"WHAMMY" Pass DIY headphone amp guide
Thanks for the responses.
It continues. I took out all the regulators and mosfets. I started to put new ones in with the correct heatsinks. Then I noticed that R20 and R37 were .... different. It does not seem to be from the caps. See the nominal and new look ones. They still measure 3Ohms though. Started out as 5 Ohms.
Changed the regulators and mosfets. Changed power supply resistors R20 and R37. At opamp, measured close to 14.8 on both supplies. With old opamp, left channel seemed ok. Right channel was distorted. Changed to opa2134. No sound on right. Left sounds good.
Offsets are about 13mv on both channels now.
Thanks for any suggestions.
Stormfrontier- the 4562 is bipolar input, so use C26, 27.
Leave C2, 3 open
Correct, no LED in psu, or bypass capacitor (C8, 10)
Do you mean C2 and C7? Or am I missing something (which could be very easy with my skill at schematics)?
Supply voltages are ok. So I skipped the power part.
I checked every resistor via DMM. No shorts: Left and right side values match. Visually, caps look ok. As far as I can tell, connections are ok from input to output.
Is there a way to test 4n35 or should I just change the one for the right ? Earlier, with the wrong heatsinks, Q3 had goo on top.
Any other ideas? Thanks.
The input of the optocoupler is connected across both r29 and r32. If you measure the dc voltage across both resistors and it reads about 1.0 to 1.2 volts then the optocoupler should be working correctly.
Thank you.
R16,R22 had 1.1V
R29,R32 had 0
I'll order one of these.
Additionally, Without inputs and outputs,
Supplies ~ 14.8V
Voltages at opamp pins:
7 -330 mV
6 14 mV
5 13.9 mV
1 13.95 V !
2 13.9 mV
3 13 mV
Hello,
I have recently soldered up the Whammy. What a fun project until now.
I have finished everything and now experiencing a lot of hum and noise when turning up the volume knob.
Is there somewhere I should look at?
I have the LM833N op amp.
Any help is greatly appreciated as I am a novice at this.
[/url]Untitled by tam.rmc, on Flickr[/IMG]
Hello lostthumb,
Your regulator configuration does not look like the ones given in "WHAMMY" Pass DIY headphone amp guide
Configuration 1 - “Naked Regulators”
Configuration 2 - “LED reference”
Configuration 3 - “Resistor reference”
It seems to me that you used a mix of them. Which option did you use?
Lol, thank you. I apparently did configurations 1 and 2.
I guess after testing the power part, I started to populate everything else.
I will try to find some time today to remove r9,10,13, and 14
