Go Back   Home > Forums > Blogs
Old
Active crossover network using 555 timer as class D amp
Posted 9th July 2010 at 08:17 AM by ledmania
Updated 13th July 2010 at 06:07 PM by ledmania
This blog may provide interest to some newbie looking for low cost, easy to build class d amp source tuned to their listening taste. I have already tried this circuit on the breadboard and it sounds surprisingly good but I’m sure it will work much better on PCB of course. The timer chip I used is the CMOS LMC555 because it’s a lot faster than bipolar counterpart such as 15 ns rise and fall times and can oscillate up to 3 MHz @ 5V. Of course you can use bipolar 555 timer as well.
About the circuit:
The circuit consist of 2 classical yet popular configurations; The master wired as “astable multibivrator” and the slave as “one shot” monostable.
https://geekcircuits.com/wp-content/u...ive-filter.png
Figure 1.
Slave A is an active band pass filter tuned to 20 Hz with +/-7 Hz bandwidth serving as “mega bass enhancer” while slave B is a simple high pass filter with -3db roll-off at 7 KHz for the treble. Slave C will fill-in...
ledmania's Avatar
Posted in Uncategorized
Views 6492 Comments 5 ledmania is offline
Old
Fdnr
Posted 1st July 2010 at 10:28 PM by DougL
Updated 14th September 2010 at 06:34 PM by DougL
https://www.diyaudio.com/forums/parts...-resistor.html
Motorola used one on their first cell phone.
Chauser eleptical low pass with nulls at 4.5k and 9k iirc.
Now I am wondering if I could create a "passive line level" with this, avoiding inductors.
Here is a link to a design article:
https://electronicdesign.com/article/...sband6366.aspx
Views 1417 Comments 3 DougL is offline
Old
guide to the v1.2
Posted 22nd June 2010 at 02:47 PM by klewis
Updated 4th January 2012 at 12:13 AM by klewis
Reflektor Notes: https://www.diyaudio.com/forums/power...ml#post2724088 post 4287
B1 with Shunt https://www.diyaudio.com/forums/pass-labs/145201-building-symmetrical-psu-b1-buffer-2.html#post1854512
https://www.diyaudio.com/forums/power...ml#post2223856
schematics #1983 https://www.diyaudio.com/forums/power...ml#post2103465
Transformer R-Core EBAyhttps://www.ebay.com/itm/110V-50W-R-c...item4ab0dbf733
V1.2R schematics
https://www.diyaudio.com/forums/power...lator-320.html
board design starts 2384
Sense wire: Use RG58 on all your shunts for...
klewis's Avatar
Views 790 Comments 0 klewis is offline
Old
E-MU 0404 USB sound card mod thread
Posted 21st June 2010 at 02:56 PM by klewis
Updated 2nd January 2011 at 05:39 AM by klewis
https://www.diyaudio.com/forums/digit...ification.html
more on setting up sound card for measurementshttps://www.diyaudio.com/forums/solid...rements-9.html
klewis's Avatar
Views 2367 Comments 0 klewis is offline
Old
Yet another DIY cable build approach.
Posted 19th June 2010 at 02:12 PM by aptquark
Updated 19th June 2010 at 10:15 PM by aptquark
Lets start by examining a few popular connectors available for the DIY enthusiast.
Here is one of Home Grown Audio's rhodium plated silver connectors. Very simple morphology. Some may find these "cheap" looking. Well...they are designed with simplicity in mind, and the cost is very reasonable. Acoustically, I really like the sound. High frequency extension is great, though with very resolving equipment, a tad to "bright". Still, a great buy. As far a durability goes, they are quite tough. But, with the stress testing that I do, after completing the cable, there is a tendency for the crimped-on negative portion to disassociate from the head. Keep in mind that I apply way more tension than would be encountered under normal operating circumstances. Overall, a very nice, inexpensive connector.
Next shown is the Audio Note RCA connector. This is a very well built RCA. Acoustically, a little more tamed in the upper frequencies compared to the HGA....
Click image for larger version
ID:	170   Click image for larger version
ID:	171   Click image for larger version
ID:	172   Click image for larger version
ID:	173   Click image for larger version
ID:	175   Click image for larger version
ID:	176   Click image for larger version
ID:	177   Click image for larger version
ID:	178   Click image for larger version
aptquark's Avatar
Views 4728 Comments 0 aptquark is offline
Old
HEC part II
Posted 17th June 2010 at 05:07 AM by abraxalito
Updated 8th September 2011 at 03:04 AM by abraxalito
Here's a pic of the underside of the DAC before I started hacking tracks. Bottom left area is where the digital circuits are, with ground plane. Top left are the analogue output filters. Right is the caps, rectifiers and regs of the power supplies - digital at the bottom and analogue at the top.
