I am still gathering the parts. I had to fix my car first
Question 1: Why 317 and 337? I have some KA7812 and KA7912 in the right package and I am planning to use them instead.
Question 2: How about ADA4627-1BRZ? AD says that is recommended for new design instead AD8610...
Hmm. My regs are in TO252 (Dpak). Your design is for SOT223...
My question was more about - why did you go for the adjustable ones in the first place? Is there an advantage that I am not aware of?
http://www.fairchildsemi.com/dwg/TO/TO252A03.pdf
http://www.fairchildsemi.com/products/analog/pdf/sot223_dim.pdf
Started soldering mine today, unfortunately our daughter woke up in the middle and wanted some of daddys attension But SMD isn't so hard once you have tried a couple of times
Tried the same vendor as you UrSv for casing so we will se if something shows up in the mail in a week or two
icewall, be aware that the chassis doesn't come with standoffs (have some to hand) and the front panel goes on with Allen (hex) screws. I didn't have a bit that fit (needs ~2.5mm) so I dug out my Imperial Allen key set and used a 3/32" key which came close to stripping out the screw head.
Luckily I'm fully loaded with Allenbits...
Yeah, that's what I thought too... until it came time to dig up the set and find one missing.
Now, mine is also playing An easy build despite SMD:s thanks to a layout it is easy to solder
Had no trouble finding standoffs so everything is mounted but I'm waiting for the volume control so I have only tested it with my SB Duet, sound is crisp, clear and very detailed.
Actually, the design of the boards is so good that I don't see any trouble with fault finding (if needed!) and with very good documentation things are even easier. SMD:s are not the complete PITA:s as I remembered them to be a couple of years ago
by the way P-A, are there any boards/kit left? If so I'm thinking of one more for the office or so....
Dont fear SMD:s
Dont fear SMD:s
Can Vishay DF04S-E3/45 (DF04S-E3/45 Vishay Semiconductors Bridge Rectifiers) be used instead of DBLS105G? What would be any other substibutes?
q on substitute parts
Notes: replaces the post above. I timed out while editing the above one...
Hi:
I work through the BOM, and a number of parts are not even listed at Mouser. Will the following substitutes work? Possible substitutes are:
Hi:
- 3M 929647-04-36-I for SL1.025.36Z (929647-04-36-I 3M Electronic Solutions Division Headers & Wire Housings)
- Nichicon LKS1V222MESZ for MCLPR35V228M22X25 (LKS1V222MESZ Nichicon Aluminum Electrolytic Capacitors - Snap In)
- Vishay DF04S-E3/45 for DBLS105G (DF04S-E3/45 Vishay Semiconductors Bridge Rectifiers)
- Phoenix 1935190 for Wago 256-405 (1935190 Phoenix Contact Fixed Terminal Blocks)
- TI LM317DCYRG3 for LM317AEMP (LM317DCYRG3 Texas Instruments Linear Regulators - Standard)
- Ultra high performance headphone amplifier QRV09
