That photo looks eerily like my own workplace, a few hours from now.The boards are stuffed. The chassis is in France.
My chassis was finally evicted from Charles de Gaulle, and is now making its way through the US.
Don't forget when soldering in your front-end JFETs to leave the leads on the long side for easy de-soldering and recovery later. Best to do what you can to preserve these rare creatures in case you wish to re-use them, such as on a new front-end design. Or, you could socket them with machined pin sockets (which is what I will probably do).
Slowly starting to look like an amp...
Any progress update ? How much is heatsinks temperature after 1 hour ?
Hot or very hot ?
BTW thermal paste included in the kit that is "take great care of the details"
Hot or very hot ?
I´m interested too, but, well, approx 60 Watt for 30cm x 17cm heatsink should be ok..
Do you mean I wasn’t supposed to peel them off?
Put a coat of clear nail polish over it.
Yes heatsinks with all chassis looks comfortably oversized
You have a part number for this?
Soldering tips from a Pace HiRel course taken long ago. Clean pads and leads with lint free wipes and 99% Isopropyl,never use erasers etc. Flux all joints "flux is your friend".Solder tip about 650F,use SN63/37 eutectic solder (this was long ago but lead free is a pain in the As#).Clean residue with Isopropyl (acid brush works good).
just fired up mine, it works
irf250 is rather hot, but all voltages are as supposed to
i guess i am not accustomed to run things this hot
Awesome! Did you measure voltage at R2 and ground to verify the 20v?
just fired up mine
c'm on gift us a little vid ; )
@ Adason
Congratulations! You are the first Nr1 " Greedy Boyz Gold medal "
If confirmed by full finished kit assembling photos presentation
Everybody chanting " We are the Champions "
Edit: extract about adjustement from Mr. Pass article
Solder tip about 650F,use SN63/37 eutectic solder...
My iron is typically set to 666 deg F, because my amps will play a lot of metal when done!
Parts kit is in transit, and should arrive tomorrow. What a week coming up - vfet & 2nd Covid shot!
- DIY Sony VFET Builders thread
