Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Thread Tools |
#5851 | |
I always wondered where the "L1" was located... I will not start this process until a ReclockPi is in hand when I have to purchase my 2nd TransportPi. My 1st TransportPi will be left un-modded. |
#5852 | |
Look at b and d.
If you want to use an independent DC power supply for TransportPi, you will need: a. Solder the supplied DC terminal connector to the position of J3. b. Remove FB L1 at bottom side of PCB if you don’t want this power supply connected to GPIO anymore. c. Feed good 5V linear/ultra capacitor voltage rail or 3.3V LifePO4/ultra capacitor rail to J3. d. If 3.3V pure LifePO4 or ultra capacitor voltage is used, it’s highly recommended to bypass the on-board low noise LDO by soldering jumper wires between IN and OUT as described above Quote:
#5853 |
#5854 | |
b. unsure how to remove. can I just pull out the metal piece off of L1? do I need to de-solder? Note: I cannot proceed ATM because I need to purchase a second TransportPi. My current TransportPi is in production un-modified, so I don't want to touch since STABLE. But this will really be beneficial once I get the second TransportPi. Last edited by A123; 13th January 2021 at 09:32 PM. |
#5855 | |
L1 must of course be desoldered.
#5856 |
#5857 |
Not comparable to how it sounds in real live, but it gives an idea
![]() Recorded with a Tascam DR-40 (48kHz) Raspian (Ian Canada) streamer Audio-GD R8 (2021) DAC Audio-GD Master 1 Vacuum XLR preamplifier Mordaunt Short Performance 6 Limited Edition loudspeakers (converted to full active with 6x NCore poweramp's (Two Hypex FusionAmp's FA253) Freya Redings - Lost Without You - YouTube Simply Red - So Beautiful - YouTube Cigarettes After Sex - Apocalypse - YouTube Patrick Watson - Lighthouse - YouTube |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Line Level | 3279 | Today 08:01 AM |
exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1422 | 22nd March 2020 03:15 PM |
DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 01:50 PM |
Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 05:00 PM |
asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 10:22 AM |
New To Site? | Need Help? |
