As long as you are using decent ply you will be fine. You can scab on an extra layer at the driver cut-out if you are anal.
dave
Thanks for the tip, not sure how to determine decent plywood... also thanks for the phrase of the day, thanks to this forum my English improves 😎
The most layers and void free.Thanks for the tip, not sure how to determine decent plywood... also thanks for the phrase of the day, thanks to this forum my English improves 😎
Ideally, you want a multi layer void free plywood such as Baltic Birch -
3/4'' Baltic Birch Plywood| Rockler Woodworking and Hardware
Hi...looking to assembly a Frugel Horn for the Alpair 12P. The new drivers will arrive in June, so I have time to build them..How I coud get the drawings plans..thank you
You want Joan. Like FHXL requires a minimum $10 donation to the forum. Then email me the receipt and i will send the plans URL. Joan is the least complete of the 4 Frugel-Horns, it will grow as builders require more specific drawings (largely material thickness).
dave
dave
Ok my space is close enough to done for me to start putting my system back together. The Joan's sound better in the finished space as I'm fiddling with placement. The room is about 14ft x 25ft and they are on the short wall.
I have a small 8" sub hooked up, long term plan is building a small pair of sealed subs. I can hear the bass with the Joans but miss some of the tactile feeling.
Now is my turn 🙂 I have got all the plywood parts... but... word of caution...
On the driver drawings that are available online the distance between the middles of the mounting holes is Ø185.7mm, I trusted this value and now have a problem because the measured value is about Ø183.5mm. I need to fix the fronts now.
I did some progress:
And I would like to ask for advice regarding stuffing. I have used some polyester for filling pills but I think it's with silicone and it's too slippy and it falls down. I used 2 x 170g (6 oz) per speaker. What is recommended amount for Joan and Alpair 12P?
Also: where did you get the legs for the speakers? 🙂
I used "tulle" bought from a fabric store. Commonly used in dress making, it's very fine mesh and comes in different colors and patterns.
jeff
Someone else will have better stuffing/legs advice.
Just sharing a picture of mine painted purple 🙂
Nice looking legs Sodacose, I'd have use them if I had a carpet 🙂
There is probably not a lot of people building Joan with Alpair 12P, so your input would be really valuable 🙂
I will install some carpet spikes, I just need to buy a couple sets.
I did the same for the lining, all interior surfaces behind the driver except the back of the baffle. The last side I sprayed and added material after everything was glued up.
I used polyfill (pillow) to stuff and just added to the closed folded section of the horn, following the instructions for a regular frugal horn.
Regarding the linning I did something like that, noting on the top wall and on the back (apart from poly).
Some felt on the inside top and back is suggestted.
If you ever heve to change speaker wire or break a binding post you will be in trouble.
dave
I thought of the wiring when building as I also used posts. If there ever is an issue, I'll cut it all out with a hole saw and mount a cup or plate. I like the clean look of posts though (even though it's on the back).
Speakers sound great now that I've got mine all lined (including top and back), stuffed, and glued. Hard to directly compare, but I stand by my earlier listening assessment that they go a little lower than Super Pensils with maybe less midbass hump.
OK, I'm going to add the two missing linings, thanks for the hint 🙂
dave
Yes, I noticed that a bit too late that I couldn't reach my hands, but I could always use a saw, cut the connectors and knock them out, stick the wooden spikes on the wood glue in the holes, putty, paint the panel again, and mount new connectors at the height of the speakers.
How much polyfill would you suggest on the front and the back chambers?
PS. With 170+170g I noticed that I hear much better 31.5Hz than 40Hz, also 80Hz is quieter than 70Hz, but that may depend on the room specific and speaker position which is completely random now.
Sodacose,
What material do you mostly play through the Joan horns?
It has been mostly pop and classic rock so far (with the kids). I'm waiting for a good opportunity to bring down my turntable and listen to more acoustic and jazz.
Thanks for that, I have added the missing lining, removed polyfill from the front chamber, left 170g in the rear one, and the sound popped out, there is more clarity, "sharpness".
- Full Range
- Alpair 12P cabinet options
