 24,000 uf caps of the same voltage rating and calling it good. Any thoughts?
Help with finding correct replacement. Jfed on Pre-amp output board
This is on a Harmon kardon Citation 11 Preamp. Replacing the Electrolytes I also tested the Jfeds with a Transistor tester. It is testing as 2 resistors consistently. The board still had output but engaging the EQ was noisy.\
It is Q506. It, Q508 and Q510 all are the same part number and test as P-Channel with symbol gate pointer close to the source lead.
As much as I have read tells me the company which made these was bought up years ago. The numbers are P1053 215 above Mfgr symbol 7233. Unable to cross reference.
Are decibel meters suitable for tube amps as a VU meter?
I see lots of people put those cheap VU meters off ebay on their tube amps, but was wondering if it is possible to use a decibel meter for the same purpose, as i have some awesome vintage decibel meters and would love to incorporate them into a steampunk styled build.
Doesnt really need to accurately measure VU or anything, but just really to serve as a level meter to give some sort of indication to how much the amp is being driven.
Would they require shunting, or just hook up across the output?
What's up with this 6V6?!
Been testing a bunch of tubes and I suspect there is a fault since the meter gives a slight reading on the first leakage test on my weston 981 tester.
Heater glows normal on first test, but glows like a light bulb as I switch to the next series of tests!
Seems to give an OK reading on emissions however.
It's a Sylvania 6v6gt
Any ideas? See photos.
Fetzilla Build Documentation
Here's what I've collected and to the best of my knowledge it's all the latest renditions .
The BOM I used as a general guide and ordered resistors and other components to my preferences . not quite sure who that came from . Use at your own risk .
Enjoy , Woody
Folks,
My sincere thanks to Woody, this is the complete FetZilla documentation endorsed by me, now made 'sticky'.
I have also appended here a complete distortion analysis of the FetZilla. Two highly competent EE friends of mine here in Melbourne took distortion measurements of the FetZilla on Monday 27th Feb 2012. They are taken at 1KHz, into an 8R resistive load, at outputs respectively of 1W (+10dB), 13.3W (+20dB), and 26.5W (+23dB):
Fundamental 10.00dB Fundamental 20dB Fundamental 23dB
H2 -93dB 5.012E-10 H2 -78dB 1.585E-08 H2 -78dB 1.58489E-08
H3 unmeasureable H3 -93dB 5.012E-10 H3 -88dB 1.58489E-09
H4 unmeasureable H4 -105dB 3.162E-11 H4 -93dB 5.01187E-10
H5 unmeasureable H5 -102dB 6.31E-11 H5 -103dB 5.01187E-11
H6 -96dB 2.512E-10 H6 -106dB 2.512E-11 H6 -110dB 1E-11
H7 unmeasureable H7 -110dB 1E-11 H7 -101dB 7.94328E-11
H8, H9 and H10 are all unmeasureable
THD by voltage 0.00274% (1W, +10dB); 0.01284% (13.3W, +20dB), and 0.0134% (26.5W, +23dB)
Measurements below about -80 dB can be assumed to be insignificant except in ultraclean designs
These figures are surprisingly good, but with output bias set to 370ma the first 5.5 watts of output are in Class A, so perhaps not so surprising after all.
I would add that the THD does not correlate well with the sound qualilty; rather, it is the profile of the distortion artefacts that affect the perceived sound quality for the human ear.
Not bad for a jfet, two mosfets, and two lateral output fets - only five active devices in total!
My thanks to Graeme and Paul for generously giving their time to measure the FetZilla!
Hugh
Rockford Punch 360.6
This is a 6-channel amp.
I'm not getting audio out of the rear L and R channels after combing through several other faults out of this amp (Those faults have been fixed) not related to these channels.
There is no audio signal at any of the pins on XM3, but I do see audio for these channels on U5 OpAmp.
I played around with different input switch settings and still cannot get audio down to these channels. No signal on the IRFx540 so its not the terminals.
I'm going to pull the board back out of the sync later today. Any clues?
Thank you in advance
  • Locked
LM3886 singing at hell°
This thread is dedicated to applications of lm3886 running at 125°C Tj.
On "Talking about lm3886"thread you can read why this IC is designed to be used at high temperature.You also find as references, uploaded intimate thoughts, of revered gainclone experts.
