The VAS drivers directly drive the output devices in this amp so changing the pot or R29 will do the same thing for the outputs. I think R29 will also change bias on the VAS drivers themselves though. I've noticed the amp sounds better when it's warm. I'm not sure if it's the temperature of the output devices or the VAS drivers improving the sound. That's why I'm asking.
Voltage over R41, R44 is expected to be 0.93V, giving us 9.3mA at that point.
From that current, 1.3mA goes through R38, supporting the cascode.
The rest 8mA - is VAS current.
In other words, to calculate actual VAS current - measure voltage over R41, R44, multiply by 10 and subtract 1.3 🙂
8-10 mA is good for driving the lateral FETs.
I'm still a newbie at building amps. So pardon my ignorance. I'm having trouble determining what these parts or they aren't available to build this amp. For example the FETs aren't available with Digikey or Mouser. Any alternatives or suggestions on where to get them?
50R 64W100 Pot 2
10 64W100 Pot 2
1k RES500 4
470 RES500 8
0.1 5W Cement 8
2R2 RES700 2
FET 2SK1058 4
FET 2SJ162 4
BJT 2SA1381 2
BJT 2SC3503 2
I can find trimmer resistors but when I type in 64W100 POT it brings up only one item in Mouser. The other trimmer resistors that come up I cannot tell if they will work on the board. So I'm kind of stuck. A Bom with mouser #s or Digikey #s really helps if you want to get your amp out there ....
Thanks.
50R 64W100 Pot 2
10 64W100 Pot 2
1k RES500 4
470 RES500 8
0.1 5W Cement 8
2R2 RES700 2
FET 2SK1058 4
FET 2SJ162 4
BJT 2SA1381 2
BJT 2SC3503 2
Thanks.
T93XA500KT20 Vishay / Sfernice | Mouser
CMF551K0000FKEA Vishay / Dale | Mouser
MF1/4DC4700F KOA Speer | Mouser
TUW5JR10E Ohmite | Mouser
SFR16S0002208JA500 Vishay / BC Components | Mouser
KSA1381ESTU Fairchild Semiconductor | Mouser
KSC3503DS Fairchild Semiconductor | Mouser
Buy the others here.
5 x 2SK1058 N Channel MOSFET 160V 7A RENESAS | eBay
5 x 2SJ162 J162 MOSFET P Channel 160V 7A RENESAS | eBay
With regards to resistors:
50R 64W100 Pot 2 - multi-turn trimmer
10 64W100 Pot 2 - multi-turn trimmer
They look like these ones:
Honeywell
Bourns
Just find the right values - 50R and 10R respectively.
1k RES500 4 - metal film, 1k, 1/4W, 1% resistor
470 RES500 8 - metal film, 470R, 1/4W 1% resistor
0.1 5W Cement 8 - cement, SQP type, 0R1, 5W, 5% resistor
2R2 RES700 2 - metal film, 2R2, 1W, 5% resistor
RES500 and RES700 are just "internal" marks, coding the power rating (RES500 = 1/4W, RES700 = 1W).
Honeywell
Bourns
3296X has the trimmer screw on the side. 3296W is a little more convenient with the top screw. 3296W-1-100LF Bourns | Mouser
Sorry, I should have read the specs rather than looking at the picture.
Mouser's terrible with their descriptions! I always go straight to the datasheet when ordering through them.
This version tested yet sir?🙂Yes, I can, as always 🙂
Regards,Alex
Hi, I did not test the PCBs, developed by Alex (although, what he is doing, is always high-quality). My PCBs are used in a number of builds I'm aware of (at least 4 builds, including my own).
Valery
Thank you vzaichenko let me board part list of this version was not driving K170 thanks.🙂Hi, I did not test the PCBs, developed by Alex (although, what he is doing, is always high-quality). My PCBs are used in a number of builds I'm aware of (at least 4 builds, including my own).
Valery
OK, I understood you'd like to have gerbers PCB and the parts list (BOM), but I did not understand with regards to K170 🙂
Also, please drop me your e-mail - I send gerbers personally.
Valery
Valery
list mean inputs K170 version and not the user the input tube. thanks sir.🙂OK, I understood you'd like to have gerbers PCB and the parts list (BOM), but I did not understand with regards to K170 🙂
Valery
dear vzaichenko please check messages offline thanks a lot🙂OK, I understood you'd like to have gerbers PCB and the parts list (BOM), but I did not understand with regards to K170 🙂
Valery
Done 😉
- Ultra-high performance, yet rather simple - hybrid and more!
