• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Ultimate Twin TDA1541a Non-oversampling DAC with tube buffer & reclock set.......
this is tailor made two chamber Bobbin ( not same as the china made one, use higher quality plastic that thinner & more strength for support) that will better improvement the band-width.
Two chamber bobbins seperate standard one chamber winding with about advantage which can possible lowest leakage inductance less than 0.3~5% and hence high frequency response.
Every primary & secondary winding of Pre-amp output will had 7-interleaved winding in same chamber.
Use triangle wave can see the phase was
improve by two chamber.
thx
thomas
Wow, Thanks Thomas for sharing your knowledge. I'm a beginner so much of this is advanced to me. I'll keep on rereading and researching all your wisdom and hope to decode every bit of it🙂.
>1. decoupling caps, at least change MKP or tantalum caps to increase the slew
>rate or said ( discharge & charge rate ). Standard caps use in vintage 1541a
>machine most was MKT caps 0.22uf.
Ok the caps installed are Wima MKP 10 .1uf matched. Are these ok?
On the output stage of this dac I can use either 12at7 or 6dj8 type with it's stock configuration. 6dj8 seems to be more to my liking in non oversampling mode. 12at7 is pretty good with the SAA7220P installed but with 6dj8 it can be a bit bright sometimes in this mode.
Here is the schematic of the dac i have
http://www.dynaco-doctor.com/cddacsch.gif
Here is the description
http://www.dynaco-doctor.com/cddes_3.htm
I believe c109 and c110 are the output caps. There are two a channel and they are .47uf. So change these each to two .22uf's and one .01? Do you have any brand recommendation? Also if I just lowered the over all value it would reduce the low bass response?
On your v3 dac, I am kind of excited that you made it so one can just use a ide cdrom/dvdrom for playback. No need to worry about drives going bad in the future. How did you get the digital stream from them?
tube-lover said:
I received the post office message already. CS8412-IS was arrived already. I can collect tomorrow.
this is another chip that I test, any people like use vintage can try.
This chip not bad.
thx
thomas
Thomas, my current dac is using this same yamaha chip, the YM3623B. How does it's sound compair to the CS8412?
YM3623B cannot directly use into the Dac. it need modify.
I test use old machine which this chip & connect into 1541a. e honest, the sound state was quitey good. If U like to make a choice. i will choose back 8414.
That why I prepae small amont of 8412-IS & 8414 for diyers to choose ecause they can directly exchange.
U can try??? Is your 1541a use 3623B, can u post a photos to discuss.
thx
thomas
Hi all,
I know what's problem in my email account already.
My server website link was broken & all transfer into admin account. Oh! it crazy over 300 letters email. I will one by one return, sory sorry for this.
I had a very interesting idea.
did any diyers interesting for audionote M10????
Since M10 circuit was very sample.
I was count the price. If I can use USD 500 to prepare a enhance version M10 to all diyers. Are U had interest??
why I said enhance!! All the tubes of M10 use 0.2mm 45% nickel permalloy core Grid choke to exchange for the grid resisters. It need 8~10pcs per machine. output transformers was use oriential Hi-B 66X50 20~45Khz -1.5db ( Daburu Pre-amp OPT).
All the resistors was USE Dale or simlilar 1% metal film. contain chassis, 6072 was EH tubes. I had over 750 pcs 5687wa on hand. 5687Wa will follow with the kit. also 23 step, 4 layers mono volumn will follow with the kit.
Price was include all, U can choose all funish or not. cable was gotham cable.
I hope to collect some advise.
thx
thomas
dear anthony,
I understand U pay to me already. since there had some problem of the remain chassis. I use drill machine fix by myself. don'y worry for that. U will collect it.
Also ver.3 is coming. ca U help me to fix one to test & told me the performance to share with the diyers.?????
Post all to gether I not need to lost too much postage. I will post the PCB with the 7220p/b only another chips & partsI guess U will on hand.can U do this for me???
thx
thomas
tube-lover said:
hi jleaman,
I PM to U already, do U received it.
BeerCan, I recovery the email box already. there had several hundred o it eed I check & clear, what is the user name of your emails???? is it same BeerCan.
I will check one by one & return email.
thx
thomas
You pm'd me but never replied to my questions.
tube-lover said:
dear anthony,
thx
thomas
Sure Thomas,
I have original Phillips TDA1541 Single Crowns that I want to use in the Dual DAC. Both V2 and V3 are still Dual DAC boards correct?
Anthony