ARTY " heating an amp ic rarely made it sound better to me.i prefer them as cold as possible within reasonable level.if it gets up to boiling point then the highs become grainy and i don't like that". _________________
AndrewT " I wish I did not follow your precedent and waste my time reading it.I will go and unsubscribe in the hope I don't bump into this Thread again. "
The maximum temperature advised by the datasheet is 150°C, although the thermal shutdown occurs at 165°C to be switched back on safely at 155°C. Running at 125°C leaves a margin of 25°C .Using lm3886tf isolated version which has thermal resistance of 2°C/W+0.2 for thermal compound ,provides about 10W acceptable dissipating power tolerance.
A straight forward idea for constant power dissipation, is class A,but looking on the figure bellow at Vs+/-25v you can see a strange flat curve from 5W to 30W Po the IC dissipates 15W to 17W.
If at 15W dissipation the Tj is 120° to allow at 20W to become 130° with 2.2°C/W ,then the heatsink temperature is to be adjusted about 85° (120-15*2.2) . I tailored two heatsinks shown bellow , adequate for 30° ambient temperature.
Both are 2.5cm thick developing both 200cm.sq.(buttom excl.) surface(air-metal contact).The shorter and wider one above weighs 105gr. It needs about 10mn to heat from 30°to 85°.The other weighs 65gr and requires only 5 minutes and costs half price.
The circuit to be used is non_inverting.For 31W it requires a gain of 23,feedback resistors 22k and 1k wil do,a 33k pulling down the mute to -V ,a 10k potentiometer and a pair of ceramic 100nf decoupling the rails. Power supplies are provided by two switching power supplies 24V3A each, adjusted 25V and you get the best sounding lm3886 ,on condition you are using it above 5W.
If this is suitable for outdoor use ,it is too high power, for use in an apartment.To realize it by yourself,adjust the sound to a comfortable level and mesure with a digital ac voltmeter the voltage on speaker,even with a low efficiency one you will be astonished how the average power is so low.Adjust it to be 5W (6.35v for 8ohms) and realize how loud the amp under design, should run, to be heated properly.
The remedy for this is to use an ordinary fullwave rectifier.If it is designed to provide 25V at 30W output ,then at low power, the supply voltage can go above 30V.On the curves above it shows the amp can dissipate 15W, starting at 2W output. Now new problems arise.At 10W continuous output, the supply is far above 25V,but from the begining of the design, up to 20W disssipation was considered ,but at transients, the supply capacitor's high voltage, charged at idle, must collapse rapidly in order to prevent overheating the output transistors above 250°.Here, the calculations are in jouls.The most important parameter is the dynamic thermal resistance of the output transistors shown on the figure bellow. A simple calculus math. could resolve the problem if it was a linear one.
If the value of the capacitor is decreased to lower stored energy, then the ripples become higher To keep the supply above +/_25V, the ac supply sould be increased ,that means higher energy stored, so to lower the capacitor value ,and so on. By estimation and trials the retained value of the capacitor is 3300uF along ac 2*22.3V (300VA PS transformer for two channels).
Now we have an amp good to function between 2W to 30W.
A parenthesis
OPTIONAL READING
The Gaincard from47Labs, became a reference ,as sea-level or freezing point of water,since a holly hifi magazine qualified it as,top grade.Ever since, IC amps are compared relatively to it.
COMPARING WITH GAINCARD
The Lm3875 used in Gaincard, needs to be heated Tj of 135° to have the thermal feedbacks canceled , instead of 125°, see figures bellow,Then the heatsink temperature must be 95°instead of 85°.
lm3886. lm3875
Running at the same operating condition, the Gaincard delivers 25W instead of 30W.
lm3886. lm3875
The dynamic thermal resistance being much higher,the Gaincard uses 1000uF capacitors with 2*23.6V ac instead of 3300uF 2*22.3Vac.This may be, results in lower dynamic sound (not shure).
lm3886 lm3875
Where the Gaincard excels, is at heatsink.It uses a tiny aluminum enclosure (10cm*8cm*4cm) with aboutt 2mm thick upper and lower plates linked firmly (thermally) by a 5mm thick side.
see the pictures of the heatsink dismentled.
http://www.6moons.com/audioreviews/47labs5/gaincard.html
The total radiating surface is 200cm.sq. But with the two heatsinks joint together, the bottoms are effective only by half ,this reduces the radiating surface to 160cm.sq. 15W dissipation highers the temperature from 30° amb. to 95°.
As the IC is mounted on the thin bottom plate, It creates a hot spot of 95° to be reduced to 60°-70° on the upper edje.With such heatsink primo,children are not injured accidentely,secondo it provides lower thermal inertia to reach 95°in less than 3 minutes.
