@BMW850
Clocks are inside the can in your DAC. You can not see what they are until you disassemble the can.
I suggest just keep it as is. I don't think this DAC can be upgraded, even with the same brand DDC.
Ares 12th will be much easier to replace the clocks. Hopefully I get it compared the SQ with my Halo after I upgrade the clock.
@iancanada of course with pleasure, and I will be happy to take the time for you
@Yveskoala
Please do it step by step and don't mix things up.
I suggest run the software with RPi only, only install MonotorPi to the RPi GPIO. Do not install anything else.
Make sure MonitorPi OLED shows correct music format when you play, then install them to the system.
Sorry for the typing mistake, it's StationPiPro J14.
Please download and read the manual and schematic:
https://github.com/iancanada/Docume.../StationPiPro/StationPiProUsersManualV1.1.pdf
- Digital Line Level
- Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
