Aleph J illustrated build guide
Thread Tools
Old 7th January 2015, 03:51 PM   #1161
Russellc is offline Russellc  United States
Originally Posted by 6L6 View Post
If you are using a single-ended input (RCA) the pin needs to be attached to "+ IN", the outer connection to GND, and "- IN" jumpered to GND.
It shouldn't hum at all, you have something mis-wired...
Glad you mentioned this. Just getting ready to wire mine up, and looking at your build guide, I was wondering what that little wire looping over to ground was! If one would like to wire it balanced, other that having appropriate input jack, is there a diagram showing proper wiring? I see one pick in the build guide where someone did this, (Grimberg) but I cant follow the wires with any certainty....
Thanks for any guidance dumbed down enough for me to follow...
Russellc
Pass B-1 preamp, Pass BA3 preamp, Wayne's 2018 LS, Iron Pre, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 7th January 2015, 05:06 PM   #1162
6L6 is offline 6L6  United States
6L6's Avatar
Balanced is easy - XLR Gnd, V+, V- connect to pcb GND, +in, -in, respectively.
Old 7th January 2015, 06:34 PM   #1163
Marra is offline Marra  United Kingdom
A few Google images for XLR wiring
https://www.google.co.uk/search?q=xl...tm%3B400%3B194
Don't forget the link between pins 1 & 3 when using RCA input.
Old 7th January 2015, 09:21 PM   #1164
Yes, I want to do it like the pic in the 6L6 guide, with both rca and xlr. I'll work up a drawing of how I think you guys are explaining so you can give it a look if I have it right. The way Grimberg did it is how I want to do it. I saw no switching, just the RCAs and the XLRs. I just cant tell whats hooked up to what on the XLRs in the pic.
Thanks again guys!
Russellc
Old 7th January 2015, 09:29 PM   #1165
6L6's Avatar
Note the jumper in the XLR from V- to GND
[IMG][/IMG]
Easy. Wire the XLR to the Aleph J board as described in post 1162.
Wire RCA inside to V+, RCA outside to GND. Make sure the RCA is isolated from chassis. (Which is normal)
Remember to use jumper in XLR when using RCA.
Old 7th January 2015, 10:19 PM   #1166
Is this how Grimbergs is in the pic? It looks like there is a green jumper going from the center of the RCA to the right side of the XLR, the ground connection?(looking at the diagram provided by Mara, "post 1")
Then it looks like another green wire attached to the same connection on the XLR as the green jumper, and that goes back to the pcb to the Ground? (That doesnt seem right, but I have no idea) Your response says RCA inside to V+, (which makes more sense) I must be missing something on that.
Then there is a red wire going to xlr pin on the left side, diagram shows as "+" (pin 2 in Mara diagram) and then goes back to pcb +in?
That leaves the black wire, which appears to go to the lower pin on xlr "-" (pin 3 on Mara diagram) and I assume goes to the -in on pcb? It also appears (black wire) to jumper over to the outside of RCA.
Your instructions are clear, I'm just having trouble charting them out on Grimbergs pic.
Finally by "Dont forget the jumper in xlr when using rca" is that the small jumper shown that I commented on in 1161, or have I missed something else?
I appreciate your bearing with me!
Russellc
Old 7th January 2015, 10:27 PM   #1167
Whoops, I've been looking at "front view" of XLR, let me re sketch...
Old 7th January 2015, 10:33 PM   #1168
grimberg is offline grimberg  United States
grimberg's Avatar
Russellc,
You can see a slightly larger version of the pictures in the original posting.
http://www.diyaudio.com/forums/pass-...ml#post3481260
As Jim (6L6) correctly described, I first made the connection between the XLR jack and the board. On the back of the XLR the pins are numbered this way:
1 - Ground
2 - Positive
3 - Negative
Go to this page and click on the "Drawing NC3FD-L-1" link to see a pdf file of how the pins are numbered. It may help you understand the picture.
After connecting the XLR to the board, I connected the RCA jack to the XLR jack. Only the Positive and Ground are connected.
When using the XLR, leave the RCA disconnected. When using the RCA, short pins 1 and 3 of the XLR. I made a U-shape bridge using 18 AWG gauge wire.
I hope this helps.
Old 7th January 2015, 11:01 PM   #1169
Now do I have it right?
Old 7th January 2015, 11:04 PM   #1170
Originally Posted by grimberg View Post
Russellc,
1 - Ground
2 - Positive
3 - Negative
I hope this helps.
Thanks, I think I've got it, and thanks for the additional info! Nice build, and I have wondered about wiring the thermisitors correctly when 2 transformers are used. Are the jumpers I see on your XLR plugs in place of the small ones 6L6 used on the boards of his non XLR example?
PS, yes I see that they are now, thanks for the link!
Russellc
Aleph J illustrated build guideHide this!Advertise here!
Thread Tools
An illustrated guide to building an F5 6L6 Pass Labs 1849 1st June 2021 06:37 PM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 07:13 PM
Aleph J Stuffing guide ? thor61 Pass Labs 2 4th September 2011 08:02 PM
My first step by step LM3886 illustrated build kgb_m3 Chip Amps 19 17th February 2010 04:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
