Match input pair Vgs at 3mA.
Current source requires 6~8mA.
Idss is usually ~20mA, which we shall not be using.
Hence the need to use Rdg.
To find out what value, make a small breadboard and see what resistance you need to get to 6mA.
See also :
Understanding the J113 JFET - diyAudio
Patrick
See also :
Patrick
Makes perfect sense. You will have done all the hard work. Even I should be able to order the PCBs. Thanks for this project. It looks very intriguingOnce tested OK, we shall publish the Gerber files.
You can then use them to order your own PCB.
Lowest cost option. And no work for us.
Patrick
First test successful.
Everything worked as intended.
Heatsink temperature 40°C after 1 hour.
DC stable to 20mV after trimming.
So servo can be optional.
Patrick
Have you looked at the harmonic distortion spectrum already? Did you compare measured distortion spectra with the IRFs and the Semi Souths at the output?
A short update.
A lot or work has been done over the weekend, without saying.
We have to make some adjustments to the circuit, as the Spice models for the MOSFETs and the JFETs do not seem accurate.
See e.g. :
JFET buffer with J113
For example, we need to adjust the R11/R13 ratio to get close to equal current sharing,
We have also measured the distortion spectrum and it is predominantly H2, with H3 20dB lower.
H4, H5 are below noise level.
But the H2 level is still a bit high for our liking, so we have a bit more fine tuning to do.
Will take a bit longer, but we are pretty sure we know how to get there.
Patrick
See e.g. :
Patrick
- UDNeSS, or You don't need Semisouth's
