Quote post: 2258....
JOLLY GOOD i say (Just watching Monty Python).
Got Hypex SMPS today, heatsink en route from italy just needs tuneup caps for SMPS from RS.
Iron on standby now !!!!!!!!! Thanks for update Andrej, best regards Ricky
Hi cuda
No problem at all, integrated thermal tracking (sensing) diodes should become a part of a TL431 bias generator, to prevent thermal runaway ie. to compensate PTC of a darlington pair. 😉
Thank you, I made a schem
Hi guysBYRTT 8 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
DuffyDawg 4 PCB set + 4 SMPS400
electromf 4 PCB set
badrisuper 2 PCB set
volavola 2 PCB set
JethroTull 2 PCB set
kp93300 2 PCB set
momomo67890 4 pcb set
ua3grn 6pcb set
mj777 2pcb set
mkusan 2pcb set
Odysseas 4pcb (2 pairs)
hcbonfim 2pcb set
Albrerta 2pcb set
dw1narso 2 pcb set (1 stereo) + extra output device pairs & isolators (for stereo if possible)
supernet 2 pcb set
milandks 4pcb set
tjencks 2pcb set
quanghao: 2pcb set
audionootje: 4pcb set (2x stereo)
tritosine 4pcb (2 pairs)
Bobo le Chat 2 pcb set
AP2 2pcb set+2pcb empity (i need this also)
Meganinja 2 set ( stereo )
mikvous 2 pcb set
still4given 2 PCB set
Rick G 2 PCB set
kindhornman 2 boards
ravid 2 pcb set
evette 6 PCB set
At the moment we have reached to 108 VSSA PCB set.
Only 2 VSSA PCB set still available.
Who will be the lucky one?![]()
Now the final step to conclude our VSSA GB list is on the move. The quoted post above is my last GB list from post # 2149 and has been updated many times by forum members. What I need now is the final GB list for the amount of 114 VSSA PCB sets, that is also the maximum what I can offer because of limited number of ALF mosfets. So 114 is the number.
Please make final list which will be fair and will consider correct order of applied GB members.
Regards L.C.
LC, the GB VSSA could support 100W 4ohm ?
The PCB set is the PCB with all component ?
thanks
With SMPS400A180 it will deliver 135 W/4 Ohm RMS.
All components included except:
- 10 uF/63 V MKT
- 1000 uF/50 V
- 2200 uF/6,3 V
These capacitors have to be supplied by GB members themselves.
Lazy Cat,
Are those of us here in the USA purchasing these boards through PMI? I would like to send the funds and get my portion of the order underway.
Thank you,
Steven
Thank you,
Steven
Lazy Cat,
Thank you,
Steven
The list I need has to be of a sum of 114 VSSA PCB sets.
On the list I don't see PMI so he's probably making forgeries on his own. 😀
If you're inside 114 than you'll be informed about the details after the GB list will be finalized. 😉
So if it is still possible I would take 2 PCB set, but it seems that not
114 is the final number. I will finalize list tomorrow and all will be clear.