*Gaincard temperatures are calculated/estimated for Tamb of 30°C.
End of parenthesis
There are two more problems to resolve. 5minutes or 2 minuets ,it is still too long to heat up.The most important is still at low power.If you are listening as background music while reading or dinnig or simply it is late evening and you are listening a soothing music ,The amp will remain cold and provide you toy quality sound.
One step beyond.
How about powering this IC to its maximum voltage +/-40V.If I can provide 150ma at this voltage by a high impedance supply added uppon, then I get 15W dissipation at the first watt.
But who will swallow the 150ma if their is no signal?The IC will take it's share of 50-80ma,what is left, is taken by a pair of power zeners.The total power dissipated at quiescent now is 12W.How about I give a hand and make it 15W.By this the heatsink once heated to 85°it remains constant.
Signal,or not signal,is no more a question.As the IC dissipates at quiescent 4W the Tj min is about 95°.Just tiny watts and it goes to hell° and this, up to 30W output.
To make a high impedance supply toppling a full wave ,is to add a pair of capacitors across the bridge and add two diodes in series to transform the PS into a weak tripler.The values of the capacitors fix the supplementing current.47uF+(33uF/50Hz or 22uF/60Hz) .See the circuit bellow.
Yes the BASIC3886 is the 300B of semiconductors.Now it just got a power supply.Similar to 300B which requires also an adequate nonlinear driver and a decent output transformer to be called an audio amp,the BASIC3886 also needs some auxiliaries to deserve the title of 21st century audio amplifier.
THE BEST IS YET TO COME
KOKORIANTZ
Curves are extracted from TI datasheet.
Need help repairing a PPI PC450 Amplifier
Hello,
I recently installed my old PC450 amplifier into a new car. I had this amplifier for years with no issues.
In the new car I immediately noticed the amp got very hot and stopped outputting. I did not have an inline fuse installed.
I powered up with a current limited supply and found the output transistors were getting very hot. I removed them from the board and checked for shorts but found none. I replaced anyway and still have the same problem with new output transistors.
The amplifier powers up normal drawing normal current then after about 30 seconds it draws max current limit from the supply (5A) and all outputs get hot for all 4 channels.
Currently only the outputs for CH1 are on the board and the problem still occurs.
Any help would be greatly appreciated!😀
Oregonians looking for some nice full range speakers?
I have a pair of Classic Audio Nirvana 12s in some large cabinets approx 18 wide x 14 deep x 45 tall boxes. Built out of Baltic Birch Ply, internally braced. Speakers are in fantastic shape and have never been abused. I am asking $400 a pair. Basically buy the drivers get the boxes for free. I can demo them for you from my 300B SET amp. I picked up a pair of transmission line speakers on craigslist that are pure magic with my amp and no longer need the 12s.
I am in the portland area.
email me at jclass.audio@gmail.com or better yet text me at 541-231-2297
Jeff
Music Angel XD950MKII capacitor issue
Hey all, I currently have a working Music Angel XD950MKII, but that is only after replacing some of the capacitors in the driver section, as it smoked in just a few minutes after the initial startup. Guess China-made 450WV capacitors don't necessarily mean they can actuall work at 450WV! Anyway, I have another capacitor that is starting to bulge, and I would like to replace it. Problem is, I can't identify what the value is. Have any of you come across this problem, and/or doesn anyone happen to know what the value of this capacitor is? There are two, one for each channel, but the ones in mine aren't the same and aren't marked with anything meaningful. The one that is bulging is the one on the right, this picture was taken prior to 'the bulge'. Thanks in advance! ~Elfox
How to retrofit new tonearm?
I just bought a new Rega RB330 tonearm for my Systemdek IIX, replacing the stock Profile II tonearm.
I understand I need 222mm from the center of the tonearm mounting base to the spindle. Inserting the Rega tonearm in the stock tonearm board I am unable to get 222mm.
Do I need to cut a new tonearm board then drill and mount the new arm?
Does the thickness of the tonearm board matter? I would think yes for VTA. The stock board is 3/8”.
What’s the best way to ensure I get the 222mm from the spindle to the center of the tonearm base?
Thanks!
Precision Fidelity - C7 Mods...help Wanted!
I have a Precision Fidelity C7 - in basic unmodified form. I want to bring it up to its highest spec. and would be grateful if anyone has a schematic to share for the 7A or REVISED model.
I will be using it with a Bent Audio MC Tx.(Silver) and a variety of power amps.
I will be very pleased to hear from anyone who has worked on this Pre.
Many thanks
Brian
What is the best metal for a handmade/DIY small heat-sink?
