Hi pico, what about a cutout on the back panel for the IEC mains socket /fuse. switch?
Like this one: 6765 - IEC Appliance Inlet C14 or C18 with Line Switch 2 pole and Fuseholder 1- or 2-pole
Yeah that is the standard cutout modushop does.
My understanding is I don't need to add it in, as gianluca will put it in.
I will add it now if you want though.
Can people confirm if they are happy with a standard 10mm front panel, or whether they want it more unique looking.
Yes, to blue LEDs in the front panel! I prefer smaller ~1mm through holes with back bore of 3mm or 5mm for the body of the LED.
One of the things I like to do is make sure there is good contact between the side heatsinks and the front panel. This helps spread out power dissipation.
I was going to do the LED holes like Firstwatt.
Is that ok?
Say with Oval 3mm leds.
Is that ok?
I’m sure I can make that work. 😉
90mm
Holes have been placed on back panel.
Do I need to add the standard schurter IEC cutout to the back panel or will you add it?
Hi Gianluca
As soon as we have confirmed these minor details I will send you the dxf files.
Do you have an email, I can send them too?
IEC cutout needs to be added to the drawing if you want it. You can send your drawings to info@modushop.biz once they are ready
- Ultimate 4U 500mm Chassis - Who is interested?
