Antonytls said:WM8816 is no longer available on Farnell and Newark...
The Wolfson site lists it as obsolete and with no stock for web orders. They do not appear to have replaced it with any other product.
I think MAS9116 is the exact same chip trying to find a source for MAS9116 atm
Yes, I noticed that too, but I am not sure the MAS9116 is easier to find.
Their specsheet is dated Dec 2000.
If you can find some, please let us now.
Christian
Christian
all i found was their "distributor/sales office" page
http://www.mas-oy.com/company/distributors.htm
might try looking there shoot off some emails or something.
i didnt see anything in us so i guess ill just continue working on my relay attenuator
I have buy 10 MAS9116 and I need only 4.
If you whant I have 6 to sold. I think I will put them on eBay.
i am searching WM8816, MAS DA6116 and MAS9116 but didnt find any at Mouser, Digikey, Newark and others.
I asked the german distributor of MAS and they only sell in 100 unit quantities and for a crazy price.
Does anyone know a reliable source for these chips?
best regards
Alan
best regards
Alan
Hello,
I have 4x MAS9116 to sold at 8,50 euros each, without shipping.
I can have more if needed.
Sebastien
Sebastien
http://cgi.ebay.com/Wolfson-WM8816-...746991QQcmdZViewItem?IMSfp=TL0807091429r14263
I'd purchased mine from this guy.
Farl
Farl
thanks to the guy in greece i have my wm8816. Wolfson discountinued the WM8816 and my calls to the office in Finnald and Germany went the same - "product is not availble".
Now I am searching for MAS DA6116 chips.
please help!!!!
Just purchased a VFD display and connected it to the WMStamp Driver board which i've got from Vetaran as a kit, but the display will not switch on, there is a +5 V as i'd checked in pin 2 on the VFD.
Another question, do i have to install the crystal Q1, C11,C12 and L2 to connect the digital supply of the PIC to make it working? These parts were not included when i received the kit.
Many LCD/VFD/OLED Displays claim that they are HD44870 compatible
but some of them are not. Read the Datasheet of your Display and compare with original HD44870 codes.
Can you give some details about your VFD manufacturer & model no.?
thanks for the replay.
Noritake-itron CU20029ECPB-W1J
Pics:
http://www.noritake-itron.com/SubPages/Photos/Reduced size/CU20029ECPB-W1J.htm
Pics:
Have you tried to adjust the contrast pot on all its course? I also thought my first display was not working but then I found out the pot adjustment is very critical, can be very different from display to display and can be close to the end positions.
Christian
Christian
i'd tried adjusting the pot yesterday but still not working, I wll try more adjustment today after my work.
Christian,
I'd tried adjusting the pot in both ways, but with no success.
I'd double check the pin configuration from the driver PCB to the VFD and i am sure it's correct.
There is a 3 pin CN1 in the rigth side of the VFD module, when i shorted pin 2 and 3, all the dot characters flashes, this means that the module has a power. But why it will not switch on, i don't know.
Some more suggestion please........
farl
farl
Question about discret buffer for the WM8816
Hi guys,
my pal in germany wants to make a high end WM8816 with discret buffers in front and behind the WM8816.
As I can read in the Datasheets the WM8816 needs a feedback loop from an Op amp at the output stage. Can someone explain me why? And how we can do this with a discret buffer (like Jung buffer/ Diamond buffer)?
I think the Wm8816 needs an inverting feedback or I did missunderstand the datasheet.
Datasheet of the identical twin of the Wm8816 from MAS Oy.Datasheet of MAS9116
Hi guys,
- Chip Amps
- WM8816 digital volume control (WM STAMP)