Hi Guys!🙂
First of all, please try to forgive me for my bad english😱!!!
I would like to ask you what is the best type of metal for the best heat dissipation of an old (obsolete) audio integrated transistor ( TCA940, 10 watt max audio transistor).
Unfortunately the TCA940 heats a lot, so I want to build a very nice and useful (handmade-DIY) heat-sink for this transistor, because the (rare) common heat-sinks for the TCA940 on the market have a shape that doesn't fit the available space in my small circuit board.
I've a good idea how to do, but I've no idea about the best metal to use for the best heat dissipation.
I was thinking to use copper.
What do you think about copper as a possible solution? or does exist some other higher quality metal for the heat dissipation? I don't care about the price!
Please guys, help me!!! give me your opinion!
Thank you in advance for your kindness and patience!
Best Regards:wave::wave::wave:
FS - Erno Borbely Original SE Headphone Amplifier KIt - assembled/tested
Legendary Erno Borbely Original Kit assembled/ Tested - used little
Uses Toshiba Dual FETs (2SK389), low distortion Resistors/ Capacitors and 2SK216/2SJ79 Mosfets capable of driving low impedance Headphones ( 40 Ohm). Complete copy of Erno Borbely Document copy will be sent along with this Kit. Requires +/- 24V DC low noise Power Supply is preferred. One can use LM317/337T based PSU. I have Erno Borbely assembled Power Supply Regulator with Rectifier is suitable for this Kit. You can also buy DIYAUDIO super regulator kit and prepare nice LN PSU. Prefer US buyer but willing to ship internationally
send me a PM for Pricing/shipping costs etc
Refurbishing an X5
A friend of mine sold me their Pass Labs X5. While seemingly sonically perfect, it has certainly seen some "love."
A previous owner was a cat lover and possibly a smoker, so the internals were very dirty.
After spray-dusting, a thorough exterior wipe-down, and a DeOxIt pass on all the contacts, things have been sounding great.
What I'm wondering is... since the "wings" have seen a lot of love, and are quite easy to remove, what kind of tools do I need to either buff out the scratches? I think the tooling required to mill a proper replacement set is a bit outside my wheelhouse (though I'd love to learn!) and certainly beyond my budget for this restoration.
(I also suppose it's not outside the realm of possibility that Papa Nelson & co. have spares -- not exactly a DIY solution, but it might be the cheapest one!).
On an electronics side, I'm wondering if anyone here has worked on these and has any advice for tuning them up?
Just because it sounds really nice to my ears doesn't mean it's not out of spec and therefore could sound even better. I had a Rotel amplifier that I used for over a decade before I took it into a local amp repair shop for service when a channel went flaky. $120 later and I felt like I had a brand new amplifier because in addition to replacing a handful of bad caps, he also re-biased the channels. I don't think it sounded that good since the day I bought it. Maybe never.
I'm fairly new to electronics work, so I've never had the pleasure of re-biasing an amp. I don't even know if that's doable or advisable here... or something a neophyte should avoid for fear of life and limb... again, just looking for advice. I do have some local electronics expert friends in my DIY club I could work with if COVID weren't a present-day concern. Hard to get elbow-to-elbow when you shouldn't even be in the same room as people! 😀
Need help by Aikido All in one 9 Pin
I have buy for a lot of year a 9 Pin Aikido all in one PCB
and like to build it at the moment.
I like to use the 6N23P witch are the russian 6dj8 Tubes for all Postions and My Transformer do have measured:
247V AC 70ma
6,8C AC 2,5A
The value of capacitors ist clear , for the regulator i like to take the LM317T
Can i use alternativ for all MUR410G the 1N5402(D9, 10, 11, 12 ) ? Or ist it only as replace for the D5 -D8?
Now my big problem the Resistors;
I think this values are clear
R19 499 ohm
R20 124 Ohm
R1 1 M
R11 1M
R9 100k
R10 90K ( ? )
and the rest, i need realy help!
Can anyone help me please with the other resistor Values?
I like to use the recommended values B+ Voltage 200V for 6dj8
Thank you very much and regards from germany
Capacitor type for input filter
I am building a balanced-to-unbalanced receiver circuit ala ESP's Project 87 (Balanced Transmitter and Receiver II) and want to add the input filter as shown here., to trap out any RF disturbance. My question is: Does the selection of capacitor type here have any audible effect? Normally I use PolyPropylenes for any low-value capacitors in the audio path, but in this particular application, the size is quite a limiting factor; thus I am considering use of a MLCC COG type cap. Usually I would avoid any ceramics in the audio path, but in this case, is it really in the path? It would seem that the capacitor here would only be involved at super-sonic frequencies and thus a non-factor. Opinions?