Thanks Lazy Cat,
It was Christophe who convinced me I needed to build this amplifier. So how are we to transfer funds to you and when will you have final costs so we can purchase or orders from you,
Steven
Steven
Thanks Lazy Cat,
Steven
Please wait for me to finalize the list. Than all GB members will be invited to send me exact delivery addresses to my e-mail. Than the offers will be replied back and after the payment will be confirmed, mailing will be started. So please wait a little bit for formalities to start. First move is to finalize GB list because there are more than 114 sets applications present. 🙂
BYRTT 8 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
electromf 4 PCB set
volavola 2 PCB set
kp93300 2 PCB set
ua3grn 6pcb set
mj777 2pcb set
mkusan 2pcb set
hcbonfim 2pcb set
Albrerta 2pcb set
supernet 2 pcb set
milandks 4pcb set
tjencks 2pcb set
quanghao: 2pcb set
mikvous 2 pcb set
Rick G 2 PCB set
ravid 2 pcb set
siberia 1 pcb (if possible)
gnat 2 pcb set
potepuh 2 pcb set
metallicus69 4 pcb set
Ranchu32 2 pcb set
woofertester 4 pcb set
edbk 4 pcb set
Raj1 2 pcb set (or 6 if available)
analog_sa 3pcb set + extra output device pairs & isolators (for stereo if possible)
mravlca 2pcb set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
electromf 4 PCB set
volavola 2 PCB set
kp93300 2 PCB set
ua3grn 6pcb set
mj777 2pcb set
mkusan 2pcb set
hcbonfim 2pcb set
Albrerta 2pcb set
supernet 2 pcb set
milandks 4pcb set
tjencks 2pcb set
quanghao: 2pcb set
mikvous 2 pcb set
Rick G 2 PCB set
ravid 2 pcb set
gnat 2 pcb set
potepuh 2 pcb set
Ranchu32 2 pcb set
edbk 4 pcb set
mravlca 2pcb set
Quote gannaji post 2250: Hi gannaji, after public v1.4 this thread went "Commercial sector", please respect.
kindly answer:
Your request say purpose is for education and learning hmmmm, then i say read this hole thread it is top stuff for education and learning, and when you have read hole thread you are able to compile same schematic as i have = learning. If you after have read the hole thread not are able to nearly understand circuit and compile nearly same schematic as shipped, then i claim your skills is at such level that if you got copy of mine v1.4x, you won't understand anyway = no learning.
Digging into this thread will also take you to 4 x other very hot VSSA version threads.
And remember i am hobbyist, so how true is my v1.4x.
Skeptical answer:
Truth is that v1.3 is splendeed for engineering education and learning, final version is just tuneup for real world stability and performance, what do you need this for ?
If you have hidden agenda/purpose behind request, for example build your own private high performance amp or go commercial production by your own, i suggest: Contact author to participate in group buy (for private amp), or negotiate with author about OEM possibility.
Last you could try request author for final version.
Ricky
Dear Ricky,
Please note:
- I am 76 years+, retired and have no commercial interest.
- I was reading this thread since start as also the VSA, TSSA, PeeCeeBee etc. threads since beginning.
- I already purchased two sets of the boards from LC in the first GB and also extra semiconductors to try Shaans version.
- I am grieved at your insinuating and harsh reply.
Dear Ricky,
Please note:--gannaji.
Im sorry gannaji, you can have a excuse to a certain point.
But because of point 2 and 3. circumstances, i can't imagine why you ever asked, because the layout with its final schematic is copyrighted and you did know.
Get permission from author and of course i will share, but we got to respect peoples choise to make for the day in a world as is (controlled by $).
Ricky
Ref post 2274:
"Picture 1=Single ended v1.4x schematic
Picture 2=Balanced v1.4x schematic
Picture 3=Single ended v1.3 schematic
Picture 4=Single ended v1.4 schematic"
Agree you cannot post 1.4x schematics. Can you post schematics for 3 & 4?
Reduced my order.. doesn't seem to help much...
