The diyAudio First Watt M2x
Joined 2019
heatsink pattern
Go to the DIYaudiostore.com site and fish around for the UMS spec. they have it there. You will have to figure out where you want to place it on the sinks but that is easy. They are predominately on 40mm center They have the compete pattern. The drill is 2.5mm with a 3mm by 5 tap. Set it up so that you drill between the blades and you can drill through if you want to. Lot easier than blind hole. Be careful on the tapping. Don't break it off. There is a kind of tap you can get that looks like a drill which reduces risk of breaking. Don't know what they call it.
Warning. Precision is important. On some boards there is very little wiggle room.
Just did it. Good luck
Don
Now the hard part begin.. drilling and tape holes. Big heavy heatsinks.. hope I can get things together.
Joined 2011
Nelson Pass builds sleepers too. He builds them, listens to them, tweaks them, asks trusted-ear listeners (30 year friends) to audition them, tweaks them some more, and then releases them to the public. With no advance hints or pre-release marketing or sneak-peek revelations at all.
I hope your sleeper is as awesome as some of Nelson Pass's sleepers have been.
Joined 2014
Greetings, I just finished my M2X with Ishikawa boards late today (way overdue). I made the recommended modification and used R6 = 37k and RV1 = 20k. I can't get the offset to zero. The closest I can get is about +5V (both channels). I'm assuming I made some bonehead mistake and it's not a matter of just decreasing R7. I read through about 50 pages of this thread. I haven't started to troubleshoot this but thought I'd be lazy and ask what kind of obvious things I must have screwed up. Thanks for your patience.
Joined 2014
photos
Here are some photos. I hope they show something interesting.
I just getting ready to go over each component and verify against schematic.