Chip-amps suited as power stage in a composite amplifier, LM1875/TDA2050 excluded.
Admitted, the title sounds weird. Actually, we already have a thread concerned with the use of LM1875, in particular with more in parallel, as power stage in a composite amplifier. The final aim there is to test such a composite amplifier in BTL-configuration. Without being aware when I bought my LM1875, I ended up with specimens that are probably “fake” and do not behave fully as LM1875 ICs delivered straight from TI. My “fake” LM1875 sometimes perform more like TDA2050. As the TDA2050 is pin-compatible with the LM1875 and their specifications are pretty much alike, this existing thread also include the use of TDA2050. ST no longer produces TDA2050 but a company in Taiwan, Unisonic, produces a version called UTC-TDA2050V that seems to perform very well and can be bought at a very good price. Such is for the existing thread.
Work with LM1875 and TDA2050 in the existing thread got to a point where it was difficult to disregard that other chip-amps may also be very suited for composite amplifiers. In particular for higher power levels. In posting #510 ( LM1875 in parallel configuration and used in a composite amplifier. ) of the existing thread, a scheme was drafted mentioning a plurality of chip-amp candidates.
Before a chip-amp is used in a composite amplifiers, its behavior should be investigated such that an implementation of the chip-amp is used in the composite amplifier that is 100% predictable and reliable. This sounds trivial but even the well known LM1875 showed some characteristics, like self-oscillation and de-rated operational limits, that took most of the time before the complete amplifier performed well. Another problem related to use of chip-amps at a gain below the minimum gain specified in the datasheet.
For other chip-amps than LM1875/TDA2050, where should the results from investigations be disclosed? The existing thread is already becoming comprehensive with LM1875/TDA2050 issues, parallel-coupling issues, controlling OP-AMP issues etc. Therefore, the present thread is started with the purpose to disclose experimental results and considerations relating to these further chip-amps, when using them below the minimum gain, when connecting them in parallel, when improving stability, when protecting them from overload etc.
FF
Adcom GFA-535-II Schematic errors and omissions
I recently picked up a Adcom GFA-535-II off of Craiglist for $80. I found a service manual for it and have been looking under the hood. I’ve found that the schematic has an error and omission and thought I’d share my findings. I attached the service manual and the schematic extracted from said manual with the errors and omissions highlighted.
The Error
The schematic in the service manual shows to input to the VAS stage coming off of collection the feedback transistor (Q603/Q604) of the LTP. When I first saw this in the service manual schematic I was a bit baffled by the topology. I couldn’t figure out how this could possibly work. I opened up the unit and probed the connections with the continuity setting on my DMM and confirmed the error. The connection should be to the collector of input transistor in the LTP (Q601/Q602 not Q603/604).
The Omission
The omission is an electrolytic capacitor C637/638 bypassed by film cap C635/636. These are DC blocked caps in the feedback loop. In my unit (Rev-2 of the PCBs), these caps are mounted on the boards with silk screen and are spec’d at:
  • C635/C636: Film 0.47μF 400V
  • C637/C638: Electrolytic 22μF 50V
C637/C638 seems a bit undersized to me. I suspect this is due to space constraints as the caps were added as part of Rev-2 of the boards without any other apparent layout changes. The low pass filter formed in combination with the 1KΩ feedback resistor create a 7.2 Hz pole. This would typically be a 100μF cap in most designs for a 1.6Hz pole frequency.
I understand there are three versions of this situation:
  • Original with no caps
  • Caps installed on the underside of the PCB without silkscreen
  • Caps installed on the top side with silkscreen (Rev-2 boards)
I found out about the omission from an article posted on the website Hoppe’s Brain (user Phloodpants on this site). The article is too big to attach, but a copy can be found here. It’s a good read if you’re interested in this amplifier. His website also has good information on these amplifiers and several mods.
Other Omissions?
One more item to note… The capacitors in the service manual go to C631/632. The omitted capacitors I found started at C635/C636. This suggests that C633/C634 exist somewhere. However, I could not locate them.
That’s all. I hope someone else finds this information useful. :cheers:
  • Adcom-GFA-535-II-Service-Manual.pdf
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,772
Members
7,887,927
Messages
Filter
Forum Statistics
Threads
406,206
Messages
7,887,927
Members
507,772
Latest member
Hypertone
