White noise and slight crackles in one amp channel
I asked ChatGPT what causes crackling sounds in three stage amplifiers. This is the reply:
Crackling sounds in a 3-stage amplifier can be caused by various factors, and troubleshooting the issue may involve checking different components in the amplifier circuit. Here are some common reasons for crackling sounds in amplifiers:
  1. Dirty or Faulty Potentiometers (Pot): Potentiometers, also known as pots, are used for volume control and other adjustments. Over time, they can accumulate dust and debris, leading to crackling sounds when adjusted. Cleaning or replacing the potentiometers may solve the issue.
  2. Loose or Faulty Connections: Loose or corroded connections in the amplifier circuit, including cables, input/output jacks, and internal connections, can introduce crackling noises. Inspect and tighten connections or replace faulty cables.
  3. Tube Issues (if the amplifier uses tubes): In tube amplifiers, crackling sounds may occur due to faulty or worn-out tubes. Tubes can degrade over time and may need replacement. Make sure to identify and replace any problematic tubes.
  4. Faulty Capacitors: Capacitors can degrade or fail over time, leading to crackling sounds. Inspect the capacitors on the amplifier circuit board and replace any that appear swollen, leaky, or damaged.
  5. Interference or Signal Noise: External interference or signal noise can also cause crackling sounds. Ensure that the amplifier is properly grounded, and try different power outlets to eliminate potential electrical interference.
  6. Faulty Transistors (if the amplifier uses solid-state components): In solid-state amplifiers, crackling sounds may be caused by faulty transistors. Testing and replacing defective transistors may resolve the issue.
  7. Power Supply Issues: Problems with the power supply, such as fluctuations or inadequate power, can lead to crackling sounds. Check the power supply components and ensure they are functioning correctly.
  8. Overheating: Amplifiers that run too hot may exhibit crackling sounds. Ensure proper ventilation and cooling for the amplifier, and check if any components are overheating.
3 stage amplifiers don't have any pots! Power supply is irrelevant to the question, and overheating is an unlikely one. Not sure tube amps are what was meant by the question, but its a reasonable thing to mention. Overall not too bad a response though. Lacks useful information for how to identify the faulty part(s) though.
This is the noise analysis for the input voltage and output voltage. I used the LTSpice command
Code:
.noise V(output) V1 dec 100 1 200k
How is the actual noise calculated from this graph?
Comments are appreciated.
Thanks.
  • future_lec_ian_2022_07_04_BJT_and_thermistor_VBE_multiplier_amp_circuit1.asc
