Don't forget to chamfer the insides of the driver mounting holes.
Dang, I knew one of you guys would pull me up on that
I didn’t make the cutouts until after I’d assembled the cabinets so I’ll have to source some kind of “reverse” chamfer cutter.
I did do it on my front A11MS cabinets but do you think it makes a noticeable difference ?
It is pretty important afaik, I wouldn’t skip out on it. It is not too much work by hand using a rasp either.
Cheers guys, I’m on it
...so I’ll have to source some kind of “reverse” chamfer cutter.
A big a$$ rasp (with a round side) is the easiest way to do this. It doesn’t have to be pretty.
dave
dave
Thanks Dave,
Googling “rasp” turned up this drum rasp which would also be handy for easing out, when you don’t have exactly the perfect size hole saw.
This is the one i have and have found works well: 4-in-1 Bastard Half Round Flat Rasp, Carbon Steel Hand File for Wood - Needle Files, 4 Kinds of Grit Surfaces: Amazon.ca: Tools & Home Improvement
dave
dave
I had a strange day yesterday, I sold the very last Alpair 7.3 I had in stock almost at the same time I took delivery of the new stock of Pluvia 7.2 HD, their 'spiritual successor'. Kind of a circular feel to it
Anyway I spent yesterday and today getting the new products up on the website, here are the links.
Pluvia 7.2 HD
Pluvia 7.2 PHD
Alpair 5.3
CHN-50
Pluvia 7.2 HD
Pluvia 7.2 PHD
Alpair 5.3
CHN-50
- Full Range
- New Markaudio Drivers