BYRTT 8 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
electromf 4 PCB set
volavola 2 PCB set
kp93300 2 PCB set
ua3grn 6pcb set
mj777 2pcb set
mkusan 2pcb set
hcbonfim 2pcb set
Albrerta 2pcb set
supernet 2 pcb set
milandks 4pcb set
tjencks 2pcb set
quanghao: 2pcb set
mikvous 2 pcb set
Rick G 2 PCB set
ravid 2 pcb set
gnat 2 pcb set
potepuh 2 pcb set
Ranchu32 2 pcb set
edbk 4 pcb set
analog_sa 2pcb set (will even take 1 if none are left)
mravlca 2pcb set
BYRTT 8 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
electromf 4 PCB set
volavola 2 PCB set
kp93300 2 PCB set
ua3grn 6pcb set
mj777 2pcb set
mkusan 2pcb set
hcbonfim 2pcb set
Albrerta 2pcb set
supernet 2 pcb set
milandks 4pcb set
tjencks 2pcb set
quanghao: 2pcb set
mikvous 2 pcb set
Rick G 2 PCB set
ravid 2 pcb set
gnat 2 pcb set
potepuh 2 pcb set
Ranchu32 2 pcb set
edbk 4 pcb set
mravlca 2pcb set
"Au cas où"
BYRTT 8 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
electromf 4 PCB set
volavola 2 PCB set
kp93300 2 PCB set
ua3grn 6pcb set
mj777 2pcb set
mkusan 2pcb set
hcbonfim 2pcb set
Albrerta 2pcb set
supernet 2 pcb set
milandks 4pcb set
tjencks 2pcb set
quanghao: 2pcb set
mikvous 2 pcb set
Rick G 2 PCB set
ravid 2 pcb set
gnat 2 pcb set
potepuh 2 pcb set
Ranchu32 2 pcb set
edbk 4 pcb set
mravlca 2pcb set
Cuda 2pcb set
BYRTT 8 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
electromf 4 PCB set
volavola 2 PCB set
kp93300 2 PCB set
ua3grn 6pcb set
mj777 2pcb set
mkusan 2pcb set
hcbonfim 2pcb set
Albrerta 2pcb set
supernet 2 pcb set
milandks 4pcb set
tjencks 2pcb set
quanghao: 2pcb set
mikvous 2 pcb set
Rick G 2 PCB set
ravid 2 pcb set
gnat 2 pcb set
potepuh 2 pcb set
Ranchu32 2 pcb set
edbk 4 pcb set
mravlca 2pcb set
Cuda 2pcb set
Final VSSA GB list
BYRTT 8 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
electromf 4 PCB set
volavola 2 PCB set
kp93300 2 PCB set
ua3grn 6pcb set
mj777 2pcb set
mkusan 2pcb set
hcbonfim 2pcb set
Albrerta 2pcb set
supernet 2 pcb set
milandks 4pcb set
tjencks 2pcb set
quanghao: 2pcb set
mikvous 2 pcb set
Rick G 2 PCB set
ravid 2 pcb set 100
gnat 2 pcb set
potepuh 2 pcb set
Ranchu32 2 pcb set
__________________________________________________________
114 VSSA PCB set
Optional GB list if any from above will cancel the order:
siberia 1 pcb (if possible) - not possible, please send broken VSSA to repair 😉
edbk 4 pcb set
mravlca 2pcb set
Cuda 2pcb set
Guys please check GB list and if any from above the line list would like to cancel the order please say it now, so the guys from optional GB list can be supplied. 🙂
Regards L.C.
BYRTT 8 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
electromf 4 PCB set
volavola 2 PCB set
kp93300 2 PCB set
ua3grn 6pcb set
mj777 2pcb set
mkusan 2pcb set
hcbonfim 2pcb set
Albrerta 2pcb set
supernet 2 pcb set
milandks 4pcb set
tjencks 2pcb set
quanghao: 2pcb set
mikvous 2 pcb set
Rick G 2 PCB set
ravid 2 pcb set 100
gnat 2 pcb set
potepuh 2 pcb set
Ranchu32 2 pcb set
114 VSSA PCB set
edbk 4 pcb set
mravlca 2pcb set
Cuda 2pcb set
Regards L.C.
QOUTE: Post #2275. Hi gannaji, for sure but program does not support extension ".asc" files.
Program can save as own file format ".tsc" extension, and export something called "Netlist for PSpice(*..CIR), export as picture file (*.EMF,*.BMP,*.JPG), export as (*.XML) file.
If you cant use these extensions i suggest you download the program yourself from Texas Instrument website, it is free and manual and helpfiles can get you running. So post answer here and i can attach files in another post.
And last if you just need schematics then see post #1 for v1.3 and see post #300 for v1.4.
Ricky
Ricky
To LC and others, may-be this can interest-you:
http://www.esperado.fr/temp/VSSA/cfa-vs-vfa.html
Distortion, bandwidth, slewrate, noise, PSRR etc.
- Vendor's Bazaar
- VSSA Lateral MosFet Amplifier
