Ultra-high performance, yet rather simple - hybrid and more!
Current flow through Q4 and 5 are fairly equal as is Q6 and 7. On the good board current flow is always higher in Q4/5 than Q6/7. On the bad board it's always opposite.
My BipSumo boards have now become TubSumo boards and I think the old TubSumo boards are going to get driven over. On the new boards Vas current is slightly lower and DC offset still isn't great. My heater voltage is close to 7.5VAC. Is that too high? I'm using a 6.3VCT 4 Amp transformer. Self regulation is pretty poor obviously.
What is the voltage at the servo output - right at pin 6 of LF411?
When it can't balance out the offset, it normally goes to the limit (some 14V or so). Is this the case?
One board is pretty good. Offset is only -3mV. Pin 6 is +2.7V on it. The other board is hovering around -40 mV. Pin 6 is around +2.5 on it. It seems more like the servo is holding it at that offset. Both boards are fairly steady, only drifting a couple mV. Would this be a mismatch of R18 and R24?
You're right - this servo topology assumes pretty low tolerance. I use 1% only.
