Ultra-high performance, yet rather simple - hybrid and more!
My BipSuMp inputs work perfectly. 1mV offset on one and 3mV offset on the other. 1.6V between ND and PD with 100 ohm resistors to NFB. Both are pretty much identical in operation. Both have -200 mV DC offset with the servo pulled. It looks like matching devices (other than mismatched gain ranks on A1381/C3503) has helped. I have 2 sets of matched devices waiting to go into the TubeSoMo inputs. Hopefully that fixes them up.
Perfect!
8mA VAS current - exactly as designed.
200mV with no servo is a pretty good balance.
Looking forward to seeing your tube- ones working as well 😉
I've been battling with the tube inputs a little more. I've switched them to BJT inputs for comparison. DC offset is now gone completely. The board that I thought didn't have enough VAS current is actually perfect. The board that I thought was good actually has too much VAS current. It will likely be easier to find the VAS issue on the defective board.:scratch1:
Interesting...
For the beginning - if you can measure the voltages on both boards:
- across D3, D7 LEDs;
- across R29 resistor (150R).
And then we'll see.
At the same time, it looks like you've got some problem with the tubes. Are you sure, the "heating" voltage (6.3V AC) is stable enough? In case it is lower, than that, anode current is somewhat lower than expected, resulting in "inadequate" operation...
