Hi Ben,
I’m aware that SE amps clips asymmetrically, this amp is more than usual.
Any solution to improve this without increasing the bias ?
Choke loading a single ended amp is probably the most efficient topology. 19V and 1.5A in is 28.5W in and output is 10W into 8 Ohm - that is 35%.
When you say that the amp clips asymmetrically more than usual, what are you comparing it to?
I’ve compared it to other class A but it’s been a while, I just bought a digital scope, my previous one (analog) had been broken for years..
All I can say is that the output wave form will start to flatten when clipping starts. As the output voltage increases further, the waveform flattens more. So more asymmetry indicates higher level of clipping, or higher level of exceedance of maximum power. This is for single ended amplifiers, which are Class A.
By the way, using a higher impedance test load or speaker will increase the output voltage before clipping.
If Class A, but push-pull, then symmetrical clipping is possible.
What I’m trying to say is that the negative waveform starts clipping very very early, the positive waveform is at least 6 times higher in amplitude before clipping starts on the positive side…
My load is a resistor of 8 ohm, 200W
"very very early" is meaningless. What is the voltage when it starts to clip?
With single ended amplifiers, what you observed re: negative and positive waveform is normal.
Let me get a preamp and redo my setup.
I could not get the positive side to clip just with the output from my sine wave generator as input signal.
The output positive waveform will not clip until it reaches power supply voltage.
I am asking at what negative output voltage the negative waveform clips at (voltage of negative waveform on oscilloscope screen).
The Zenductor is not a low distortion amplifier, and the difference in magnitudes of the positive and negative waveform is 2nd order harmonic distortion.
Changing the operating point of the MOSFET, so it is in a more linear region of the characteristics curve will lessen the difference in positive/negative response. A more linear region would have the curves more evenly spaced across the load line.
Thanks for wanting to help guys 👍
Maybe my function generator is not up to the task…the negative waveform starts to distort at -1 Vpk..while the positive stays undistorted up to + 19Vpk
My output device is FQH44N10.
I have to buy better equipment before I continue testing.
This is what I see with the equipment I currently have, maybe one of these instruments is not working ok.
Or maybe the amplifier is not working properly. If this is built with your own board, double check the circuit. Compare your schematic to the official schematic. Perhaps there is a discrepancy.
My PCB is working fine, it sounds very good but the output waveform is just distorting very early.
Something is not working properly if the output is distorting at such a low output voltage.
You can check your signal generator/oscillator by checking its output with the oscilloscope. You can then also check the signal/generator connected to your preamp (if you used a preamp in your amplifier test) with the oscilloscope. If they all check out, then the amplifier is suspect.
Also note that the OUT+ on the amplifier is Ground, and OUT- is amplifier output+. So be sure to connect the oscilloscope Ground to amplifier Ground.
A bit late to the party...Hi @Vix
Have you had a chance to measure the output power into 8 ohm (just before clipping) when biased at 19Vdc, 1.5A
I tried to check it earlier but the clipping was asymmetrical (more than usual) the negative part was clipping way earlier, it got better when I increase the bias but I’d rather keep it at 1.5A
Is there anything I can do to reduce such a big asymmetry when it clips ?
Eric
No, I did not test anything. I just enjoyed it "as it is".
With these circuits, more bias current is always welcome, as long as you don't burn anything.
If the heatsinks aren't big enough, a 12V fan, run at 6-7 V helps a lot (while remaining quiet)...
I will have everything to build a pair of these by the weekend but I didn't order IRFP048s. I do have several IRFP240s lying around which I know @Vix used. I have two 19VDC supplies I plan to use with big heatsinks so I'll bias at 1.5A. Is there much sonic difference between the two in this circuit? I don't understand MOSFET selection for audio applications very well maybe someone can point me to a resource?
I finally got a chance to build one channel (Covid last week). Thanks @e_fortier for the GBRs. Ran it on a huge heatsink at 19.5 V with the bias set to .75V across 0R56. My power supply says it's putting out 26 watts. Sounded very good but couldn't get much gain. I need to hook it up to one of my preamps when I get the other channel figured out. I have a FE 2022 and a tube preamp to try. I might cut this huge heat sink in half for two channels. I have a nice box to mount each channel in. Ran the output to a 10V sine wave (PP I think) with my function generator and didn't see clipping.
- Zenductor
