thank you for comment non i stay my home beacuse covid 19 ,many shop for electronic parts close.
to day i write about 12v class d from low pass filter cor
vdo YouTube
i already make this class D amp discrete you can refer to mr kartino design ucd xlite discrete, its has very stable design and no heat, high efficiency.
Your really do? That's funny as for me this looks like a nightmarewoahhhhhhhhhhh i like that
Maybe I am too German anyway....
class d for education the circuit use ne555 generate triangle 130khz lm393 mod audio ,triangle to pwm ,sent to class d ampliflier
vdo YouTube
vdo YouTube
class d 500k by foodland , this circuit have ic lm311,ic nand gate 7400 and ic ir2110 L filter 25uh c105/250v
vdo YouTube
Hello Surachit
I know this circuit from Bangkok - Banmore Thai Electronic Shop
I am Farlang, my Holiday Thai Girl friend / now my wife
bought this circuit for 1500 THB 7 years ago as an
assembled working Class D PCB module in Banmore for me.
Later I have make new PCB design for PA amplifier look attachment.
Hi Surachit
If you want stable working amp, you will need a lot updates
look D4K5 Schematic and you dont waste your time
Gerber PCB file you can have for free
LM311 is not good solution, Tl071 input design is better
IR2110 need Buffer
use IRFP4227 Mosfets
Inductor T157-2 need 38-42 turns
IR2110 need Buffer
correct circuit i forgot zd5.6v for op amp
my wave side many circuit keep class d 500k by foodland - Class-D - LN-Electronic
Joined 2009
maybe a mod can fix it, the title of this thread is misleading, I expected some 10kW of fireworks.......
lol
mini d by foodland , this circuit has lm311 irf9540 and irf540 vc+_45v class d fre 100khz coil 150uh c 2.2uf
vdo YouTube
vdo YouTube
- Class D
- class d Earthquake PH-10000W
