First project - Will this crossover design work?
Old 15th March 2020, 04:13 AM   #1
Mygyth is offline Mygyth
Smile First project - Will this crossover design work?
Hi everyone, this is my first post, and my first project. Please be patient with my newb questions.
First up, sorry if this is posted in the wrong forum, please let me know where to post it if so.
So i have no experience at all in speaker design or building, and only middling experience in electronics. However, ive been interested in taking on a project for a long time and have been watching youtube vids/collecting gear like soldering iron etc for about a year now.
A few weeks back, i found a retro style radio for sale at a garage sale. I decided to make this my first project. This is intended to be a bluetooth speaker system for my workshed. I want it to have bluetooth radio and AUX functionality with a remote control. So I stripped out the old electronics, and cleaned up the shell. (cleaner than whats shown in this pic anyway)
I bought a bluetooth decoder with FM, Aux and USB functionality on ebay.
I then went to do the quick job of making some speakers for it.... Oh bless past my innocence.... 3 weeks later, countless hours on youtube, a few tutorials and 3 programs later, i have this:
Now, like i said, i have zero experience, and am just learning what i can on the fly. But, i think if ive understood everything correctly, what i have here should work? I figured id hop on here and ask you guys what your opinion was before i fork out several hundred dollars on making it happen.
FYI, this is the tweeter i plan on using:
ND28F-6 1-1/8" Neodymium Dome Tweeter 6 Ohm - Dayton Audio
And here is the woofer im looking at:
TCP115-4 4" Poly Cone Midbass Woofer 4 Ohm
Im planning to make 2 closed speaker boxes out of MDF, (one woofer and one tweeter in each). one for each side of the radio case, and mount my bluetooth thingo in the middle. Put some nice cloth in front of the speakers to keep with the retro asthetic. etc etc.
My biggest question right now is the 2400uF capacitor on the woofer. I am given to understand that ususally, you want to stick with film capacitors in stereo design. However, obviously a film capacitor of that size would be prohibitivly expensive. This video seems to claim that if you have a large electrolitic capacitor in series with a resistor, and those in parralel with a film capacitor, then it should be fine.
YouTube
Now im pretty sure that describes what i have in the above schematic. Can anyone confirm for me please if the above system will work with an electrolytic capacitor in the 2400uF position. If not, what are my alternatives?
Many thanks everyone
Old 15th March 2020, 05:42 AM   #2
AllenB is offline AllenB  Australia
AllenB's Avatar
Electrolytic capacitors get a bad rap, but they aren't as bad as that.
Anyway, remove it altogether. The 2400uF value means that it is acting like a piece of wire at audio frequencies.
Old 15th March 2020, 06:08 AM   #3
Thanks AllenB. Tried that, and like you said, made no difference to the overall graph. I guess that was an easy fix
Does everything else look good to go?
Old 15th March 2020, 06:18 AM   #4
Also, My next question is how do i choose a amplifier and power source for the proposed system?
Old 15th March 2020, 06:41 AM   #5
AllenB's Avatar
I would probably start by trying to ditch the remaining woofer resistor. This will take some adjustment of the other two components to restore the balance. This should take the impedance back above 2 ohms.
What are your Voltage and current requirements for each component?
Old 15th March 2020, 11:05 AM   #6
Thanks again for your advice. I tried taking away the resistor, but it creates a HUGE spike in the impedence @ 53 Hz (Image 1). I couldnt seem to reduce that spike with the other components. So I tried adjusting the resistor's value and adjusting the other components until i had a minimum impedence of 4 Ohms (image 2). Im worried that the impedence graph is still too variable.
1. What is the minimum impedence i should be aiming for?
2. How much variability is acceptable in the impedence graph?
3. What other options do i have?
Had to use a website to calculate the current and volts from the watts and impedance, but here we go
Tweeter:
Impedance: 6 Ohms
RMS: 30 watts
Current: 2.23606798 amps
Voltage: 13.4164079 V
Woofer:
Impedance: 4 Ohms
RMS: 40 watts
Current: 3.35410197 amps
Old 15th March 2020, 11:29 AM   #7
AllenB's Avatar
Why don't you like this?
I thought you wanted to power the bluetooth frontend?
Is there a reason you cannot use a normal audio amplifier or is that ok?
Old 15th March 2020, 11:38 AM   #8
I was under the impression that the impedence graph should be as close to flat as possible?
The bluetooth device is 5V, not sure what current it uses. Ill get my altometer out tommorrow to check. Honestly, ive not really looked at different amplifiers at all yet. I figured id design the speakers first, and get an amp/power supply that suited it after i knew what i needed.
Old 15th March 2020, 11:50 AM   #9
system7 is online now system7  United Kingdom
system7's Avatar
I think you should look at a vaguely similar well-executed project for an idea that might work:
Eekels' Mini
Basic circuit should work with most 4" plus 1" drivers. And it does everything that is good here. You always get an impedance peak on the bass, whether closed box or reflex.
FWIW, you have selected a Qts 0.35 woofer more suited to reflex, which means you have a port in the cabinet. About 5L, I'd guess based on a Vas of 3.1L.
Best Regards from Steve in Portsmouth, UK.
Old 15th March 2020, 11:51 AM   #10
AllenB's Avatar
To deal with this you can use a Voltage source amplifier. Typical audio amplifiers are like this. They are designed to ignore these impedance variations (sort of).
Ok, if it already has a supply then we don't need to measure that one.
First project - Will this crossover design work?Hide this!Advertise here!
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux Tfive PC Based 612 29th March 2020 10:15 PM
crossover design sb17nrx ,sb29rdnc. Will this work? mallikreddyk Multi-Way 40 27th October 2018 06:28 AM
3 Way Active Crossover Design project powagrip Multi-Way 13 23rd February 2005 08:06 PM
have a speaker design- need crossover- will this work? trespasser_guy Multi-Way 1 26th August 2002 05:23 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
