Hi Olly
What frequency is the tcxo and did you just swap the xo? Please share the site where you got it from.
I've ordered my v200 and getting my linear psu and other parts ready while waiting for the amp to arrive.
cheers
Hi Bernie7/Etienne,
freq is 12.288Mhz
got it from ebay Vanguard TCXO 0 1ppm 12 288MHz Ultra Precision Golden Oscillator | eBay
Put it on a buffer module CD Player High Stability Clock Buffer Module No TCXO Included Assembled | eBay
Cheers
Olly
Hi Mike,
Sure I will try it
Have you used the standard version ie 1.5A or the bigger 2A ?
Cheers
Olly
I already had 4 of the LL1694/1.5A version. If you model the PSU in PSUD2 software then you can simulate the peak current draw. The inductance will be lower for the 2A version, personally I wouldn't go there unless necessary.
Here's my latest PSU (parts bin special):
Got tips for modelling in PSUD2 if you need.
Mike
PSU philosophy here: Flesh And Blood The Reichert 300B Article By Herb Reichert
Yes, I know it's about a tube amp; read the bit on the PSU and think conceptually.
Mike
"The power supply is everything in these little amps and it also seems to be the area where designers agree the least."
"Low impedance and minimum storage gives fast recovery and fine texture to the sound. Remember, most amps under 2000 watts are running at or near overload. Let's make them sound unstressed at overload. Then the music will sound unmechanical."
Mike
Built the "parts bin" PSU shown above. With resistive loads on the output, voltages match simulation exactly.
It needs at least 160mA current draw to behave like a proper LCLC supply.
I'm "currently" (ha ha) running two 330R 25W resistors permanently across the final cap to ensure this is (nearly) met even without a load. Also to discharge the caps upon power down.
Constant current load:
Resistive load:
Listening tests soon!
Mike
Resistive load:
Mike
Well unfortunately the new PSU is better than the last one.
I say unfortunately because it's bigger, heavier and more expensive.
The last PSU (Connexelectronic SMPS with a Lundahl LL1694 choke) is still very good and slightly laid back. Great for movies.
However the new PSU is spooky good. Not going to go all "audiophile" on you, it's simply better and worth the effort.
Mike
Mike
Hi Bernie7/Etienne,
freq is 12.288Mhz
Cheers
Olly
Many thanks, Olly
Etienne
Hi Olly,
Could you confirm this is the way you have connected your new clock :
- Removing C378, C379 (and the old crystal, of course)
- Connecting buffer module output to right-hand pad of C378
- Connecting buffer module ground to right-hand pad of C379
Also, how did you feed the buffer module ?
Etienne
Etienne
Mike
Hi Mike,
Again thanks for sharing
Just ordered a LL1694 to add in my PSU. Will add it with a nice MKP.
If that works well, will go for the full monty (ie your PSU).
Of course I will report.
Quite impatient actually
Cheers
Olly
Hi Olly,
Etienne
Hi Etienne,
yep that's ok, I will add a join between the 2 pads of C379 (instead of the cap actually) and remove the resistor between C378 and C379.
That would do the trick.
Cheers
Olly
Hi Mike,
Cheers
Olly
Great stuff Olly! Looks like you and me are the only ones surfing the big waves.
Have you downloaded PSUD2 yet?
Mike
Hi Mike,
Not sure why but that's cool we have the full waves just for the 2 of us
Started to read the PSUD2 web page when I bumped into the intro
Are you sure an unregulated PSU is what we are looking for ?
BTW half waves are possibly the best way to go
PSU Designer II is designed to help you with the design of simple linear (unregulated) mains power supplies, as often found in tube amplifiers.
Hi Mike,
That's a terrible pun. You are officially off my Christmas card list.
Every power supply is regulated to some extent. The designer has to decide WHERE it is regulated and what happens after the regulator. I've tried various approaches on these amplifiers and I think you'll enjoy the journey.
Getting a PSU to work with an amplifier is like getting an amplifier to work with a speaker. One affects the other and sometimes you just gotta try sh1t out.
Happy with the linear PSU but when I build the triamp setup I think the linear PSU will be for the tweeter.
Mike
Simple Voltage Regulators Part 1: Noise - [English]
http://www.calex.com/pdf/3power_impedance.pdf
Mike
Mike
Mike
Thanks for the tip on using a common mode choke. I put a generic CMC right after my LPS and the highs did smoothen quite noticeably.
My amp (without Cmedia and Wifii) which I ordered direct from China just arrived; it is v200.6
Cool! Just to be clear, the Lundahl is a differential choke, not a common mode choke. However, due to the leakage inductance, it also rejects common mode.
KISS 134: Noise Reduction with Lundahl’s Double-Coil Cut-C Core Chokes: a pictorial essay by Andre Jute
mike
Well my 2 V200.7 amplifiers arrived today. Incredibly I now have 3 identical amplifiers.
Unfortunately the casework on one of the amplifiers is twisted by over 2mm. This means the amplifier rocks on its feet.
While the PCB manufacture is beyond reproach, it appears that I.AM.D have problems with assembly.
All,
Am am looking for a fully digital Amp with WiFi (or bluetooth) at the moment and stumbled upon your thread.
Is this the famous V110?
wifi draadloze stereo versterker hifi audio digitale versterker 2x150w zuivere metalen behuizing afstandsbediening geen voedingsadapter gratis verzending in 2 x draadloze wifi versterker hifi digitale audio versterkers 150w zuivere metalen behuizin
And if so what would be the better amp? V200, V110 or the FX audio D802C?
- Class D
- I AM D v200, Fx Audio d802, optimisation and TPA3116
