What did you last repair?
I asked our electric company line man, he says the primary 11 kV is a delta connection winding, and the secondary 415V is a star winding, and the secondary neutral is grounded at the pole / mounting plinth.
Phases are 220 V L to N each.
Alternately, this seems to be better for asymmetric loads, from a net search, no ties to anybody...
Zig Zag connection:
https://www.researchgate.net/deref/http://electrical-engineering-portal.com/zigzag-transformer-connection-overview
Our trunk lines are 765 or 800 kV DC, or 400 kV AC.
Sub stations are supplied at 220 kV, and large customers can get 132 / 66 kV connections. 33 kV is legacy, so is 6.6 kV.
11 kV is the 'last mile' distribution voltage, and depending on load, transformers are placed for 'low tension' customers at appropriate distance from the load.
'High tension' describes voltages above 1.1 kV.
Fifteen years ago I replaced my circuit breaker panel and meter housing and service connection to support a house addition.
I came to realize that the house was not grounded with a stake or to any water pipes. I found one ground clamp on a pipe but the wire did not go to the panel or anything.
The utility people who reconnected the panel also said the ground wire on the pole on the street was missing likely due to someone harvesting it for meth.
RF interference with the stereo sure seemed to go away after having a ground to the water pipe and a ground stake added for the panel.
This is in the US so neutral and ground are bonded at the panel.
The question is.... did the power company REPLACE the pole grounding wire, and then put a theft-protection shield or metal conduit around it?
Were they notified of it so they could do the repair?
Because if not, then your house, and perhaps others are the primary ground for the whole system, not a good thing to have.
It may have eliminated RF issues, but your own home is now the primary transformer ground.
That is not acceptable for code.
Reactions: daqvin_carter
Since you guys are working on writing, here's photos of the truck wiring I'm working on... before, during, after.
It's my tribute to electric cars. I'll buy one when they have a range of at least 400 miles, batteries can be fully charged in a few minutes, AND they cost $30k or less. I'll be waiting awhile. Right now, there aren't any EVs made that are "greener" than gasoline vehicles. Mining the lithium and rare earth metals isn't green. Disposing of the batteries isn't greener. Places like LA are having roving blackouts because the power grid can't handle the energy required for the record heat and number of people running electrical appliances. What will happen if more people are charging their EVs. Good luck.
In the meantime, this 1995 Chevy LT-1, 5.7L engine will be fed by a 22 gallon gasoline tank will most likely last me the rest of my life, and I can drive 800-900 miles in 12 hours without having to plan my route around charging stations and having to wait for a recharge.
I saw where a plumber removed pipes and rerouted them, and left the clamp dangling off the wire in midair.
Any kind of rehab should have some kind of engineer or construction manager overseeing it or at least inspecting it. Plumbers aren't engineers.
They replaced the grounding wire though they did not add a shield.
There is another pole adjoining my property that at least had a ground wire.
I try to keep that pole inaccessible to avoid ground loss.
At least now my home is well grounded. I did surround the ground wire from the panel to the stake with half inch conduit just for fun. The second ground is required to be where the water pipe enters the house. Im my case the water pipe is 3/4 inch copper run about 50 feet to the street.
We've here In Philly have had the same problems - copper thieves chopping transformer ground wires from the poles.
Same goes for un-occupied/vacant homes - they steal the wiring, even copper plumbing!
PECO Electric has been putting a half-round shield of PVC with flanges and screwed to the pole to deter theft.
Here they illegally connected the shield to the return path of street lights.
Thieves got a jolt.
Somebody died, so it was stopped.
Aluminum is used here, not as expensive as Copper.
Griunding plate is cast iron alloy, wire to it is galvanised iron.
Not so lucrative for thieves.
Legionella just loves crimped tubes despite being “less chance for legionella” being one of the selling points.
Been there done that, went back to hard soldered copper piping and brass manual crimped couplers. Legionella values back to nil.
Fast & Cheap are always winners 🙂
Around here it isn’t so much PVC - they use PEX. Still plastic. I wasn’t a fan of it either until 2 winters ago when it went down to the single digits and the copper plumbing was NEVER intended with that in mind. Busted pipes all over the place. I got off easy compared to my neighbors but still had my work cut out for me. With the usual 20 degrees it was never a problem. Now that the weather cycles are expected to get crazier and crazier it’s all going to be PEX from here out.
Reactions: mchambin
A neighbour brought me an electrically powered incubator which failed when the mains supply, 230V 50Hz, suddenly rose to 398V. This was caused when a power line touched the neutral line, and the latter, broke for some reason. The result was some households experienced this abnormal voltage surge which destroyed appliances and electronics.
Knowing the above, I told my neighbour that repairs like this are almost impossible if the power supply is a modern SMPS with power factor correction.
Now, the incubator is in my garage: should I even take the time to dismantle it? Or is it all wasted time and effort?
My home is all copper plumbing, and cast iron sewage drain pipes.
The house is 82 years old now, and in good shape still..... just some minor issues due to aging.
I've never had cold weather busting water pipes, however I do take precautions against that happening.
Like draining the outside faucets and leaving them slightly open, shutting off their inside valves too.
Insulation also helps.
