We will go with the decider of the first 5 that vote.
1 for back panel II
Probably thinking it would be a good idea to put handles on the back panel. What do people think about that?
These chrome handles would look good on the back panel
Maniglie tonde 3 unita cromate
1 for back panel II
Do I need to draw them on a split 250mm heatsink?
I have drawn them as they would appear on a solid single 4U x 500mm heatsink.
Whatever floats your boat 🙂
I like panel 2. Handles on the back panel might be too close to the connectors. I dont't need them, but will go along with the group. Thank you, Bill
No II also, what about IEC mains input / fuse socket?
Also what is your preference, location for mains on/off switch
I was going to go with the standard all in one schurter IEC cut out that is standard on the deluxe back panel.
If people want something different to that, let me know.
Once you have them you'll be glad they are there. That's how I felt once I installed handles on my amp.
Everything will be repositioned a touch for the handles if required.
What are the hole spacings for these chrome handles.
90mm
I would like to suggest that we have an option to use separate line fuses for dual-mono configurations. It's Ok to have the IEC inlet and power switch combined, as long as the switch is a dual-pole variety. That way the only thing that two channels will have in common is the power cord. I like the screw-in type of fuse holders that use a round mounting hole.
Yeah, no problems
Just been dealing with a massive life change - redundancy.
Friday was the last day.
I should be able to focus my full attention on it now.
There is very little extra to do.
Sorry to hear that news pico, unfortunately you are not the only person in that position in Victoria. Good luck with your new endeavors.
Looking forward to further updates as you find the time.
Thanks for your support.
I will get back to this tonight - should have it completed by the end of the weekend.
Are you able to confirm the outside diameter of the barrel on the Cardas xlr, just so I am certain the hole cutout is the correct size.
- Ultimate 4U 500mm Chassis - Who is interested?
