Unusual amp from 1987
This is how HexFet quasi may look like.
Simming is not completed yet..
2SK1530 is not lateral. this is vertical mosfet.
Millenium Crescendo amp was using them. Usually, for some strange reason, without drivers, so people may think they are laterals..
See this thread:
Designing amp with 2SJ201/2SK1530
It looks like they need lower current to drive them, that's why no drivers... But they are still vertical.
А что мешает использовать диоды КД522/1N4148 ? Здесь не нужны идеинтичные пары источников образцового напряжения в генераторах тока.
And what prevents the use of diodes KD522/1H4148 ? In current generators, there is no need for ideal pairs of reference voltage sources.
Here are my "final" (?) sims of one complementary HexFet version,
and two versions of Quasi HexFet (with FQA and IRFP260 devices, there are very small differences).
Looks like Maxim's build will be BJT version (triple output), I'm only planning to build HexFet version.
For quasi - not sure yet if I'm gonna use IRFP260 or FQA devices, I guess depends on correct matching.
Have good experience with both of them.
  • lmk.max.dec27.hex.240.asc
  • lmk.max.dec27.qhex.fqa.asc
  • lmk.max.dec27.qhex.ifrp260.asc
