900W H-class PA Amp with Limiter
hi apex,
i tried your darlington topology.and guess what everything was ok no abnormal
readings.no sagging of voltages. dc offset of 2mv.same reading on every collector.
then i switched back to normal driver stage with mje15032/33 .switched on
2.1mv dc offset.no voltage sagging everything normal.then i saw i forget to add
22ohm resistor which was connected to both emmiters of mje15032/33.as i
connect then every thing messes up.30 mv dc offset.voltages sags 60 to 38
and-60 to-14.different reading on every collector.what should i do.
thanks
ravs
be a vegeterian.....
Use darlington topology if work good on your amp.
triple ef bias
hi apexaudio
greetings made yourtriple ef can you tell biasing method will add 2 more output pairs
thanking you
andrew lebon
hi apex,
cant use tripple darlington as pcb dont allow this.i have to wire them seperaterl
cant i raise the value of resistor say 82/100 ohm or add a 100nf across
the resistor .raising the resistor value 100 ohms makes thing normal.
i want to complete it as soon as possible
thanks in advance
ravs
be a vegeterian....
