dfidler:ToDo
This page lists my todos that have to do with diyAudio.
Threads to Review
- http://www.diyaudio.com/forums/headp...phone-amp.html - Class A Headphone Amp
- http://www.diyaudio.com/forums/solid-state/126370-oscillograms-testing-why-layout-matters.html - Why layout matters
- http://www.diyaudio.com/forums/solid-state/171304-new-diyaudio-help-new-build.html - Choosing An Oscilloscope
- http://www.diyaudio.com/forums/chip-amps/134726-new-my-ref-rev-c-thread.html - what is a Ref Rev C?
- http://www.diyaudio.com/forums/solid...re-please.html
- http://www.diyaudio.com/forums/analo...ve-preamp.html - LDR vs Pot
- http://www.diyaudio.com/forums/solid...raw-backs.html - multicap drawbacks
- http://www.diyaudio.com/forums/subwo...hose-subs.html
- http://www.diyaudio.com/forums/tubes...amplifier.html
- http://www.diyaudio.com/forums/solid...r-limiter.html
- http://www.diyaudio.com/forums/solid...aksa-55-a.html
- http://www.diyaudio.com/forums/class...050-board.html
- http://www.diyaudio.com/forums/power...chematics.html - schematics for +/- 0-50V 0-5A PSU.
- http://www.diyaudio.com/forums/power...regulator.html
- http://www.diyaudio.com/forums/multi...d-ariel-2.html - Lynn gives a ton of info on speaker cabinet characteristics, among other things
- http://homepages.which.net/~paul.hills/Heatsinks/HeatsinksBody.html - basics of heat sinks (lots of equations)
- http://www.diyaudio.com/forums/chip-...ild-guide.html - Project starter for MyRefC amp
Overall Structure
From post http://www.diyaudio.com/forums/every...l#post2263068; I want to change the front page of the wiki to order it a little better so that each article has a home and can be found, easily, by people who want to browse the wiki.
To this end, I've created the WikiStructure page. Please feel free to modify it or discuss it in the thread above.
Wiki Pages to Update
These are existing pages that I want to edit...
Krell KSA-50 Clone
I've finished the migration of all of the URLS and headings. Now I need to re-write the guide so that it's not so disheveled. This will involve renaming all of the existing pages, merging them, and then deleting the old ones.
However, to do that, I need the ability to rename pages and find out where these pages are referenced (both in threads and in the wiki itself).
Miscellaneous
- http://www.diyaudio.com/wiki/The_Blocks - what does this relate to?
- http://www.diyaudio.com/wiki/Other - appears to be specs on an type of triode; should be added to a new category called 'Electronic Component Specs'
- http://www.diyaudio.com/wiki/El_Cheapo_PP_6AQ5_6V6_EL84 - needs to be linked from somewhere
- http://www.diyaudio.com/wiki/Electro..._and_Shareware - needs to be improved and added to an index page
- http://www.diyaudio.com/wiki/Electro...-_Online_Links - needs to be added to a page somewhere
- http://www.diyaudio.com/wiki/Audio_Calculators_Online - needs to be linked form somewhere
- http://www.diyaudio.com/wiki/El84_6bq5 - component specs; needs a category page of it's own
- http://www.diyaudio.com/wiki/Baby_Hu...EL84_amplifier - Awesome page! Needs to be linked form somewhere
- http://www.diyaudio.com/wiki/Parts_S..._in_USA_Canada - Needs it's own category page!!!!!
- http://www.diyaudio.com/wiki/Guitar_Amp_Designs - ARGH PEOPLE!!! LINK TO YOUR DAMNED PAGES!!!! HELP US FIND THEM!
- http://www.diyaudio.com/wiki/TransformerSuppliers - can you guess what I wnat done with this one? Argh.
- http://www.diyaudio.com/wiki/TubesValves - this was the beginnings of a category page; needs to be fleshed out! There are lots of pages that we can put on here
- http://www.diyaudio.com/wiki/Vbe_Mul...p_Compensation - needs a home
- http://www.diyaudio.com/wiki/DN2450_...an_output_tube - this is a 'sub page' of http://www.diyaudio.com/wiki/Baby_Hu...L84_amplifier; both need to be cleaned up and moved around so that they reference each other properly
Wiki Pages to Migrate
- Nothing on the list yet; need to do some cleanup first...
Wiki Pages to Create
- MongrelAmplifier - taken from this thread
- Help:CreatePage
- Help:WikiBestPractice
- Help:Templates
- Help:WikiCodeList
- Help:Tables
- Help:
- Templates!
- Getting PCB's printed (where, how)
Pages to Delete
I've moved this to: WikiPagesToDelete
This page has been seen 1,119 times.
Created by on