The AD1955 sits about the centre of this pic, and if you look closely you'll notice two small holes I drilled in the groundplane either side of it where I will later install the 10uF decouplers.
The second pic shows the component side, prior to any hacks - the 'virgin board' if you like, although sullied by the two small holes near the DAC chip. The analog supply is pin15, that's at top left.
Third, here's the meat of the digital circuitry and I've already added one decoupler to the AVDD (analogue positive supply). To the right of the 24.576 XTAL (not required) is the DIR9001 SPDIF receiver. The DIL chip is a multiplexer allowing both USB and SPDIF input...
ID:	165   Click image for larger version
ID:	166   Click image for larger version
abraxalito's Avatar
Views 1246 Comments 0 abraxalito is offline
Old
Rating: 3 votes, 5.00 average.
Don't be such a scientist!
Posted 15th June 2010 at 04:21 PM by jan.didden
Updated 15th June 2010 at 04:25 PM by jan.didden
I didn't get it. There are gifted design engineers on this forum. They get involved in threads. BUT, in most cases, eventually an 'issue' develops and the engineering guy gets binned or banned or asks to be banned. Why why why? Happened to me a few times. Not that I got banned, thank Ohm, but I got close to leaving because I too got enough of it.
Of what?
Let me explain. Most engineering types like to explain things, to tell others with less experience and knowledge what they are doing wrong and how they can do it better. They inundate you with facts, figures, links to engineering papers etc, and expect that the other guy flows over with gratitude. But, funny enough, it doesn't happen that way. The 'other guy' gets pissed off from being corrected all the time. Hell, he didn't come here for that, he came to have fun, discuss his hobby and his latest creation.
[flashback] At the time Al Gore's An inconvenient Truth came out, the same director (!) also made Too...
jan.didden's Avatar
Views 9708 Comments 28 jan.didden is offline
Old
Salas HOT ROD DCB1
Posted 15th June 2010 at 03:56 PM by Tea-Bag
Updated 27th November 2014 at 04:51 PM by Tea-Bag (added BOM)
So I am going to write some details down about the DCB1 Hynotize Hot-Rod buffer. The current production board is black, 2 oz copper and 2mm thickness. (See below) The below blue pictures are prototype boards and are not representative of the product.
Here are some of the specifics to help understand ordering parts for it etc. This is not a detailed build guide, but there is a link to one below from another forum member.
They can handle 10mm pitch snap-in capacitors 25mm width capacitors.
There are positions for smaller MUR120 type diodes OR MUR820 style TO-220 style diodes. Not both!
The vRef LEDS can now be bypassed with a 25mm Film cap or a 100uf electrolytic. The film cap by consensus is best at .22uf.
Click the image to open in full size....
Tea-Bag's Avatar
Views 33054 Comments 0 Tea-Bag is offline
Old
My project blog
Posted 14th June 2010 at 03:18 PM by taro2ss
Updated 14th June 2010 at 03:20 PM by taro2ss
Hello,
Click here is my project blog. There is some information about my headphone amplifier products.
Thank you.
Views 687 Comments 0 taro2ss is offline
Old
Towards a better DAC - introducing the HEC
Posted 14th June 2010 at 04:16 AM by abraxalito
Updated 8th September 2011 at 03:05 AM by abraxalito
Doug Self's comprehensive work on power amplifiers has been an inspiration to me over a number of years. In it, he coined the notion of the 'blameless amp' as one which was beyond reproach, measurements-wise. So I pondered over running with the notion of 'blameless DAC' along the same lines. Initially this sounded attractive, even though not entirely original. Google found a reference to it already here on diyaudio but could not show me the actual posting.
I decided on reflection that the 'blameless DAC' would be not such a good idea. That's partly because for me, measurements are not the goal of audio design. Enjoyable sound is what does it for me, not vanishingly low THD figures. So a 'blameless DAC' could only be blameless if measurements are God, so to speak. For someone like me for whom auditory experience is all, I decided I'd need another term for my DAC project.
I've settled instead on the term 'highly evolved converter' or HEC for short. This recognises...
abraxalito's Avatar
Views 3178 Comments 8 abraxalito is offline
Copyright ©1999-2017 diyAudio
